Question about Sony KP-53V90 53" Rear Projection Television
The image is overlapped; i tryed the image focus to allign it again, but it did not work Model KP-53V90 SONY PROJECTION TV 52"
    President:
  • 2,777 Answers
This is a sign that the video board in the TV is actually failing... starting to go bad basically. Do you think you want to try and do the repair yourself, it is not easy unless you have done TV repairs of this nature in the past.
Please let me know, I will be glad to help you figure out what part exactly and where to get it from..
Thanks, just reply to my answer here and I can help.
Tim
Posted on Nov 06, 2010
HOW DO YOU FIND IT AND THINK THE REMOT IS NOT THE PROPER ONE FOR THE TV IT DOES WORK BUT LIMITED
Convergence is the alignment of the red, green and blue lines to produce a white line when doing a convergence setup. You need the correct remote to do that. Support for KP 53V90 Sony
May 24, 2016 | Sanyo Televison & Video
Sony kp-53v90 no picture but has sound and display lettering
The tv have a problem known as a convergence problems,it dead.The tv convergence board require changing 2 STK convergence ICS and some or all it resistors to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 05, 2010 | Sony KP-53V90 53" Rear Projection...
I HAVE A SONY KP-53V90 53 INCH REAR PROJECTION TV AND THE COLORES ARE NOT MERGING TOGETHER PROPERLY I THINK THIS IS CALLED A GHOST IMAGE HOW CAN I FIX THIS
You have a convergence issue, will have to check convergence IC,S or just replace them there are usually two of them mounted on heat sinks they are usually STK'S with a number after. Also must check fuseable resistors supplying +15 and - 15 volt s to the chips. After replacement some convergence alignment may be needed. Good Luck.
Mike
Apr 15, 2010 | Sony KP-53V90 53" Rear Projection...
I have a Sony KP-53V90 53 with no display and red light flashing
This is a good one. Your TV "looks" at the feedback coming from each picture tube in your TV. When it doesn't see what it expects, it kicks out a 5 flash. Most commonly, the correct signals never got to the picture tube(s) and that's why the feedback was abnormal. Which brings us to the most common solution: C boards, they attach directly to the bottom of the picture tubes. Figuring out which one has a problem... that's another matter. Due to the age of the TV, parts costs are rising. Each C board (3 in the TV) runs about $100 so guess work can be expensive. I hope this was helpful.
Mar 28, 2010 | Sony KP-53V90 53" Rear Projection...
I have a Sony KP-53VP0 Rear Projection TV Kinda Cloudy Picture.
take off the back of the tv and clean the lenses and the foggy picture will go away
Jan 14, 2010 | Sony KP-53V90 53" Rear Projection...
I have A sony kp=53v90 tmier stand by light falshes twice
Well I believe you are on the right thought pattern.
I beleive this is an older CRT rear screen projection TV.
Could just possibly be a Power supply issue or a bad HOT 'High Output Transistor.' It could also be a flyback issue.
Will need to be taken in to a trusted service shop to have it looked at. May be a time to look for a new TV. Sorry!
Blessings,
A/V Media Tech Guy
Dec 19, 2009 | Sony KP-53V90 53" Rear Projection...
The picture is out of foucus
If your tv is Sony KP-51WS500, then its rear projection tv and problem seems in convergence stage.
Please confirm model number to guide you further.
Oct 11, 2008 | Sony KP-51WS500 51" Rear Projection...
Remote control does not work.
In Sony KP-53V90 TV, Remote Sensor (IR) is located in HC board and an exploded view is pasted here for reference.
Sep 28, 2008 | Sony KP-53V90 53" Rear Projection...
NO AUDIO OR AUDIO GOES IN AND OUT
problem is defective part on audio bd., either audio I.C. or a bad resistor or capacitor on the output side of the I.C.
Dec 30, 2007 | Sony KP-53V90 53" Rear Projection...
TV turns off-on when I try to adjust the volume
check tact switchs ALL on the control panal. several with leaky switchs.good luck wayne
Oct 22, 2006 | Sony KP-53V90 53" Rear Projection...
Sony KP-53V90 53" Rear Projection Television Logo
47 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
