Question about Frigidaire FRS266ZDSB Side by Side Refrigerator
Fridge is too cold
Please help, I just have had my fridge just over 5 years and the last couple days I noticed the milk somewhat frozen, I have not touched the temp it is set at 3 under thr thr factory setting. We pulled it out and cleaned the litttle
venting it has in the back and cleaned the floor and walls from any dust. The freezer seems fine. any suggestions. the manual does not help.
e-mail me at pretsos@sbcglobal.net Thanks
    Scholar:
  • 149 Answers
Do a test put the fridge on 1 or 2 (the warmest settings) if you don't see that it turns off you have a defective thermostat. there pretty easy to buy and to install if you need assistance just feel free to e-mail me @ hvac.tech7872pr@gmail.com
Posted on Jun 15, 2008
Lamona fridge/freezer HJA6855. Freezers ok, but fridge isn't cold. One part of the fridge iced up, whilst the rest is warm. Light still working. Milk lasts 2 days! Please help. Thanks
  • Have you tried manually defrosting or checking the evaporator to see if it is frozen over? Just checking the ice pattern on the evaporator is important. Sounds to me your are having problems with the defrost components like the=> HJA6855 Defrost Heater
  • or the Defrost Timer? I am here should you have questions, Thanks John Tripp Appliance 911
Jul 12, 2015 | Refrigerators
Electrolux Side by Side Fridge-Freezer ESE6108WA - freezes food in the fridge
hi its sound thermostat problem not click off when the temperature reach to the set point ,need to replace it.
May 14, 2012 | Electrolux Refrigerators
Our 2004 GE gsl251grb bs refrigerator is freezing food.
1st try cleaning the condenser core cooling fins
Aug 23, 2017 | GE Refrigerators
GE side by side mod 7FX20JR can't read the rest. Quit making ice and freezer side just cold. Fridge side only little cold. Cleaned out freezer-had to throw most food away. unplugged unit. Cleaned out...
Sorry to hear about your problem. Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it. If not. you have other issues
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
Dec 22, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge too cold.Freezer OK.
You probably have an issue with one of the following:
* temperature control assembly (controls freezer and/or fresh food temperatures)
* damper assembly (allows air from freezer to fresh food compartment)
Contact an appliance service company.
Feb 26, 2010 | Refrigerators
We have a Whirlpool gb22dk refrigerator freezer. The bottom freezer keeps meat frozen but will not keep sea food ice cream bread ect frozen. This fridge came with our house which we purchased 2 years ago...
1st.Check the freezer door gasket for any place it maybe torn or not making a 100% seal when you close the door.That would make temperature drop. 2nd.take off bottom kick plate so you can look under the refrigerator.Using a flashlight make sure there is not alot of lint / dust stuck on the coils .If there is remove it carefully and you will see temperature lower. PLEAS RATE THIS!
Jun 09, 2008 | Whirlpool Refrigerators
I have noticed that fridge seems to be running alot lately I did all routine maint. cleaning coils etc. and it still seems to be running alot. model number is afd2535dew top fridge french door. Is there an...
not really sure as far a swhatconstitutes ruining along time, you are doing the right thing by keeping it clean for sure, refrigs now run for as long as they need if it never stopped running youd see hte effects of that in 2 ways, either all your food would be FROZEN solid( cause it never shuts off), or your food would be spoiling quicker hat n usual, in which case your refrig is trying to run all the time to maintain temps! the noise that you hear running might just be the evap fan motor running( circulater fan, sure its gonna run to circulate, but the compressor wont be running all the time.. check and go by your dairy products, ice cream too hard or too soft, and in refrig check the milk and butter.youll never know how cold you leftover is but youll know right away if the milk it too warm
Mar 19, 2008 | Refrigerators
Fridge wont get cold and freezer gets cold then gets warm
Sounds like to me you have a defrost issue. If your fridge is only 2 months old don't sweat it and call out a Whirlpool warrenty certified tech. to fix the problem. And sorry to say age does not matter with fridges any more. The good ole days of fridges lasting 20 years is over now it's 12 years if your lucky.
Feb 24, 2008 | Jenn-Air JCB2280HES Side by Side...
5 year old Maytag Wide by Side Refrigerator side not cooling
Same issue with my 6 yr old Maytag side-by-side model #MSD2756GEW. Turned out it was caused by a faulty circuit board. This circuit board is located in the upper right fridge section. Apparently these boards are sensitive to power surges (which we have here in central Texas from time to time.) When the circuit board is fried, it makes a noise like a fan blade malfunctioning and it stops the auto defrost feature in the freezer from working. So the freezer ices up at the back, and the ice prevents the cold air from reaching the fridge section.
Our circuit board (which we thought was a fan) made ominous noises for a few months. (The noise would last only a minute or so and stop shortly after we opened a door). Eventually we noticed that the fridge wasn't as cold and the freezer had snow in it. Finally the board stopped making noise and about a week or so afterward we noticed that the milk had spoiled and the fridge wasn't very cold. The food in the freezer side pretty solidly frozen, thankfully.
In addition to replacing the circuit board, the fridge had to be de-iced or it would not work properly. I put it all frozen into a large camping cooler where it stayed for several hours. I opened the freezer doors and put table fan and pointed a hobby light which gets quite hot, at the back of the freezer. Within 3 hours, the ice had melted significantly so I could see through the grate at the back of the freezer. This really great technician named Tracy, made a special trip to the parts store to get the circuit board and came back within a couple hours, bringing with him a steamer. He removed the back panel inside the freezer section (the coils are behind there) and used the steamer to melt the rest of the ice before he left.
Tracey, who works for a local appliance repair company, told me that about 4 years ago, Maytag started making their fridges with built-in surge protection, so the circuit boards apparently don't get fried on the newer models as they do on my 6 yr old model. He recommended that we put plug the fridge into a heavy-duty surge protector - which we are definitely going to do.
TR
Feb 13, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Frigidaire FRS266ZDSB Side by Side Refrigerator Logo
357 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
