Question about HP OfficeJet 6210 All-In-One InkJet Printer
Carriage jam print cartridge stalled HP 6210 Officejet. It started all of a sudden and I can't fix it
    Guru:
  • HP Master
  • 2,178 Answers
Press "ON" till green lite appears. The display will indicate "Initializing..." and then lift upper half of the printer to access cartridges. Cartridges should move all the way to the right. If they don't, inspect the carriage belt for any obstructions.
Posted on Nov 06, 2010
Carriage jam when there isn't one
the carriage is not the CARTRIDGE ,
the carriage(the cartridge holder) stall at somewhere in the print area
i hope my answer is useful?
Dec 11, 2012 | HP OfficeJet 6210 All-In-One InkJet...
HP OJ 5110 the print cartridge carriage is stalled problem open door, clear carriage jam, then press enter. plz problem describe in hindi
door close ka sensor thik se kam nahi kar rha hai. ho sakta hai ki paper jam hoa hai. saaf karo, cartridge fir se nekal kar install karo. print cartridge carriage ke rod par thora sa tel lagao
Dec 13, 2010 | HP OfficeJet 5110 All-In-One InkJet...
Hp C4280 printer says incompatible print cartridges wont print! 2 new cartridges installed
door open,
clear carriage jam, and then press enter.
problem solution describe in hindi
Hp officejet 6210 all in one, carriage jam
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 07, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Paper Jammed. Have appeared to remove all paper. But I keep getting "Carriage Jam, open door, clear carriage jam then pres OK" message. Message on my computer screen says "The print cartridge carriage is...
HP support has extensive documentation for both paper and carriage jams for your model:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00304007&lc=en&dlc=en&cc=us&lang=en&product=391182
I hope this helps!
Dec 10, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Carriage jam
change the carrage block.this error is comin because of faulty carrage cable
Aug 08, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Carriage Jam Error display on the LCD!
open the lid ,you will see the cartridge track(steel bar) look both end of the track you will find something stuck over there most likely paper chip
Dec 05, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Stalled printer cartridges
Sounds like an issue with the print carriage. When it's out of alignment and tries to print, it can make awful noises. HP.com has a web page that describes a number of troubleshooting steps when you have print carriage issues:
Carriage Jam Errors
There's also a related web page having to do with the noise coming from the printer:
Noisy Print Carriage
Hope this helps. Good luck.
Oct 07, 2008 | HP OfficeJet 4215 All-In-One InkJet...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
232 people viewed this question
Seeker5211
Seeker5211
