Question about Vizio L37 Television
Picture starts flashing after tv is on for a few minutes.
  • 2 more comments
  • Al Minter Nov 06, 2010
    It is an intermittent problem and does not do it when we use the blu ray. But I do have a Roku box connected for Netflix movies and it does it with that. I should say its more of a rapid blinking than flashing.
    I double checked the blu ray and it is also doing it when we watch a dvd.
    thanks i will get back with you
    ok i went to menu and turned the backlight to 0. If you get up close to the tv you can see it blinking but from a distance you can't tell it. does that sound like the backlight board?
  • 10,515 Answers
To start with, kindly provide few more details ;-
1. Is it an intermittent or continuous problem?
2. Use DVD player or Blu Ray player and see, if the picture would still flash?
Let me know,so that we could proceed.
Thanks!!
Posted on Nov 06, 2010
  • 1 more comment
  • taran_2005
    taran_2005 Nov 06, 2010
    Thanks for your response!!
    If the Blu Ray works fine, this is almost confirm that there is nothing wrong with TV. It seems to be an issue with box.You could try to unplugging the connections and then replugging it after few minutes. Could you also try moving the cable from the box to a different input on the TV? don't think this will matter, but it is something to try. It sounds like a problem with the box or system.
    Let me know,if needed further assistance.
    Hope i helped you.
    Thanks for using ' Fixya ' and have a nice day!!
  • taran_2005
    If it flashes during the Blu Ray or DVD player, this changes the complete solution. This is more of a TV problem.First make sure to hit the menu button on the TV's remote and if nothing
    is there then friend while the set is on turn a bright flashlight on
    and shine at angle into the set push the TV menu button if you can see a
    image then your backlight is not working. You can also check the
    transformers they are close to were the wires plug into the panel, make
    sure all transformers read the same amount of resistance if not you have
    found a bad one. Now you will have to check to see if the power supply
    is sending 24v to the backlight, if not the power supply is bad. Cost
    backlights around $150 and power supplies around $100.
    There could be few more probabilities that we might need to inspect.
    Check and let me know,so that we could proceed.
    Hope i helped you.
  • taran_2005
    taran_2005 Nov 07, 2010
    To provide more details, this is not 100% foolproof. As i am not there, so wouldn't be able to able to exactly judge whether you are looking at the correct angle or how it was done. But, anyways the TV has to be repaired. If you have electronics experience and multimeter, i could provide few pointers that would help you ti fix it yourself, not sure whether you wanted to fix it it yourself or not....
    Hope i helped you.
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
caypianan@yahoo.com
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
Picture jumps after a few hours turned on
I have a 3 yr old 55 inch mitsubishi TV and when I turn it on the green light starts flashing and I must reset the TV about four times before it finally comes on has anyone had this problem if so what solution did you have?
Jul 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Picture on my TV starts to flash after a few minutes of use
This problem is common in Samsung projection TVs. The DMD board is going bad.
Mar 21, 2008 | Samsung HL-R6167W 61" HDTV
Flashing picture screen on Sony KP_53HS10
tap around on the circuit boards in the rear of the television. narrowed it down to the Comb Filter circuit board. It is the smallest upright circuit board behind where you plug in all your connectors. pulled it out cleaned it off, reinserted it
Nov 19, 2007 | Sony KP-53HS10 TV
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
Blinking picture until warmup
On Sony TV's they monitor the current drain on all three electron guns Red Green and Blue. Until all are somewhat equal it will keep the CRT blank. As the set ages it means that it might flash a few times until the cathodes are good and warmed up.
Jan 28, 2007 | Sony KV-32V36 32" TV
Vizio L37 Television Logo
Top Vizio Televison & Video Experts
Steve Allison
Steve Allison
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
