We have a enders colsman ag brauck 1 patio heater. the model is a cosy commercial d-58791 werdohl. the problem we are having is when we agnite it, it will light but as soon as you let go of the regulator knob the flame goes out.
Therinnaiguy
  • 1420 Answers
SOURCE: Coleman patio heater 5040A770
These heaters are not designed to be operated below 40 degrees F. If the heater is used below 40 and if you have a gas tank containing less than 25%, the unit will not operate for long and will start going out. If the heater all of a sudden goes out without showing any flickering or pulsations, you have a bad gas valve, there is no thermocouple on this model. Fill your tank and try the heater again. If it continues, give Coleman a call at 800-835-3278.
Posted on Nov 15, 2007
hotuna
  • 288 Answers
SOURCE: windchaser patio heater
You have to hold the button down for 30 seconds at least before turning the knob to ON. If you are doing this and it still goes out after you let up on the knob, then it needs a new flame sensor, or thermocouple. Same thing different names.
Posted on Mar 06, 2008
Buffalo12980
  • 625 Answers
SOURCE: Kirkland heaters - outdoor patio
get a new thermocouple
Posted on May 27, 2008
SOURCE: natural gas patio heater
make sure there is no dust dirt spider webs in the pilot hood if u have a nice blue flame coming from the pilot and u held the pilot knob down for at least 30 sec
and it still doesn't work then u have a bad THERMOCOUPLE
Posted on Oct 08, 2008
  • 121 Answers
SOURCE: my ventless gas heater has
This sounds like your gas valve is weak. An orange flame has to much gas and not enough air mixture. Have you trie to ajust the air mixture. If it won't ajust then you will need to replace the valve.
I hope this helps.
Posted on Oct 24, 2008
Where can I get a replacement thermocouple for my Enders Cosy Polo patio heater
Thermocouples are pretty universal. I would remove it and take it to any parts house to match up the length.
Aug 19, 2017 | Heating & Cooling
How to remove maxi cosi cover
It is very confusing but the bit you pull to tighten the straps is on a held on under neath you just follow it round & it should just un hook from underneath the front of the seat.
Gazebo, Patio Heaters,Heated Towel Rails
May 10, 2012 | Maxi-Cosi Baby Gear
My gas endless summer heater shuts the flame off abruptly after 5 minutes or so. why??
The first consumable part to fail on a gas patio heater is the thermcouple, these can last anywhere between 1 year to 6 years. When faulty it will cause the heater to shut off when turned on at pilot. Found this site very useful patio heater problem solving.
Nov 18, 2011 | Endless Summer 233010 Natural Gas...
MY ENDERS PATIO HEATER i CAN GET TO PILOT ON, BUT WHEN i TURN THE VALVE TO TURN IT ON, IT DOESN'T TURN ON
Most likely cause will be a worn thermocouple, these can last from 1 year up to 5 years but will at some point need replacing. Always check for leaks when making any repairs, found this site very helpful patio heater problem solving.
Nov 16, 2011 | Enders Colsman Enders 90 Inch Black Patio...
The pilot goes on but when i un-depress the gas knob to turn the burners on it goes out..hence no flame. what's teh problem?
Generally this is caused bu a worn thermocouple, these last form 2 years up to 6 years but will wear out at some point. For help see patio heater problem solving, these patio heater specialist have helped me in the past.
Mar 03, 2011 | Endless Summer Blue Rhino 235000...
Im not getting enough fuel pressure to create a decent flame, everything lights as it should and stays lit but its not letting enough pressure out. Could it be the pressure regulator on the line thats...
Check what type of fuel, if using butane on cold days it will stuggle to stay alight, always use propane on outdoor patio heaters, propane will work in vvery low temperatures. If using propane check for leaks, do a leakage test, found this patio heater specialist site very useful.
Feb 21, 2011 | Endless Summer Blue Rhino 235000...
I have an RTA International Patio Heater, Model 385.001 with a clogged pilot light valve. I need a way to fix the problem or a new replacement part. I have a commercial gas heating repair company working...
Gas Valves are not meant to be repaired only replaced. So I would have them replace the part and have them warranty there work. If the heater is very old and the replacement part is going to be half the cost of a new one You might want to put that Money on a new one and get a New manufactures warranty in the deal. Just another point of view....... Hope this helps
Feb 07, 2011 | Rta International Patio Heater
Whats the order of the sprk plugs of a 1999 dakota
if you have a 6 cyclender the firing order is 165432. if you have a 8 cyc then it is 18436572. hope this helps you have a good day.
Dec 13, 2010 | Distributoys Enders 90 Inch Patio Heater...
Heating & Cooling Logo
156 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
