Question about Ionic Pro Air Purifiers
Cleaned both the metal blades light because green light went red however, red light was still on so had to clean fuzzy long filter. Red light is still on. What can I do? Still no green light? Have I lost the electro static part of the cleaning i did make sure it was dry putting it back after cleaning. Thanks Sheryl Pitocchi
  • 6,826 Answers
According to the website for the Ionic Pro Air Purifiers, an extra set of collection blades may be ordered so that you can rotate the wet one with a dry one.
Did you wait 24 hours after cleaning it in warm sudsy water?
Good luck on getting your Ionic Pro Air Purifier to work with the newly cleaned blades.
DEEP CLEANING
Noisy functioning (audible loud buzzing sound) is a sign that your Ionic
Pro Turbo® ionic air purifier is overdue for a complete clean-up of the
collection blades and the internal ionizing wires. The internal ionizing
wires must be kept clean to ensure silent and normal operation.
To Deep Clean:
1. Before beginning, make sure you have read all of the safety
precautions and cleaning instructions located in the "SAFETY
INSTRUCTION", "IMPORTANT WARNINGS", and "CLEANING &
MAINTENANCE" sections of this owner's manual.
2. First, turn OFF and unplug your Ionic Pro Turbo® ionic air purifier.
3. Let it rest for a minute before sliding out the collection blades as
described in the "To Clean the Collection Blades" section of
this manual.
4. Use a cloth and warm, sudsy water to wipe away dirt particles
on the blades' surfaces and edges.
5. Rinse and let the blades dry thoroughly for 24 hours before
re-inserting them into your Ionic Pro Turbo® ionic air purifier.
If desired, you can purchase a second set of collection blades to
use while the original blades are drying to allow for virtually
uninterrupted air purification. (See the "ORDERING EXTRA
COLLECTION BLADES" section of this owner's manual for details.)
Cleaning External Surfaces
Over time, some particles and dust may accumulate on the external
surfaces of your Ionic Pro Turbo® ionic air purifier.
If this happens:
1. Turn off and unplug the unit.
2. Mix one ounce of soap or detergent with five ounces of water
and apply sparingly with a moist sponge to wipe the outer
case surfaces.
3. Do not allow any water to slip into the internal parts of the Ionic
Pro® Turbo ionic air purifier as this could damage its functioning and
may result in injury to you.
4. Allow the unit to dry for at least 24 hours before resuming use.
Posted on Nov 06, 2010
I have cleaned the machine and the red override light is still on
Are you sure the filter cartridges are in correctly.
Those can be tricky if they are not in exactly the same way. The metal tabs have to line up. Also, isn't there a reset button on those?
Hope that helps,
Matt
Sep 19, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Have cleaned unit and will not work. The clean
I just fixed my proffessotional ionic. Im not sure what I did. lol. I took the screws out of the bottom, didnt see anything wrong, tho there is a piece of plastic in there, I dont know what it is. I cleaned the 2 center long metal like things, cleaned the contacts that the metal blades touch. cleaned the wires with alcohol and qtips, put it all back together, and it came on!!!!!!
Apr 20, 2009 | Sharper Image Ionic Breeze 3.0 Air...
The red cleaning light is staying on after I have cleaned it several times
I have had to hit the power button several times in a row to get the red cleaning light off till the other light went blue. Thats what I did, Did you just clean the blades? there is another part that cleans the wires too, Its like a plunger.
Dec 07, 2008 | Ionic Pro CA200 Air Purifier
"clean" light
Sharper Image was giving customers a small rebate for the product since it was proven to be ineffective for cleaning the air by Consumer Reports as well data by the EPA.
This has caused a mess for Sharper Image that they went into bankruptcy as a result of it. The Consumer Products Safety Commission is going to be making a decision on ionizers at the end of year since there are hazards in the air from using the devices. It could be that ionizers are no longer sold in the US next year.
The industry should have been regulated and unfortunately the government never did anything about it until Sharper Image and Consumer Reports went to court on it.
Jul 31, 2008 | Sharper Image Professional Plus Ionic...
RED CLEAN LIGHT
After cleaning the unit, blue light turns on momentarily then red cleaning light comes back on. Have cleaned and dried unit including the contacts on the end (cleaned with alcohol). Sounds like a common problem, any solution?
Bob
Jun 17, 2008 | Ionic Pro 901P2RIP04 Air Purifier
Red light won't go off
To RESET the Electronic Filter Check:
When the filter check light remains on,it is time to check/clean the HEPA-Type
filters and reset the filter check,if needed. With the unit powered on,insert the tip of a ball-point pen or
paperclip into the hole next to the LED filter check light and hold for approximately 5 seconds until the
light turns off (Fig 5). Depending upon your individual usage (environment and hours used),you may need
to check and clean the filters more or less frequently. If the HEPA-Type filters are cleaned before the filter
check light turns on,the filter check should be reset at the same time.
These cleaning intervals are intended as guidelines only. Performance of any filter media is dependent
upon the concentration of contaminates going through the system. High concentrations of contaminates
such as dust,pet dander and smoking will reduce the useful performance of the filter.
NOTE:The HEPA-Type filters are not washable.
Fig.5
May 24, 2008 | Honeywell HHT-090 Air Purifier
Clean Filter Red light
I cleaned the filters as well earlier and the red filter light still blincked to clean the filters. Then I pushed the power button for about 10 seconds continously and then turned it on and the light turned off.
May 22, 2008 | Brookstone Pure-Ion UV Air Purifier
Ionic breeze quadra s 1837
I had a problem with my Ionic Breeze Quadra. Green light would only blink for a second then the red light stayed on. I cleaned unit very good but problem came right back. I blew out the breeze with an air compressor. Not much came out, but now I am green and back in action. I used about 75 psi to clean out.
Mar 23, 2008 | Sharper Image Ionic Breeze® Quadra® Air...
Ionic pro won't turn on
Solution, perhaps...
All electrical contacts can get a film on them. Try cleaning the contacts (at the bottom of the blade unit; you should see the three with the blades out) with an alcohol swab (make sure the contacts are dry before reassembly in this case) or a pencil eraser (vacuum the debris out before attempting to start it again).
If those contacts don't make up properly, the unit will think it needs cleaning, even though it doesn't.
Mar 27, 2007 | Ionic Pro 901P2RIP04 Air Purifier
Air Purifiers Logo
740 people viewed this question
Top Ionic Pro Air Purifiers Experts
Paul Cox
Level 1 Expert
Shehu Pro
Shehu Pro
Thomas Perkins
Thomas Perkins
Are you an Ionic Pro Air Purifier Expert? Answer questions, earn points and help others
