Question about Whirlpool Refrigerators
I boughtan old camper with a consulcamping made in brazil, it is electric 115 and proprane. My question is The electric plug is not made for the U.S. Can I cut the old plug off and put on an American plug ?
Plugged camper into 120 volt everything works electrically except ceiling lights dont work
* Check 12 volt DC system (may be camper battery or car battery, though most only use the camper battery.)
* Camper may be using 12 volt DC lights so it can be turned on while your on the road or not hooked up to an 120 VAC or 240 VAC outlet.
* If you are using 120 VAC lights then check the neutral line (note; HIGH voltage here. Get help from an electrician or at least the RV park handyman.) The problem may be at the outlet (the RV site's problem) or more likely in your plug or cable (the big cord) as it does get abused, run over, kinked, etc. Need to have it checked by an electrician.
* Check the light bulbs; is it seated properly? Replace if burnt out. Have electrician test if there is power at the socket.
* Final; Be safe and have a qualified electrician service your camper.
Aloha, ukeboy57
May 11, 2018 | Electrical Supplies
Norcold fridge for my fifth wheel is not working leveled camper still nothing 115 v going to fridge on auto setting
How old?
Jan 03, 2013 | Refrigerators
My dewalt drill is 3pin 110v I need to step up to 240v
You cant convert to 240 the plug you have is a 30 amp 115 volt
Nov 07, 2012 | Drills
Was given a roof top ac for a popup camper need help
Make and model of unit should be on base of roof assy, please reply with that so we can be sure we have right wiring info for you. Although they are pretty common, let's be sure.
Jul 30, 2010 | Dometic Rooftop RV Air Conditioner
I've recently boughtan advent roma laptop. I know
download from this site the driver http://list.driverguide.com/list/company1838/index.html or from here select your type http://www.user-guides.co.uk/Advent/AdventCDDownloads.asp
Dec 29, 2009 | Computers & Internet
Where can I find a (1lb) proprane tank for portable
That should be a screw on type of propane cylinder, which should be readily available at stores like Wal-mart, Sears, Menards, Lowes, Home Depot, Etc.
Apr 19, 2009 | George Foreman GGR62 Grill
When I plug my camper into a house outlet the circuit breaker in the house blows.
the camper has a electrical fault some were ,
a wire could have been chewed though
or a water leak into the wiring points
Jul 05, 2008 | 1986 Volkswagen Wagon Camper
Refrigerators Logo
23 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
