Question about Acer TravelMate 252LMi Notebook
Can any type of memory upgrade be used for acer travelmate 252LMi??
  • 3 Answers
That depends on how much memory you have in the machine now.
The machine is typically sold with 512MB of memory. The motherboard in the machine has a maximum capacity of 2GB of memory.
It has two slots for memory and those slots can take DDR PC2700 with a maximum of 1GB per slot
Posted on Nov 06, 2010
I have acer travelmate 2355nxc with 40 gb hdd. want to know how to increase its speed and capacity.
Hi, how are you?
To upgrade your laptop, you will have to verify the capacity for upgrade of your laptop.
The Acer Travelmate comes with:
  • Intel Celeron-M 360 Processor 1.4GHz
  • 256MB DDR SDRAM -
  • 40GB Hard Drive
  • DVD/CD-RW Combo Drive - To read DVDs and CDs and write CDs
  • 15" XGA TFT Screen
  • Intel 852GM 64MB shared graphics
  • Operating System: Windows XP Home Edition
  • Based on this information, you can upgrade your memory depending on what type of memory your motherboard supports and how many empty slots for memory does your laptop have.
    The hard drive can be upgraded also depending on which hard drives does the BIOS will recognize.
    I will suggest to contact ACER and ask for the options and upgrades capacity.
    God Bless You!!!
    Hope it helps.
    Remember to rate solutions, to keep fixya.com working for you!!
    Feb 21, 2011 | Acer Computers & Internet
    Are there drivers for Acer TravelMate 252LMi LXT3206122 PC Notebook operating system windows 7 32bit
    64 Bit drivers will be marked as 64 bit, if it is not then we can assume that it will be 32 bit.
    Feb 02, 2011 | Computers & Internet
    Can i upgrade the hard disk of my old (2005) Acer travemate 2420 laptop?. form present 40 GB to a new 320 GB. Will it work? How much it coasts for the up gradation? also memory upgradation ..to 1 GB how...
    Price actually depends on where you make your purchases, do some research to locate the best price and yes you can upgrade your hard drive and memory, I am unsure of the type of memory your laptop needs however the hard drive you need is a 2.5 inch sata drive
    Mar 02, 2010 | Acer TravelMate 240 Notebook
    Acer Travelmate 270 Memory Upgrade
    Acer TravelMate 270 upgrades:
    The official upgrade slot is located on the bottom of the laptop and is easy to find. Just unscrew the small cover and there it is.
    The other slot requires you to unscrew the two screen bracket screws. Once you have done this, between ESC and F1, F4 and F5 and F12 and PrtSc there are small plastic rings. Put a biro nib into these and pull down. They will pop down. You can now remove the plastic cover.
    Unscrew the two screws marked "L9" on the bottom of the laptop which are located at the top of the memory cover. Now you can remove the keyboard. Underneath the keyboard is the second RAM slot. The SiS 650 chipset supports a max of 1GB per memory slot and since this laptop has two slots that means 2GB of RAM. I've used Kingston DDR400 PC 3200 SODIMMS.
    You can also upgrade the CPU - the fastest CPU available is the Pentium-M 2.6GHz. Nothing faster will work - trust me on this. It must be a Pentium 4 Northwood architecture CPU with a 400MHz FSB. Standard P4 Northwood CPUs with the metal shim won't fit - unless you know a way of removing the shim without destroying the CPU. Best to stick with a Pentium mobile (Pentium 4 M) chip. Look on Ebay for these.
    Of course the hard disk can also be upgraded - a 200GB 7200RPM 2.5" drive works a treat. Non SATA of course.
    You can add wireless and USB 2.0 using PCMCIA carbus cards. I use a StarTech 54mbps wireless card with the RAlink chipset and a NEC USB 2.0 card with 4 USB ports. Both cards fit in at the same time.
    The laptop absolutely flies with these upgrades.
    Mar 20, 2009 | Acer TravelMate 273XV PC Notebook
    Sir,i would like to upgrade my memory(256MB DDR2)for acer travelmate 4061nwlci pls inform if 1GB is compatible.pls help
    Your System memory is upgradeable:
    256 or 512 MB fitted as standard upgradeable to 1 GB of DDR2 533 memory, or 2 GB using two soDIMM modules.
    Regards,
    Mike.
    Feb 23, 2009 | Acer Computers & Internet
    Need to speed up my Acer Travelmate 2410
    According to your describe, your slow TravelMate laptop can caused by various hidden Windows errors. Those problems firstly cause your Acer slow, and then freeze up occasionally. One day crash all of a sudden! To quickly fix the problem, see resolution here: http://www.speedupacer.com/ Should help you out, good luck!
    Dec 29, 2008 | Acer TravelMate 2300 Notebook
    Looking for Internal Wireless card for Aver Travelmate 2301
    Upgrade your memory because 256 will not cut it! You have to share 64mb with your video and makes it smaller.
    DDR333 SDRAM standard, upgradeable to 2048 MB
    with dual soDIMM modules
    ctrl+shift+esc will show you
    Your expansion card type: Type I/II PC Card Slot
    Card Differences
    James Mac
    Aug 31, 2008 | Acer TravelMate 2300 Notebook
    MEMORY UPGRADE ON ACER TRAVELMATE 5720G
    Acer's support isn't the best. IMHO But go to their support site anyway and look up your laptops manual (there should be instructions on upgrading your RAM there). I did find that your machine will accept up to 4GB of RAM 2 X 2GB sticks. There should be a door or port (for easy user RAM upgrading) that is being overlooked, but again it is an Acer.
    Good luck.
    Feb 23, 2008 | Acer TravelMate 2300 Notebook
    Upgrade RAM
    hi, to upgrade your laptop's memory here's the info you need to order the new module or modules http://www.ec.kingston.com/ecom/configurator_new/modelsinfo.asp?id=1&SysID=25068&mfr=Acer&model=TravelMate+2410+Series+2413%2C+2418%2C+2419&root=&LinkBack=&Sys=25068-Acer-TravelMate+2410+Series+2413%2C+2418%2C+2419&distributor=0&submit1=Search regards
    Aug 18, 2007 | Acer TravelMate 2413LMi Notebook
    Acer TravelMate 252LMi Notebook Logo
    102 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Alun Cox
