Question about Samsung DVD-V4600 DVD Player/VCR
DVD stopped working and cannot do setup.
I was watching my new "Carrier" DVD I just got in the mail. Anyway, everything was fine for 25 minutes and then the frame freezed. I waited and then I pressed stop.
Then I pressed eject on the DVD player and ejected the dvd. I then loaded the dvd again and I waited. The lights when over the "Loading" over and over again and then the screen said " Cannot load disk or something wrong with disk, the disk cannot be played, check disk. Nothing was wrong with this disk, but just in case, I started loaded other disks. I received the same message for all the other disks.
I unplugged the t.v and the vcr/dvd, waited again and the replugged. I was able to get the setup to set the time, however, after that, the setup would not work. Now I have two problems. I cannot look at the dvds and I cannot program anything. I thought I had it for a moment, but then I tried it after I programmed the clock and I got: when I press the menu button on the remote control: "For the setup , Please wait then try again".
I can look at my VHS tapes, but I cannot record anything, because I cannot program anything and now I cannot look at my DVDs.
What happened?
Thanks
You probably need to reset your DVD/VCR/Combo. Go to www.samsung.com. Go to <Support>. In the search box, type in the model of your DVD/VCR/Combo. Or type in, >how to reset DVD/VCR/Combo<. Each model has different reset method and there are hundreds of models!
853. How To Reset Your Samsung DVD Player STEP 1
STEP 1. DVD Reset List
Samsung DVD players have a built-in reset procedure that resets the DVD player to the factory defaults. You can use the reset procedure to reset settings that don’t work with your TV or to resolve issues such as unit lock up. To run the reset procedure, you press one or more buttons on the front of the DVD player and hold them for at least fifteen seconds. The buttons your press depend on the model you have.
Important: For the reset procedure to work, you must press the buttons on the front of the player, not on the remote control for the player.
Below is a list of all Samsung DVD players and the buttons to press to run the reset procedure.
DVD511 - Stop / Play
DVD611 - Stop / Play
DVD709 - Stop / Play....
Many, many other models follow but cannot be listed here because of this site's text limitations.
Posted on Mar 22, 2010
  • wmclane Mar 22, 2010
    Hello, again. The Problem: "For the setup please wait then try again." If resetting using Solution 1 (3/22/10) does not enable you to use the Setup Menu, this a second Samsung Support recommendation:
    ----Start Samsung Support recommendation-----
    DVD players : I Cannot Get The Setup Menu From My DVD Player To Appear On My TV Screen.
    If your DVD
    player
    is connected with only the coaxial connection, you may not be able to access
    the Set Up menu. You must connect your DVD player using the RCA connection
    or any other available connection besides coaxial.
    After doing so,
    ensure that your TV is in the correct video source. If you still cannot
    see the menu, reset the unit. Click
    here
    to view how to reset the DVD player
    Note: If the
    word "menu" appears on the front panel of the DVD Player, but you
    cannot see the menu on the screen, the problem is within the connection
    or the video source on your television.
    -----end Samsung Support recommendation------
    The reset solution sounds easiest!
    Good luck.
Here's my setup: 46"Panasonic Viera
I'd call the cable company, it sounds like you have an issue with the cable box.
Feb 22, 2011 | Televison & Video
DVD stopped working
it seems the lens is bad
Feb 24, 2010 | Sony SLV-D950 DVD Player/VCR
Extreme heating bills
easy way to fine the high usage is to turn everything off and watch your meter and have someone start turning thing back on and watch for the most usage of power
Jan 25, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Furnace stopped working.
HI!!! Looks like your ignitor has stop working..change your glow ignitor and you should be fine..Good luck..
Jan 04, 2009 | Carrier Heating & Cooling
Stuck with progressive scan mode
My dear friend try with this,turn on the dvd take out the disc open the tray now push for 5 seconds the button stop.Good luck.
Jun 18, 2008 | Zenith XBV243 DVD Player/VCR
Onkyo TX-SR702 keeps going into speaker setup mode
Los amplificadores de audio del aparato estan a punto de danarse,checa las bocinas una por una a ver si no hay alguna mala.
Apr 14, 2008 | Onkyo TX-SR602 Receiver
Dub VHS to DVD
I am not sure why the DVD recorder is stopping after 25 mins of recording. However, once a disk is finalized all the remaining space is unrecordable. That is why your computer is showing the disk as full. The same applies when finalizing a CD. As for the first problem, check to see what record speed you are using. XP is 1 hr, SP 2hr and so on. But stopping after 25 minutes is weird. Even if you use a quick record button, (aka OTR) the recording is usually done in 30 minute increments. Try it again. If it still is only recording for 25 minutes, you may want to contact the manufacture's customer service or tech support. Hope it helps.
Mar 23, 2008 | Zenith XBR716
Screen without icons ?
I had this problem briefly. I had to restore my iphone back to factory settings, and the icons and everything came back. Now, it will also update to version 1.1.4.
Mar 09, 2008 | Apple iPhone Smartphone
Parental screen coming up on a DVD. Not able to watch DVD.
use password 3308 to change the parental control to 7, and the movie will run
Feb 14, 2008 | GoVideo DV2150 DVD Player/VCR
I just rented a new dvd from Blockbuster and I get a parental screen that comes up. I can't get past it and can't watch the movie. All my other movies work fine. Even the feature dvd that came with the...
You have the rating set on your DVD player to lower than the rating of the movie you are trying to watch.
Somewhere in your setup menu of your DVD player (press the "setup" button on the remote with disc stopped or no disc) you will find a place to set the parental lock. Either turn it off, if that is an option, or set it to the rating of the movie (or higher) to enable viewing.
Feb 14, 2008 | Televison & Video
Samsung DVD-V4600 DVD Player/VCR Logo
729 people viewed this question
Henry  Thomas
Henry Thomas
