Question about Volfenhag Car Audio & Video
Volfenhag zx-8400 amp and ZX-4712DVX subs
Hey everyone,
I'm really stumped here. I was under the influence that the zx-4712dvx subs would work best with a Volfenhag amp. So I went ahead and got a pair of subs and the zx-8400. Please bear in mind that I don't have much experience with car audio systems. I went by what I researched and hoped for the best. Here's the config: H2 Hummer, Stock Bose 6 cd changer which I didn't want to replace, no auxilary outs so they spliced off of the speakers and decent sized "enclosed" box with several round vent holes.
After the installation, 3 techs spents close to an hour each trying to tune the system but without any luck to get a decent sound of the system. The sound comes out extremely muffled and besides that, the bass is controlled from the remote knob (not the radio where you would turn the volume up and the bass would turn up as well!!!!!). Now that seems extremely odd to me, but they insisted that this was the only way for this type of a system to work - a german thing they proposed - which is complete B.S. if you ask me.
Now could someone PLEASE help me out here. I'm starting to assume that they have no clue as to what they're doing although they were highly recommended!
  • 1 more comment
  • Sam S.
    Sam S. Jun 15, 2008
    Come on people.. someone suggest something!
  • Sam S.
    Sam S. Jun 17, 2008
    I'll go back to those retarded installers and see what they come up with. Thanks a bunch for your suggestions.. I'll keep you posted.
  • Tygh Duval
    Tygh Duval May 11, 2010
    I'll do what I can to help! First, a few more details:
    1. Do you know the internal volume of the enclosed box they are installed in?
    2. The Bose 6 CD changer is the in-dash head unit, yes?
    3. How many speaker outputs does the Bose unit have?
    4. When you say they "spliced off the speakers" from the Bose, did they connect the speaker output from the Bose to the high-level input of the amp? If so, do you know what speaker outputs were used to connect to the amp?
    5. Do you know if the dual voice coils of the subs were wired in parallel (I hope so!)?
    Really, there are two issues. Why you can't control the volume of the subs via the head unit volume control and then why they aren't hitting like you were hoping. They may be related. Keep in mind that many times, depending on the vehicle, the box, and the type of music, a sealed box may work better than a ported or bandpass box.
  • 58 Answers
U JUST NEED 2 REAJUST UR AMP
Posted on Mar 20, 2009
  • 29 Answers
Well, you should tell them they have no idea what they are doing, you should have them re do it with a seperate amp that is DESIGNED for a bass and then it will work fine :)
Posted on Jun 18, 2008
  • 3 Answers
First of what you have should work great together....now the next thing is: does the bose system carry powered speakers if so the spliced speaker wires should be put onto a converter(a small box with RCA outputs) then you should make sure the levels in the little box is not set to full but 75%, if set to full you can be looking at distortion. Then they should set the amps to full range and see what you get.........oh and by the way you don't have to use that little controller(with the telephone wire) for the bass. You can control the bass with the frequency controllers on the amp or your head unit. And it's not a german thing trust me they come with nearly all amps now. These guys are full of ****. If you don't get the punch you want they should try bridging the amp for more of a punchy sound. Oh and you can use that decent sized box with the vent holes......that should work fine.
Posted on Jun 17, 2008
Power to amp but no light happened when my battery went dead replaced
the power amp has a short in the unit and it drain everything out of the battery, that why the battery is dead. it is really possible that a capacitor is open or shorting out cause the unit to drain the battery.
Mar 26, 2014 | Volfenhag ZX-8400 Car Audio Amplifier
Not working
sure it is not your amp?? if so these are pretty cheap subs to just buy new.
Apr 21, 2010 | Volfenhag ZX-4710 Car Subwoofer
Zx-8100 amplifier is red lighting.
try wiring them differently. here is a link for u to go to http://www.crutchfield.com/learn/learningcenter/car/subwoofers_wiring.html . once there find your amp configuration (ie. mono, or 2 channel) then down to the type of subs an how many subs ( ie. 2 dvc (dual voice coil) 4 ohm subs) an that will show u how the subs should be wired and wired to the amp.
Mar 21, 2010 | Volfenhag ZX-8100 Car Audio Amplifier
I have a volfenhag zx-7170 amp with 2 chanels burnt out can i get this rebuilt to higher wattage specs and if so where can this be done
Anythings possible but would not justify the cost of the upgrade. What be cheaper to get a new one with more watts.. No one really upgrades amps as the cost of new ones are so affordable.
Nov 04, 2009 | Volfenhag ZX-7170 Car Audio Amplifier
I have a volfenhag zx-8400 and it just geos into protection mode
The most likely problem would be a blown fuse. I would replace all of the fuses.
Oct 04, 2009 | Volfenhag ZX-8400 Car Audio Amplifier
I have a volfenhag zx-8400 amp. i dont have a manual. whats the proper way of conecting amp? its mounted on my speaker box, which is ported, 12' volfenhag 2500 watts. on the side of amp it had voltage...
The voltage prolly says like 100Mv-2v, it doesn't really matter, just know that that the lower you turn it the harder it bangs. The X-over depends on where your box is tuned, crank the knob down too about 40htz and you'll prolly be good, just don't turn it lower than your box's tuned frequency. And your rca's go to line input. And there shouldn't be a problem with mounting your amp vertically, you prolly just had a bad connection. Hope this helps if you have more questions please ask...
Sep 21, 2009 | Volfenhag ZX-8400 Car Audio Amplifier
Need help please...
If you unplugged the fuses, the amp won't come on at all. I'd say its a blown transistor, you can test this by opening up the amp and using a multimeter to check resistance on the transistors.
Aug 03, 2009 | Volfenhag ZX-8400 Car Audio Amplifier
Zx-8400 amp too much for zx-4812?
The amp and sub combo should work fine the subs can really take a crapload of power-i have a neighbor thats running 1200 watts rms to each sub in his caddy and OMG- its sick. Your amp should be pushing around 800 watts rms(continous) to the sub which should do very well-my concern with your setup is that the sub is designed for a vented box- you can use any box u want but im just suggesting that you use a good solid vented box with these subs- my other concern with your setup is that having only the single sub if its a dual coil 4ohm + 4ohm coils then you might run into trouble if you dont have it set up right-by that meaning to get all the power handling capability of the sub you would want to use both of the coils right? well to do that you have to either wire the coils in series or wire the coils in parallel right? In series the coils will yield an 8 ohm load to the amp and youll only get about 400 watts from the amp bridged into that 8 ohm load- on the other side of that if you wire the coils in parallel then the cols yield a 2 ohm load and that could cause the amplifier to become unstable and fry its little guts. All of this is assuming that the amp is made to run bridged at 4 ohms- if it is 2 ohm stable in bridged mode than you have nothing to worry about. Now the popping noise- that sounds like its coming from the amp somehow and just feeding through to the sub-like you ive never heard a sub popping unless its bottoming out and you say its not so its gotta be the amp id say-if it were me id check all power connections especially the ground for the amp . It could be that on the heavy bass notes that your amp is not getting enough juice -throw a 3.5 farad capacitor on the power line and see if that helps your system out-
May 22, 2009 | Volfenhag ZX-4812 Car Subwoofer
Volfenhag ZX-7160 Car Audio Amplifier owners manual to adjust the frequency also wiring diagram diamartn64@gmail.com
its very easy to hook it up. your best bet is to join www.carstereo and ask your question there.but it is easy to set and hook up amp if you really need help email me
Mar 03, 2009 | Volfenhag ZX-7160 Car Audio Amplifier
Car Audio & Video Logo
461 people viewed this question
Top Volfenhag Car Audio & Video Experts
Robert Rankin
hoyzee1
Are you a Volfenhag Car Audio and Video Expert? Answer questions, earn points and help others
