I have an older washer top load frigidaire gallaxy and water is spilling on floor and tub is spinning but water wont drain all the way
  • 1,531 Answers
You need to check the drain pump for anything that may be obstructing the flow of water.If the water is coming from the bottom of the tub the you mif=ght have a bad tub seal.
You can use a screwdriver and push the tabs in on the lid to lift up the lid and remove the two screws from the front panel on the bottom and remove the front panel. and check all the hoses from the tub and the drain pump.if there is still
Posted on Nov 06, 2010
I have an Amana washer model NAV3330EWW purchased in November 2004. The washer will not drain during any of the cycles, It apparently went through the entire wash without draining after the wash or...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 28, 2011 | Amana Washing Machines
I have a mo# FTF2140ES0 front loader washer that won't spin
check the pump for a blockage,if the water cantget out of the wash tub,the machine senses this and wont spin out the load,also make sure to check both sides of the pump from the tub to pump and pump to house drain sides
Mar 12, 2010 | Frigidaire GLTF2940ES Front Load Washer
I have a top load washer MWS939Z it gives big noisy while it spinning what would be problem can you please describe me thanks
its probably leaking some water through the tub seal. ( not enough to get on floor .) the tub seal and brg are failing . the noise is a ruff brg . if you let it set to long it will not spin / the brg will lock up .. this is a major repair and if older you may want to repl instead of repair .. est ? probably 225. to 300 . depending on labor rates in our area . **** hope this help's / feed back pls .
Dec 23, 2009 | Frigidaire MWS939Z Top Load Washer
Frigidaire Front Load washer Model FWT645RHS1 wont fill with Water
The drain hose might be too low. Make sure the drain hose is at least three feet above the floor.
May 31, 2009 | Frigidaire Washing Machines
SPIN CYCLE WON'T DRAIN WATER FROM TUB IT RUNS ONTO MY FLOOR
Sounds like you have a bad water pump. Remove the hose going into the water pump and coming out of the pump and the pump should pull directly off the shaft check to make sure it spins freely.
May 01, 2009 | Frigidaire GLWS1349A Top Load Washer
Water level high when spin/drain cycle begins.
The water level is higher when in the rinse mode; but it should never leak. Examine the interior through the rear, there should be a loose hose somewhere. Or at the filter area. Plug off the mains caution.
Feb 28, 2009 | Kenmore 22932 Top Load Washer
Fridgidaire Washer wont drain
If lid lock is bad the tub will not spin properly. Unplug, remove front and look at the lid lock closely. Let me know, Thanks, Sea Breeze
Jan 08, 2009 | Frigidaire GLWS1233A Top Load Washer
Frigidaire washing machine top load. troubleshoot
There are levelers at the corners of the unit for levelng - tubs have springs attached to them for righting the tub while working (spinning, agitating) - also if the clothes are evenly distrbuted in tub it will wobble badly during operation.
Leaking is usually from the drain pump especially from the point whwere the hose is attached to the pump
Regards
Sep 20, 2008 | Frigidaire CWS3600AS Top Load Washer
Washer repair
The transmission might have locked up causing the motor to overheat.
Nov 10, 2007 | Frigidaire FWS833A Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
paul
paul
