Question about Kenmore 500 6952 Dryer
After 500 kenmore dryer is done drying the dryer won't shut off
  • 903 Answers
The push-start switch in the dryer is probably bad. The contacts inside the switch get warped over time, causing the dryer to think you pressed Start again after it finishes a cycle. Replacing that switch should solve your problem. You can find the switch online at PartSelect.com if you know take the rear panel off the dryer and see what the switch looks like.
http://www.partselect.com/PartSearchWizard.aspx?Appliance=Dryer&Brand=Kenmore&PartType=Switch
Posted on Feb 20, 2011
Kenmore 500 dryer used to dry a full load of cloths in 1 regular cycle of about 40 to 50 minutes. Now the same cloths are taking nearly 2 hours to dry.
I think I would check and see if the dryer vent tube is clogged or nearly clogged. It sounds to me like it is. Try this first, if its not, I will continue to try and solve this with you.
Sep 06, 2015 | Kenmore 500 7.0 cu. ft. Electric Dryer -...
I have a Kenmore 500 model # 110.68532700, sometimes it would work and run for about ten minutes then shut off, after about 10-15 mins you could run it again, sometime it would run fine tell the clothes...
see this possibles causes:
see the diagram attached
1) Test the main start switch for open 2) Test the switch door for open 3) Test any coonector for loose wires, or broken wires, or burn .4) Motor defective repair
Jun 09, 2012 | Kenmore 500 6952 Dryer
Gas dryer heat shuts down won't dry cothes
This sounds like the heat sensore that goes to the gas valve. It is there fore shutting down the gas.
Jun 15, 2011 | Kenmore Dryers
Kenmore Dryer Model 66801692
at leas 15 yrs old??? think it's done its time, its a great machine andwould reccomend replacing with a whirlpool/kenmore unit again.no tworth servicing in my opinion, average call here in new york 150-225, anbd those are for simple issues. id rather put money into new unit! bit be sure to check your venting id say 85% of dryers taking too long to dry are vent related issues
Nov 13, 2008 | Kenmore 62872 Electric Dryer
Kenmore He5 Dryer
try replacing the door strikes and catches part # 279570...possible door hinge issue but less likely
Aug 20, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer won;t work
Remove the top cover and take a hair-dryer to the PC boards on the back of the main control panel.. (3 screws take the top cover off from the back) Mine has done it a total of 5 times now.. what it needs is all new buttons installed.. or a new control panel if this works..
Feb 22, 2008 | Kenmore 82822 Electric Dryer
Kenmore 500 6952 Dryer Logo
431 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
