Question about LG 22.4 Cu. Ft. Bottom-Mount Refrigerator - Smooth Black
I have a LBC22518ST refrig. The prob is that the seal on the freezer door has stopped being very effective. When closing the top portion, it causes the freezer door to lose its seal and open open slightly. I hadn't noticed until I found freezer items unfrozen. The door doesn't pop open enough to cause the alarm to sound. I bought it 2 years ago.
4 Suggested Answers
  • 489 Answers
SOURCE: Freezer door
You may have a door alignment problem and requires a qualified LG technician to find the problem.
Posted on Jun 11, 2008
  • 210 Answers
SOURCE: Freezer Door Popping Open
Look at the bottom of the freezer door, there is a little plastic stopper there. It may be worn out or broken. When you close the door this is what holds it there. Start there first.
Sgt 48
Posted on Jun 17, 2008
SOURCE: Our French Door model after almost 2 yrs pops open
We solved this problem by replacing the plastic parts on the top & bottom of the door that 'latch' the door closed.
On the top of each door is a white plastic 'cam' that latches into a receiver at the center point of the refrigerator chamber. One of mine was broken.
Additionally, on the bottom edge of each door is a white plastic hook-shaped 'stopper' that provides spring tension. I replaced both of those and now all is happy.
Got the parts from RepairClinic.com
Item #: 1266811
Description: Door hinge cam (left)
Price: $2.40
Item #: 1266810
Description: Door hinge cam (right)
Price: $2.40
Item #: 1267543
Description: Stopper,door
Price: $2.40
Posted on Oct 31, 2009
Refrigerator runs continuously
How well are the door seals and the door to the ice dispenser is it closing all the way. Condenser clean?
APPLIANCE 911
Apr 14, 2016 | Frigidaire Refrigerators
Refrig door does not seal
First off, make sure nothing is stopping the door from closing completely. If the door is closing properly, then using a hair dryer, heat the gasket until soft and pliable. You can carefully stretch it towards the cabinet. There is a magnet in the gasket all the way around on the mating portion. While the gasket is soft, the magnet will pull the gasket until contact is made with the cabinet. Once a good seal has been accomplished, allow to door to remain closed for 30 minutes. The seal will cool down, and the new shape will be maintained. After that, close the door on a dollar bill. Gently tug the portion of the bill on the outside of the door from one corner to the other. There should be some resistance to your pulling. If the bill feels loose, apply more heat to the gasket in that area to improve the seal. DO NOT HOLD THE HAIR DRYER IN ONE PLACE TOO LONG AS IT WILL DAMAGE THE GASKET, AS WELL AS THE PLASTIC LINER.
May 08, 2014 | Refrigerators
I have an LG refrig french door model LFX 31925ST/00. Purchased less than 2 months ago. The top plastic freezer door continues to get an ice build up on the front of the drawer only. Is this normal? ...
It sounds like a loose or bad seal on the top area of the freezer door. Use the old dollar bill test to see how good the seal is. Hold a dollar bill up to the seal and close the door. there should be some resistance. compare the resistance between the top and bottom of the door.
Nov 06, 2017 | LG Refrigerators
Refrigator with a top freezer freezes up about every 4 weeks
Check the door and seals, does it close and seal properly.
If the seals are letting in warm air, the fridge goes into overtime, hence freezing up.
Its also worth checking that the fridge isn't on too higher setting.
May 10, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Refrigerator is staying at 50 degrees, will not get any cooler
May be your computer board, not turning on the defrost heaters in the freezer section. The freezer will eventually get warm too. Are you getting frost build-up on the rear wall of the freezer? If you are, you can temporarily solve the problem by turning off the whole refrige for a day and open up the freezer door- put towels on the floor under the freezer doors. Then turn it back on - mine worked fine again. I am currently waiting for a computer board replacement. It is behind the metal plate on the back (outside) of the cabinet. Good luck.
Sep 28, 2009 | GE Profile PSW26P Stainless Steel Side by...
I have a top freezer. Whenever the refrigerator door is closed, the freezer door pops open. There appears to be a good seal around each door... How do I keep the freezer door from poping open, when...
Replace the seals. It may appear to be in good shape but what is happening is the compressed air from closing the refer door is going up and releasing the seal on the freezer I would replace the freezer seal first as that should solve your problem.
Thx
Deathstalker
Aug 22, 2009 | GE PTS22LHR Top Freezer Refrigerator
My self-defrost freezer (18.5 cu ft, 11 year old, refrig on bottom/freezer on top) has begun to frost up primarily around the door (inside). I have insured that nothing is close to the door to avoid the...
Test the gasket by closing the door on a dollar bill. If you can pull the dollar out easily then the gasket is not sealing. If the gasket is OK then the auto defrost function may be not operating. High humidity and opening the door frequently can also cause some frost build-up.
Aug 12, 2009 | Frigidaire 18 Cu. Ft. Bisque Top Freezer...
Freezer door pops open when fridge door is closed.
well u need to check the rubber of ur freezer ;s door .some damaging in the rubber is causing the problem.
May 26, 2009 | Amana ARSE66MB Side by Side Refrigerator
Kenmore Bottom Freezer
Look in the back of the freezer, there will probably be a metal panel with a plastic vent on top.
Look through the vents in the metal panel, and you should see the shiny metal fins of the evaporator. If the fins or the vents are plugged with frost, that is your problem. The freezer will stay cold because a small amount of cold air will be forced through the frost but that will not be enough to make it up to the refrigerator portion. You can defrost the unit by removing the metal panel and allowing the frost to melt. Careful use of a hairdryer can speed up this process. This will likely be a temporary fix. The root cause of excessive frost can be caused by a bad door seal or a defective defrost circuit.
First check that the door seal is good by closing the door on a dollar bill at several points around the door, both on the freezer and refidgerator door. If you can pull the bill out with no resistance, the door is not making a good seal. Inspect the seal and make sure there isn't anything stopping the door from closing such as food, or a shelf not pushed in all the way.
If the door seal is good, the defrost system is likely defective. The defrost system has three main parts, the defrost heater, thermostat, and timer. If either one of the parts fails, the freezer will plug up with frost every few weeks. If you can troubleshoot this by manually starting the defrost cycle. Let me know if you would like this procedure.
Dec 13, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Sub-zero 500 series refrigerator door wont stay closed
If Your Refrigerator's Freezer Door Pops Open When You Close the Fresh Food Door... If a 'top-freezer' refrigerator's freezer door pops open when the larger fresh food door's closed, it's actually a good thing. That tells us the seals are in great shape, sealing well.
Some freezer door 'pop' is unavoidable bc the bottom door's so much larger than the top one and the hydraulic effect of compressing all that air kicks in. The two compartments share the same air via a duct between them, and that compressed air rushes up into the freezer compartment and can 'pop' the door.
To improve the situation, apply a few drops of oil (sewing machine oil or 'three in one' - NOT WD-40) to each freezer door hinge pin. (Even better: if you can, pull the doors and coat the hinge pins with petroleum jelly). This will help the freezer door swing back closed by itself. The freezer door usually stays ajar because it's binding a bit, and that's usually caused by it's swinging 'dry', with no lubrication.
It’s also a good idea to ‘kick’ the habit of letting the refrig door close hard.
Sep 04, 2008 | Refrigerators
LG 22.4 Cu. Ft. Bottom-Mount Refrigerator - Smooth Black Logo
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
