Blue screen flashes up and computer will not load windows in any mode help
  • vkopsell Aug 03, 2008
    History on machine::: I have had problems with hardware in the past year namley the hard drive I had to replace it, that worked for 3 months. The next problem I had was blue screen again . I let a cowoker work with it he found a bad memeory stick I replaced both 512mb with kingston memory stick upgraded to 2gb.
    cowoker also removed mcafee software and instlled node 32 .very happy with the results computer was much faster and safer w/o macafee .Machine worked great for 2 months. Now I get beeping and blue screen .tried safe mode same results the last bluescreen was today(8/3/08) had STOP 0X0000008E and at the top of the page it had : PFN_LIST_CORRUPT. your scaring me!!!!
  • 106 Answers
There should be an error code similar to 0x0000007b or some similar number. See if you can get a glimpse at it and quote back here.
There could be one of many possible culprits. From memory, to harddrive, to cpu or motherboard. The error code will definitely help.
Posted on Jun 15, 2008
How do I fix
I see you chose Safe Mode.
Blue Screen Of Death
  • Unplug PC. Opening case. Remove all RAM. Use static precautions! Insert one DIMM and test. Does it load OK? Test one DIMM at time. One slot at a time. To eliminate possible bad RAM.
  • Re-install Windows. Clean install works best. All data will be lost.
  • Lastly you may have other hardware problems. If it does another blue screen after reloading windows, especially with a clean install.
Oct 04, 2012 | Computers & Internet
MSI N1996 motherboard with 640gig sata drive / sata DVD ROM / NVIDEA Graphics card G7500 - wont boot up windows 7 even though i install new sata drive and try new installation it wont boot up! Pre...
hi there.
this is all the info i can find.plus try the link at the bottom might help you out some more.
If your computer blue screens when you turn it on, then loading in safe mode could help you get into your computer to sort out the problem. To boot safe mode in Windows 8: Hold Shift and press F8 upon startup to open Recovery Mode. Select See Advanced Repair Options, press Troubleshoot and select Advanced Options.
How to fix the blue screen of ***** - Cheeky Munkey
getting blue screen error Google Search
Nov 17, 2017 | Intel Motherboard
Cannot start windows or launch startup repair. Loads windows icon then flashes blue screen then black screen with large cursor
It might be just a software related issue, i suggest you boot into safe mode(tap F8 repeatedly during POST), if you are able to access safe mode without any issue, you can perform a system restore. This will allow the computer go back in time when the issue is not yet present. Hope this helps.
Apr 14, 2011 | Toshiba Satellite L455DS5976 Notebook
I have a Dell Inspiron Mini, and everything was working fine until last Friday i tried turning it on and it as it loaded it went directly to a black screen with white letter and asked me how I wanted to...
Looks like your master boot record is corrupted or you have a bad hard drive. Without cd drive there is one option but it is not guarantied it will work. You can acctually make USB flash drive bootable but you need another computer with cd drive and an XP Operating System CD. You can google how to make usb flash drive bootable for XP and it will give you step by step instructions. Or you can borow an external cd drive or take it to pc repair store. Good luck.
Mar 17, 2011 | Dell Inspiron Mini 10 Notebook
When attempting to start my computer this morning it took me to the safe mode screen ("We apologize for the inconvenience but windows did not start successfully. A recent hardware or software change...
open your computer in a safe mode then save important files in pen drive or some removable drives....or scan it in safe mode with updated antivirus......or updade windows or repaire windows using installation process...........this will definatelly works..........
Nov 13, 2010 | Computers & Internet
When i go to start it up, it shows the Windows XP loading screen, then a black then blue screen flash for less than a 1/2 second.
It's called a BSOD which means blue screen of death. try to boot into safe mode by pressing F8 as soon as the computer starts hit it repeatedly, then try last known configuration that worked. If that doesn't work, reboot and try F8 again and go to safe mode, then do a system restore.
May 22, 2010 | Toshiba Satellite A15-S129 Notebook
PC monitor has blue USER MODE box that flashes and cannot get rid of it
The blue screen of death is incredibly frustrating. Windowsmag-glass_10x10.gif gives you an option called Safe Mode for whenever there is an internal Windows problem on your PC that needs to be resolved such as the blue screen of death or the display driver setting resolution is so low that you cannot navigate through Windows to alter the settings to a higher resolution. Safe mode allows the user to fix problems without these problems loading up.
  1. tep 1 Reboot your PC. If you can't restart normally by going to the start up menu, then hold in the power button for a few minutes. If you need to enter safe mode but can restart normally, do so.
  2. Step 2 After the hard drivemag-glass_10x10.gif mounts but BEFORE Windows starts to load, Press the F8 key repeatedly on your keyboard. If you do not get the menu with the safe mode option, then you did not begin tapping F8 soon enough. Try again.
  3. Step 3 There will be a menu that will appear. Select Safe Mode. Once you are in safe mode, you can fix what needs to be fixed without the problems loading up on your machine.
Nov 13, 2009 | LG Flatron L1715S 17" LCD Monitor
Can't get to login window
Blue screens are normally critical errors. If you have loaded any new hardware to your computer lately or some software packages you will need to uninstall them.
Try starting windows in safe mode by pressing F8 continuoulsy until you hear a beep. This will start the computer in safe mode and everything will look big on the screen, ignore that for now. While you are in safe mode uninstall anything that you have loaded prior to this error. Be it software or hardware.
If you have not loaded anything recently then try restoring your computer to an earlier time when you know that it was working with now problems.
Once safe mode boots go to Start>all programs>accessories>system tools>system restore and choose a date when you know that the computer was running okay. Once the restore has taken place the computer will reboot. If asked what mode you want to start in choose start windows normally.
Hopefully this will help you resolve your problem.
Nov 11, 2008 | IBM Computers & Internet
Computers & Internet Logo
144 people viewed this question
David Payne
David Payne
