Question about Vacuums
Manual not included in box for delta essentials mini air purifier, so how do I opperate it
Vacuum has power but wont run
From your question it sounds like the Rainbow will not run on high speed. Very good chance the Controller Asm 120v e2 Silver Gold is bad. Call us when you are able as we can replace at a discounted price if your machine meets the requirements. Contact Us
RainVac
Sep 07, 2015 | Rainbow E series Canister Wet/Dry Vacuum
Vacuum has power but wont run.
i have a feeling the motor brushes are worn and not making contact, (no electrical circuit through the main motor).
being as you didn't mention what make or model i'm unable to direct you to a site where you'll be able to purchase these motor brushes... happy hunting.
Nov 23, 2017 | Vacuums
Why my Honeywell air purified HHT-149 have no power
unplug and wait for 5 seconds, plug it back in again and hold the power button for 3 seconds.
Aug 07, 2014 | Honeywell UV HEPA Clean Antibacterial Air...
Honeywell air purifier won't turn on
Hello, this is Ava with Think Crucial.
You may check to make sure that the power cord is correctly connected to the outlet. Test the outlet is functioning properly using another appliance or lamp. Also, check the fuse or circuit breaker. The outlet may be overloaded if other appliances are also in use. Establish and correct the cause of the overload. If none of these works, then there is something wrong with your purifier unit and contact the store where you purchase it or Honeywell for replacement. It is advised not attempt to repair the unit yourself.
You can purchase a wide variety of high-quality Honeywell replacement parts for your Honeywell air purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=honeywell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Apr 23, 2014 | Honeywell UV HEPA Clean Antibacterial Air...
Need manual for delta ultrasonic cleaner.....not in box when purchased from aldi
Hi.
Here all the documentation available on the web. If this is not enough contact Aldi to get a replacement booklet:
Model: 334.150
Data Sheet
Catalog Page
Model: 334.D80H
Data Sheet
Model: 334.010
Catalog Page
Data Sheet
Model: 334.080
Data Sheet
Catalog Page
Jun 10, 2011 | Vacuums
How do I take apart the air purifier to clean it? I have a honeywell HTT-022 unit and it needs cleaning
Here is the owner's manual:
http://www.kaz-canada.com/kaz/support/manual/?ProductManualAction=renderProductManualById&ProductManualId=ee97a4e6784448b6f57acddb2f29a817
It says first to unplug the unit.
While pressing on the two notches along the front of the grille, pull the grille toward you and remove it.
Gently pull down on the top filter frame and pull forward.
Remove the protective wrap from the filter.
Place back into the air purifier housing and snap filter grille into place.
(This is verbatim from the instructions)
Feb 21, 2011 | Vacuums
I have a Delta microwave and grill Y-3 model We have lost the instructions on how to use it and cannot seem to find how I can download the instructions . PLease can you help.
Here is the manual for a Delta microwave and grill Y-3 You can go to this link to download it. Go to the site and you can read it there or Download the manual by clicking on it and doing a save as. Put it on your desktop so you can find it easier. Thank you.
Delta Microwave Y-3 Manual
Dec 22, 2010 | Vacuums
I`m looking for a alpine living air XL 15S instruction manual
Hi, I have the air purifier, and on the back of the unit is the number to call to have them send you the manual...it's:
1-800-989-2299
Hope this helps! I couldn't find a PDF one online for you to download it from the site.
Gwen
Aug 24, 2010 | Vacuums
Vacuums Logo
141 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
