Question about Lexmark X5250 All-In-One InkJet Printer
Lexmark X5250 the program keeps telling me that the cover is not closed properly
  • Anonymous Jun 15, 2008
    can't install software fully.can't find file LTWVC13N.dll LXBTDR54.dll
  • Toolate8 Jun 27, 2008
    I cannot print anyting because it keeps saying cover open. The cover is not open.
My priter lexmark x5250
Posted on Jul 05, 2008
Copies have blue background
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 5200 Series folder.
  4. Select Lexmark Solution Center / All-In-One Center
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
After printing the test page, try to print a document again to verify that the problem is fixed.
Feb 09, 2012 | Lexmark X5250 All-In-One InkJet Printer
Lexmark x5250 flashing green power light
The flashing light could indicate either a communication problem between one of your cartridges and the printer, a short in one of the cartridges, paper jam or the cartridge carrier has stalled. Please follow the steps below to fix the problem:
  1. Remove the sheets of paper from the feeder. Make sure there are no foreign objects or debris in the feeder.
  2. Open the printer cover and remove both the cartridges.
  3. While the cover is open, ensure there are no paper jams and the cartridge carrier is free from obstructions.
  4. Close the printer cover.
  5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first.
  7. Close the printer cover and check the light status.
  8. If light on printer is normal, open the printer cover and reinsert the other cartridge. Check the light status.
  9. Replace whichever cartridge is causing the light to flash with a new cartridge. You can also try to insert a different known working cartridge to determine if the other is faulty.
  10. Load some paper. Try to print a document again to verify that the problem is fixed.
Jan 25, 2012 | Lexmark Office Equipment & Supplies
Hi im looking for a driver software for lexmark x5260 printer for windows 7 32 bit
Click here Click on above link and download driver for win 7 it's for x5250 . Let me know if you need further assistance. Thanks for using FixYa.
Aug 27, 2011 | Lexmark X5250 All-In-One InkJet Printer
Open cover switch on x5250 broken
Please contact Lexmark Technical Support Center for assistance on this matter.
Jul 25, 2011 | Lexmark X5250 All-In-One InkJet Printer
Hello my printer wont work, the powerbutton is blinking and i hear a tikking noise. is mij printer broken?? lexmark x5250
It could an alignment problem, a paper jam, or something blocking the paper path. Open the printer cover and remove both the cartridges. While the cover is open, check the cartridge area for any obstructions in the cartridge carrier's path. Check any transparent strip(encoder strip) that has become loose from its position. If there's nothing out of the ordinary, close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert both cartridges and make sure they properly inserted and secured. Close the cover and try to print again.
May 29, 2011 | Lexmark X5250 All-In-One InkJet Printer
My Lexmark x5250 printer does not work. It always shows 'cover open' message.
first check that all doors or covers are closed and then check the door switches if they all ok one of the door switches are either broken or faulty and needs to be cleaned, repaired or replaced
Oct 13, 2010 | Lexmark X5250 All-In-One InkJet Printer
Lexmark x5250 "cover open" problem
hi
there is a sensor in a hole under the cover (door)
you should find it
check it that shouldn't be jamed
check it with a pen or something like that
Jun 12, 2010 | Lexmark X5250 All-In-One InkJet Printer
Lost software
I also misplaced my cd to install my x5250 lexmark printer
Aug 29, 2008 | Lexmark X5250 All-In-One InkJet Printer
Lexmark 5150 - Error 0502
1. On your PC, go to Start, Programs (Windows XP: All Programs), Lexmark series.
2. Select the Solution Center.
3. When the Solution Center appears, click on the Maintenance button.
4. Select the option to Install a new print cartridge. The carrier should slide over at this point and allow you to insert and/or remove cartridges.
5. Make sure the correct cartridges are installed inside the printer first, then inform the software which cartridges have been installed. Note: This applies also to installation of a single cartridge.
6. Print the Print Alignment page to ensure the print quality is satisfactory.
7. Close the Solution Center.
Jan 07, 2008 | Lexmark X5250 All-In-One InkJet Printer
Lexmark X5250 All-In-One InkJet Printer Logo
91 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
