Question about HP Photosmart M525 Digital Camera
I have a M425 camera and have just bought a new Sandisk card for it. When i put it in camera it just keeps coming up with wrong format, then unable to format. The small tab on the right on the cars is in the unlocked position.
  • kakima Nov 06, 2010
    How big is your new memory card? The M525 works with SD cards. If your new card is larger than 2GB then it's actually an SDHC card. While SDHC cards will fit into the slot, they are electronically incompatible and won't work.
    Brigadier General:
  • 11,967 Answers
Is the new card an SD or an SDHC card? Some cameras can't use the SDHC (high capacity) cards. Check your manual.
Posted on Nov 06, 2010
HP Photosmart M425 card has wrong format press ok to format card unable to format
You could try formatting it in My Computer on PC by right clicking on its icon to bring down the option, then format again in the camera to ensure compatibility
Dec 15, 2010 | HP Photosmart M415 Digital Camera
New 4GB SanDisk card won't format in my Hp M425 digital camera!
First be aware that a 4GB card may well exceed the capability of this camera as older cameras have a max capacity of 2GB because of the filing system that is used which is known as FAT.
A 4GB card is FAT32 and this causes problems because older cameras cannot recognize that system.
However please have a look at my FixYa Tip on the subject which gives a complete breakdown on the issue.
In some cases you can format a card with your PC and it may work with the camera.
Thanks for using FixYa.
Jan 01, 2010 | HP Photosmart M425 Digital Camera
Memory card
You might need the SD card, not the one that has HC also.
May 29, 2009 | HP Photosmart M425 Digital Camera
Card has wrong format?
The first thing you will have to check the card. There is slot on the card that contains a switch. This will lock the card so that it is write-protected. This will cause the unsupported card error.
If the card looks fine, try a card reader just to confirm that the card has not been corrupted.
If the card is functional and you can read its contents from the PC or another SD-slot device, then the issue is your camera. The slot contains thin copper prongs that comes in contact the copper surface on the back of the SD card. If the prongs are bent or damage, then the camera cannot read your card.
Dec 05, 2008 | HP Photosmart M425 Digital Camera
Can't reformat my memory card
Hello
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Jun 25, 2008 | HP Photosmart M425 Digital Camera
    Not a solution, but after corresponding with HP customer service, they concluded that the problem with my M527 (see above) cannot be fixed. They offered to replace it with the same two-year old model for $99.99 which is much more than that model camera would be worth. I declined their offer.
    May 18, 2008 | HP Photosmart M425 Digital Camera
    Wrong format on HP M425
    Just fixed this problem on a M525 camera (same physical construction).
    Do a search with M525 and format.
    Feb 10, 2008 | HP Photosmart M425 Digital Camera
    Card Format
    the card may have become corrupt, try carefully cleaning the contacts with a pencil eraser and try again,or try formatting it using a card reader, but you may have to replace the card.
    Jul 28, 2007 | HP Photosmart M425 Digital Camera (5MP,...
    HP Photosmart M525 Digital Camera Logo
    117 people viewed this question
    Top HP Cameras Experts
    teddyboy
    Lawrence Oravetz
    Are you a HP Camera Expert? Answer questions, earn points and help others
