Question about Intertherm P3RA-042K Air Conditioner
I have a Intertherm P3rA-042K that runs the ac at the same time as the heat strips. I have a Honeywell RTH3100c I have the red wire at R the Yellow at Y the Green at G and the W2 at aux. I had a jumper between Aux and E like the manual said but it makes no difference. Also for some reason it was hooked up before with a blue wire joined with the red at the unit and the blue going to B at the thermostat. I removed the blue as i saw no use for it and it still doing the same thing. The unit froze up last night from running both the strips and the ac at the same time.
  • 5 more comments
  • tractormanan Nov 06, 2010
    I had red green yellow blue and white coming from the ac. I know white is for the heat blue was hooked in with the red wire.
    Yes
    ok it works both the heat strips and the fan are on. But now what?
    I think I have it figured out I'm trying to run an ac unit with a heat pump thermostat :/ Guess I'll need to get a different one.
    Thanks for the help.
    Great help!
    Very helpful.
  • Intertherm Master
  • 6,674 Answers
Red, green, and yellow should all be from AC unit. What other wires do you have there, and are they separate from red , green, yellow?
Posted on Nov 06, 2010
  • 2 more comments
  • Mike Butler
    Mike Butler Nov 06, 2010
    Remove green and yellow from thermostat, and see what you get. That should remove circuit to compressor and fan on AC.
  • Mike Butler
    Do you have a multimeter?
  • Mike Butler
    did you try removing G and Y from thermostat?
  • Mike Butler
    Wouldn't be the first time a manufacturer told me that a particular thermostat would work, but failed to tell me I'd have to omit something like a 2nd speed on a fan or something.
    Good Luck, let me know how you make out.
Need electrical schematic for Intertherm P3RA-024K
Hi Val
check this out maybe it helps.
http://www.manualslib.com/manual/507003/Nordyne-P3ra-030k.html?page=9#manual
Dec 03, 2015 | Intertherm P3RA-042K Air Conditioner
How do you relpace an A.C. thermostat?
E Back up heat/ white wire
AUX Jumper to E
Y yellow wire / Cooling - compressor
G Indoor fan Green wire
O Reversing valve energised in cooling most units Orange wire
L unknown. consult your manual Leave open
R Main power Red wire
B Reversing valve energised in Heat Rheem units only.
C Common second leg of power Blue wire.
Aug 30, 2014 | Honeywell RTH3100C - Digital Heat Pump...
Changing From Trane to Honeywell
Color ---> New stat terminal
Blue--------C
Green------G
Yellow-----Y
Orange----O
Red---------R
White------E and Aux.
Tan---------unused, tape and secure it
If there is Rh and Rc or R and Rh, these terminals should be jumpered together.
I used to install Weathertrons eons ago. Whatever you do DO NOT connect the blue wire to the B terminal, you will short out your low voltage transformer immediately when you switch to heat
Jun 13, 2013 | Honeywell RTH3100C - Digital Heat Pump...
Intertherm has wiring of E,O,G,R,C,Y,W all have wires to them and changing to honeywell it has Rh,Rc,W,Y,G Where do all the wires go?
If you haven"t solved it by now, with the new stat you will not use the O or B terminals. Your red wire will connect at either one, RH, or RC as they are connected together with a jumper wire. Then, G to green, W to white, and Y to yellow. Now, if this is a heat pump, you have the wrong thermostat. The one you have is for a gas fired unit. The O and B terminals are used on a heat pump to shift the reversing valve. So, if you have a gas unit, I believe it is, wire it like I said. Red will go to both RH and RC as one. Please rate me on my help.
Shastalaker7
A/C, & Heating Contractor
Jan 12, 2011 | Intertherm P3RA-048K Air Conditioner
Have an Intertherm thermostate in mobile home controlling gas hearing and elec ac. Blue wire to thermostat connects to the "A" terminal on the thermostat...Blue wire goes to a terminal on the...
If there are only two wires going to the thermostat? Then you will not be able to use a Digital Programable stat. Intertherm and Coleman furnaces do the switching different than regular furnaces. They use the switching from heat to AC at the furnace with the rocker switch. They use the thermostat to either break the connection or make the connection. They use a heating only thermostat.... Hope this helps
Jan 02, 2011 | Intertherm P3RA-048K Air Conditioner
Weed eater pulled out red & white wires from thermostat at a/c unit. Red went to yellow and white to ?. Unit is an intertherm unit, model unknown but schematic #703909b
look on indoor unit to see what they used if only ac unit then only 2 wires needed common usually blue or black and yellow if heat pump then orange for rev valve o term on stat r red y yellow then white or brown for call for elect heat in defrost and blue or black for common also take some 3/8 clear tube to incase the stat wire and zip tie it to top of line set to help stop this
May 07, 2009 | Intertherm P3RA-030K Air Conditioner
Heat will not shut off
Take white off of Aux, and attach it to L
Feb 16, 2009 | Honeywell Programmable Thermostat Heater
Intertherm to Honeywell thermostat
Typically if you have a yellow wire in the "y" terminal blue is used as common or "c". As far as your jumper from rc to rh, that will depend upon what type of heat you have. If all of your heat and cooling come from your packaged unit outside, yes you will need the jumper. If this does not work maybe you have a bad breaker or transfomer.
Oct 12, 2007 | Intertherm P3RA-048K Air Conditioner
Intertherm P3RA-042K Air Conditioner Logo
180 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
