Question about La Pavoni Napolitana PA-1200 Espresso Machine
I have a Pavoni Napolitana that I love. Over the years the steam valve has begun to leak. Water drips through the frother while on. Is this something simple like replacing a washer or should I have it serviced? Thanks
  • 3 Answers
That's simple. Happened to me also you need to replace a little O-ring cost about 1 dollar they break after a time and simple to replace. If you still looking email me for more info's at angeliqueangela@yahoo.com
Posted on Jan 04, 2011
Saeco incanto deluxe frother leaking and wont pull shot because water comes out of frother tube during shot disbursement
Dear Jon,
Hi this shrikant from mumbai.This problem is happen due to dust stuck in tea/hot water valve ( for steam which you rotate).
If you have screw driver set then open the machine by using + screw drive. step below,
1.I here attach picture of valve.
2.you have to open it and clean it ( sea in pic 44,46,47,54).
3.after water leaking stop you have replace one o-ring 54 no. in picture.
4.After you machine work fine.
regards,
Shrikant Shinde
Yogishri Engineering
+91-8425830001
Jan 28, 2015 | Saeco INCANTO DELUXE Espresso Machine
My Keurig Milk Frother stopped working. The green light comes on but turns off immediately. Is there something I can fix?
How long have you been using that? Why not try the frother from Kitchen Ace. I can assure you that the quality of there products are really awesome!
Amazon com Kitchen Ace Can Opener Stainless Steel with Smooth Edge...
Sep 12, 2014 | Coffee Makers & Espresso Machines
Super automatic espresso machine leaks water into drip tray and onto counter when I use the frother
The stream valve is leaking and probably needs to be replaced. If you remove the top cover it is visible.
Sep 12, 2013 | Solis Palazzo Rapid Steam Palazzo Fully...
Dripping water from frother during coffee making, leaks water under unit - mixed with darker colored residue
Check the small chamber behind the white plastic valve, that might be filled with coffee grounds and water. For the leak while making coffee the steam valve needs to be rebuilt or replaced.
Nov 28, 2009 | Saeco Incanto Sirius Fully Automatic...
All water directed to Frother/ Water nozzle on Impressa C%
The Multivalve seems to be stuck. When you start up the machine you should hear the multivalve turning 2 times, if it`s silent, the valve is defective. This valve is important to guide the water in the right direction. Contact your servicedealer and let them have a look. There`s also a small chance that the electronic board are sending wrong or no signals to the valve
Sep 28, 2009 | Jura Capresso Impressa Z5 Espresso/Coffee...
My Shark Iron leaks....
fill with water turn iron on max keep turning steam dial all the way to the right until you get to self clean hold iron horizontal and make sure you have a towel or something to catch water drips and debris coming out of iron let iron steam and spit water out until it stops on its own turn dial back to regular steam settings wipe residue off of the plate with a towel adjust temp settings back to normal
Aug 14, 2009 | Euro-Pro Shark GI490 Iron
Steam Wand Leaking on La Pavoni Espresso Si
I HAD the same problem. I fixed it for 50 cents. It takes the removal of 4 screws (2 phillips on top, 2 long standard on bottom by the group) to remove the top to access the steam wand valve. Once the the top (and the chrome bezel) is removed, then screw out the valve counterclockwise buy ALL THE WAY until it comes out. There are 2 O-rings on the stem of the valve that wear out, Cut these off with a sharp knife, go to your local hardware store, buy 2 new ones for 50 cents, install new O-rings, and reverse the disassembly procedure. Voila, no more leaky steam valve!
Jun 20, 2009 | La Pavoni Espresso Si PAB-16 Espresso...
La Pavoni Napolitana: the grinder works however
Yes. Inside on the top after you loosen 2 scres the coffee warmer plate comes off there is a reset switch.
Apr 27, 2009 | La Pavoni Napolitana PA-1200 Espresso...
Coffee Makers & Espresso Machines Logo
229 people viewed this question
Top La Pavoni Coffee Makers & Espresso Machines Experts
billconfused
Pieter Vleeshouwers
Pieter Vleeshouwers
NOEL
NOEL
Are you a La Pavoni Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
