Question about Hampton Bay (261025) Dual Mount Ceiling Fan
I am unable to remove an old hampton bay ceiling fan it is a flush mount about 10 years old. I have taken everything off but i unable to get the motor part off
  • 44 Answers
There are 4 screws on the canopy which is the part that is mounted to the ceiling box . Just remove those screws it will come down . Hope this helps.
Posted on Nov 06, 2010
I have a Hampton Bay ceiling fan model 56-ant that is currently mounted flush. Can it be installed on a vaulted ceiling with a pole?
Yes. In flush mount configuration, it has about a 3" pole connecting the ball-mount that sits in the cup-shaped bracket. You just need to replace that short pole with one that is as long as you want. Lowe's Home Improvement or Home Depot sells them up to six feet long.
Jul 09, 2017 | Hampton Bay Dryers
Hampton Bay Sidewinder ceiling fan. For ten years, wall mounted control functioned until it 'blew' when electrician was working on a remodel of another room. Installed another control (Progressive...
You called customer care about a Hampton Bay & they sent you Minka Aire??? Hampton Bay is a store brand for Home Depot. If The fan came with a remote, you probably need the one for your fan.
Aug 24, 2013 | Hampton Bay Sidewinder 04890 Ceiling Fan
Trying to remove a ceiling fan Hampton Bay model C 542 MP (CH) PBL . its flush mounted and cant get to mounting bracket.
Look for 2 to 3 screws at the top edge of the fan's ceiling cowl. Remove those and the ceiling cowl can be sled down, which will expose the the ceiling mounting bracket . They are fairly small head screws, so look carefully for them.
Hope this helped you and thanks for choosing FixYa.
Aug 14, 2011 | Heating & Cooling
Similar problem: Does Hampton Bay Vaulted Ceiling Mount exist?
Ok so here is the deal. No there does not seem to be a Hampton Bay specific mount. The mount that comes standard in most of the Hampton Bay fans can handle the angle of most standard (read: small) angles. I do not know if it will be the case with all Hunter products, but the adapter for the Hunter fan that I replaced, worked with my new Hampton Bay. So now, I have from the downrod up is from the original Hunter fan. Hope this helps.
Sep 16, 2009 | Hunter Vaulted Ceiling Mount - Bright...
Ceiling fans on same frequency
There should be dip switches in/on both the remote control and the ceiling fan that enable you to change the control frequency. The only thing that you have to ensure is that the two components are set to a matching frequency.
The switches in the remote are located in the battery compartment just above the batteries. Remove the dome on the ceiling fan and you should find the switches for that unit. Just compare the two and match whatever changes you make from one unit to the other.
Originally answered by d0n0r in this question
May 25, 2009 | Universal Remote Control Hampton Bay...
Hampton bay #762425 portland 2 ceiling fan
I suppose you can mount it as close to the ceiling as you want as long as the blades do not hit the ceiling. It being that close will not allow the air to flow as well if it was 6 to 12 inches lower.
Mar 15, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Hampton bay portland 2 ceiling fan
not sure of your exact model...but I have installed many hampton bay fan... so far they have all worked for ceiling hugging mode.. keep reading your instructions
Ceiling fan
If the fan blade mounts are removable, go to your local hardware store with one of the mounts, and find some screws that will fit. You might not be able to get the same color, but if you check a few stores you should find something with the right shape of head to fit snugly.
Apr 17, 2008 | Hampton Bay (261025) Dual Mount Ceiling...
Hampton Bay (261025) Dual Mount Ceiling Fan Logo
206 people viewed this question
Top Hampton Bay Dryers Experts
Craig Butler
Craig Butler
Steve Allison
Steve Allison
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
