Question about Denon AVR-1802 Receiver
I have a Denon AVR 1802 and everything seems to be working properly, but I an mot getting any sound from the unit. When I perform a test tone, I get sound from all the speakers, but I can not get sound either from the TV or teh DVD. It has worked fine in the past, I was wondering if there is a button that may have been pushed by accident or something, I have two small children and they may have pushed something that caused teh issue
    Novelist:
  • 87 Answers
You could try a total reset of the system. To do so, Press Power while simultaneously pressing Speaker A and Speaker B. When the display flashes at about 1 sec intervals, release all buttons. Then select a desired source as normal and see if it plays as expected.
Posted on Nov 06, 2010
My denon avr-985 has no sound coming out of it why could this be
Go though your menu on the reciever, Look for the speaker functions for your front end rear speakers ,It was probably turned off. Was it working before you got it from your friend,
Sep 20, 2012 | Denon Avr 985 7.1 Channel 945 Watt...
AVR-1802 5.1 Channels Receiver: My Denon AVR-1802 LED is flashing rapidly. I have...
replace all the electrolytic capacitors in the power supply. i had the exact same problem with mine and once i replaced the capacitors it powered up and stayed on and worked perfect.
these capacitors tend to fail as they're of poor quality.
this fault is very common on denon receivers, especially the later models.
hope this helps?
May 16, 2010 | Denon AVR-1802 Receiver
I am trying to use my Denon AVR-1802 to connect my cable box to my TV. The problem is that I don't have any speakers connected to the 1802, I just want to route the cable box's video and audio to the TV...
connect your analog output from the cablebox to the receiver md/tape in. then connect your tv audio input to the md/tape out of the receiver. or you could just pass it straight from the box to the tv, bypassing the receiver altogether.
Nov 03, 2009 | Denon AVR-1802 Receiver
Denon avr 1802 died after lightning strike
I hate to be the bearer f bad news but it has been my experience , anything hit by lightening stays hit permanantly ..
You may find a few components on the quick scan of the circuit burnt or damaged , but you can guarantee that other components have been fried also .. It does enough damage to any electrical system when you get a 300v spike on the mains .. so imagine what approx 1/2 a million volts will do to a 12 volt radio ?? dont waste your money call your insuarnce company and claim for it ?. ... Regards vortash
May 02, 2009 | Denon AVR-1802 Receiver
My Denon AVR-1802 is permanently stuck in tone defeat. The display actually shows that the tone defeat can be turned off and on, but the tone controls, ie. bass and treble do not alter the sound in any...
Is this only when using external inputs? The manual says the Tone Control will not function in Direct Mode. Try Stereo and various DSP surround modes to see if the Tone Control works.
Apr 21, 2009 | Denon AVR-1802 Receiver
Denon AVR 1909 - tuner audio intermittent - off and on repeatedly
Make sure you have an anteena connected and adjusted
Jan 29, 2009 | Denon AVR-1802 Receiver
Denon AVR-1507 No sound on left front channel
Because the sound is only faint says to me that the power amp that controls the left channel is faulty. You need to look at the device(s) on the heatsink and probably replace them.
Dec 28, 2017 | Denon AVR-1507 Receiver
Digital audio cuts out.
I have same DD 5.1 tiny "bursts" problem with satellite HD channel. It is probably problem with Crystal DSP (German site): http://forum.digitalfernsehen.de/forum/showthread.php?t=89328&page=3
"Denon bietet Lösung für EX-Flag-Problem bei den Modellen AVR-1602 und AVR-1802 an
07.08.2002(cr)
Dass die Denon AV-Receiver AVR-1802 und AVR-1602 die mit einem DD 5.1EX-Flag versehenen Tonspur von "Atlantis" und dem "Herrn der Ringe"nicht abspielen können, ist ein spezifisches Problem von einerbestimmten Revision des in diesen Geräten verbauten Crystal DSPs.Dieser Chip wird u.a auch in einigen Kenwood- und Onkyo-Modelleneingesetzt.Da es von diesem Crystal Chip unterschiedliche verbauteRevisionen gibt, von denen aber nur eine bestimmte betroffen ist,werden die beiden Filme auf dem größten Teil der verkauften AV-Receiverohne Schwierigkeiten laufen.
Denon bietet nun für alle betroffenen Kunden, die ihr Gerät beimdeutschen autorisierten Fachhandel erworben haben, eine kostenloseModifikation an. Das Gerät muss beim entsprechenden Fachhändlerabgegeben werden mit dem Hinweis auf das Herr-der-Ringe- bzw.Atlantis-Problem.
Momentan steht nur eine begrenzte Anzahl an DSPs zur Verfügung - Denonhofft, dass kurzfristig ein größeres Kontingent eintrifft.
Denon bittet daher die Kunden freundlich um Verständnis, dass nichtalle betroffenen Geräte auf einmal und sofort umgerüstet werden können."
May 23, 2008 | Denon AVR-1802 Receiver
Remote control for this model AVR 1802 is failed to work , i want spare
Many original remotes are exspensive and hard to get hold of , Radio Shack or Maplins have many universal remotes that not only will allow you to control your AVR 1802 but many other devices you have also ... at probably half the price . ... regards Vortash
Apr 17, 2008 | Denon AVR-1802 Receiver
Denon AVR-1802
might hav eto buy new control modual parts store hi end parts store order one for u
Jan 25, 2008 | Denon AVR-1802 Receiver
Denon AVR-1802 Receiver Logo
290 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
