Question about Honeywell Heating & Cooling
Honeywell digital CT2700 thermostat is blank. I have Two zones, one for the first floor and one for the second floor. The second floor thermostat is working, but the first floor thermostat stopped working and is just blank. It was working for the last week and then stopped. I check the circuit breaker and reset it just in case but it did not work. Should i just get a new thermostat or could it be something else
SOURCE: Honeywell T86A3006 24V Class 2 Round thermostat 8020
The honeywell tradeline thermostat would work as a direct replacement (no mercury in the new ones), however if your using just heaters and no cooling system off of it, you could Heat only thermostat from honeywell that would replace your unit as well. Both at available at Ace Hardware with the heat only unity being roughly 7 dollars cheaper.
Posted on Jan 23, 2008
SOURCE: Honeywell electronic thermostat malfunction for oil heat zone
Try changing the batteries.
Posted on Mar 04, 2008
  • 5 Answers
SOURCE: Replacing Round Honewell Mercury Thermostat
try to get one that is made for oil heat, the installation is easy only two wires, and the instructions make it easy.
Posted on Apr 26, 2009
  • 9 Answers
SOURCE: t8411r1028 honeywell thermostat blank screen where would fuse be?
That thermostat should get power from 24V side of a transformer in the air handler. There should be a fuse in there on the PCB, but just as likely, there may be a 2-wire sensor in your drain trap that will shut it down if it senses water backing up in the drain piping. Clear that line from the outside of your house with a shop vac, cycle the breaker for the air handler if needed. You may also be low on freon, though, so a service call might be a good idea anyway.
Posted on Oct 06, 2009
SRF518
  • 232 Answers
SOURCE: Honeywell T8411R 1028No power to the thermostat; breakers are not
site shows this thermostat is a non programmable unit and has been discontinued. none of the info sheets including a pdf shows a replacement battery. this thermostat operates off line voltage only. check for a control fuse or breaker on your heating unit.
Posted on Oct 17, 2009
Thermostat is not coming on we are in san antonio is there help out there for us
Reasons for a Blank Screen on a Honeywell Thermostat ...
homeguides.sfgate.com > ... > Real Estate Rental & Lease Basics
Honeywell and other brands of programmable thermostats typically show a blank ...and the batteries can no longer provide power to the screen, it will go blank. ...electrical system, a blank screen indicates there is no power going to the unit, ...
programmable thermostat troubleshoot - YouTube
? 3:35
https://www.youtube.com/watch?v=pNVTAUcBx-U
Sep 26, 2011 - Uploaded by Maxxmentum
Programmable thermostat started to fail and behave erratically after being in service for a few ... My thermostat works but the remotes have stopped working. .... Honeywell CM907 Digital Programmable Room Thermostat user ...
HEAT WON'T TURN ON How Test if your Thermostat is ...
? 2:36
https://www.youtube.com/watch?v=lSJn69EAcAw
Nov 16, 2014 - Uploaded by You can Fix It!!!!
Heater fails to turn on it does not mean you have a faulty heating system ... 4th - Check programming on a programmable
Jan 10, 2016 | Honeywell Programmable Thermostat Heater
Honeywell wifi thermostat display blinks on and off
Doesnt this run on batteries? are they loose inside or the contacts to them dirty?
Dec 21, 2013 | Heating & Cooling
The thermostat for the main zone in my house (honeywell model RTH5100B1017) is battery powered and it blinked change the battery for a couple of daye and then went blank. I have changed the batteries twice...
  • Check any batteries and replace if needed. Ensure that you use only AA alkaline, nonrechargeable batteries.
  • 2 Check for oxidation buildup on battery contacts. Use electrical contact cleaner and carefully clean the battery contacts of any oxidation buildup.
  • 3 Reset the system switch.
  • Read more: How to Troubleshoot Honeywell Thermostats ' eHow.com http://www.ehow.com/how_6596826_troubleshoot-honeywell-thermostats.html#ixzz17aWIl2Xt
    Dec 09, 2010 | Heating & Cooling
    The Zone 1 (basement) and Zone 3 (second floor; no
    On the zone damper motor, there should be a little lever allowing you to open the damper for emergency heat. Probably a bad zone motor or connection.
    Dec 26, 2009 | Honeywell Electronic Programmable...
    Honeywell thermostat t8400c intermittent blank screen
    It actually sounds like the batteries are going dead if the 24v from the furnace are not providing the power to the thermostat.
    Sep 28, 2009 | Honeywell Electronic Programmable...
    A/C not turning on - Digital screen is blank
    Your honeywell should have battery back up but the primary power for this is a 24 volt transformer located in the air handler probably in your attic. All these controls run on 24 volts
    Jul 11, 2009 | Honeywell Programmable Thermostat Heater
    2 zone sytem main floor cooler than what i set it to
    Warm air rises and if the upstairs thermostat is on it will onerride to lower the temp upstairs. To have the dowstairs thermostat govern, the up stairs must be off . The whole house will balance to the controlling thermostat.
    Jun 02, 2009 | Honeywell Programmable Thermostat Heater
    Honeywell T8400B Thermostat Display Intermittently Blank
    most likely a bad tstat i would replace I recommend honeywell focus pro 6000
    Jan 29, 2009 | Heating & Cooling
    Oct 23, 2008 | Honeywell Electronic Programmable...
    Heating & Cooling Logo
    652 people viewed this question
    Top Honeywell Heating & Cooling Experts
    Bill Long
    Paul Carew
    vance jones
    Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
