Question about Keurig B60 Coffee Maker
I'm not sure what my model # is, but it is serial #66.0100.0447517. Received it for Christmas, 2009. Used it approx. 6 months. Poured out water and didn't use it at all through the hot summer months. Filled the tank with filtered water this weekend and turned it on. It stayed on for less than 2 minutes and turned itself off. Can't get it to do anything else. Have read about de-scaling but it won't start heating water or vinegar. How do I proceed? It doesn't even display menu. Just cuts off.
  • 5 Answers
SOURCE: decreased brewing volume per cup, sluggish start to brewing
There is a small screen inside the circle on the base under the tank - when you remove the tank, you can see it. Shine a flashlight in there and make sure there's nothing clogging it.
Posted on Feb 18, 2010
SOURCE: Our Keurig Select B77 brewer turns itself off
I had the same problem with my B77 from Costco. Thanks for the good advice - Keurig is shipping me a new one plus a couple of boxes of K-cups. In the meantime, I did get mine working again (temporarily) by removing the water tank and putting it back on while the machine was turned off, and when I turned it back on, it allowed me to go through the menu options and even more importantly, make a cup of coffee! I usually refill the water tank without removing it, using another receptacle. I wonder if this is what causes the problem.
Posted on Apr 12, 2010
espressonist
  • 1711 Answers
SOURCE: Not getting full flow. Have demineralized twice
If you can also see there are a lot of inquiries about the same or similar problem. We have already investigate the matter and it is a design problem from Keurig, you have something you can do at the link that it explains it some more
http://www.fixya.com/support/r5543433-keuring_coffee_maker_b60_b70
Moreover you can contact the keurig customer service which we here that they are more than happy to help you and in many cases they have replace the machines with no further question, you can try also since you are a customer with rights.
Good luck
Posted on Aug 20, 2010
woobie dog
  • 1273 Answers
SOURCE: I have a two month
Try passing a fine wire back up through the water inlet that punctures the K cups. Drain most of the water from the reservoir and add white vinegar. If necessary, add enough water to clear the low level light on the panel. Hit the start button, and collect a cup of whatever comes out. Either filter the water and re-use or dump out. Continue using the white vinegar, letting it work in the reservoir and internal pot for ~10 minutes between cycles (cups). It will take at least one hour to clean it out and flush it well. Once you are making a cup's worth of water at normal speed and time, dump the reservoir on the side, and refill with clean water. If the reservoir has a bit of a slimy feel inside it, wash it thoroughly before re-installing. (You should wash the reservoir probably weekly, or so, depending on you water).
Flush clean water through the system, dumping each cup produced, until all traces of the vinegar are removed.
Best regards,
--W/D--
Posted on Jan 17, 2011
  • 679 Answers
SOURCE: I have a single cup Keurig abuout a year and 1/2
A drawback to Keurig machines is their thin water lines, which can be easily clogged with debris. If the machine is brewing but little or no coffee is produced, running a few cups of water through the machine without a K-Cup can allow the lines to clear any buildup. The exit needle (also called the "K-Cup pin") can get clogged with grinds; gently clean in and around the pin with a toothpick or paper clip to dislodge the debris. The harmful effects of calcium mineral buildup in your Keurig coffee maker can be avoided by descaling the machine every six months. A common method of descaling is to run a large cup of vinegar through the lines. The manufacturer may recommend a particular product to accomplish this.
Posted on Jan 25, 2011
Why is my ice maker no longer making ice? We received it for Christmas, so it's only been used for three short months.
is it not under some kind of warranty??? also your question includes no information on what kind of ice maker it might be so nobody here will even guess at that one.... check with warranty services
Apr 22, 2018 | Refrigerators
Date of manufacture 81v400, serial r1194849014
1) Rheem 81V40 electric water heater ... manufactured pre 2009 ... posted serial number does not match manufacturer
http://waterheatertimer.org/pdf/Find-Age-of-water-heater.pdf
http://waterheatertimer.org/pdf/Rheem-Ruud-2009-water-heater-parts-by-model-number.pdf page 5
2) Possible date of manufacture 11-1994
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 05, 2013 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Oil leaking from top of oil tank
what bike, oil cap not screw type. we talking 2 stroke or 4 stroke
Feb 13, 2013 | Motorcycles
Need to know the year of my tank RR410T
the age of all water heaters is listed under the serial #, not model #. you will have to call a plumbing supply house that deals in your brand of waterheater, a.o. smith, ruud, bradfordwhite,etc.
Mar 02, 2012 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I bought a used Bostitch nail gun. Model/serial # N6408406208021. What parts do I change to go from a 1 1/2 inch nail (approx. #6) to a 3 inch nail (approx. #16)? Where do I get the parts?
I do not think that the n64 will take a 3" nail. N64 will most likely fit a 2 or 2 1/2 inch. To verify the length of nail open latch door and measure the width of the slot into the barrel. Take a look at the bostitch n80 series of nailers for more power and longer nail.
Dec 18, 2010 | Stanley Bostitch Coil Framing Nailer
6 month old Panasonic camera in need of repair - receipt mislaid
Your best course of action is to contact CONSUMER DIRECT which you can access online or via telephone number 08454 04 05 06 Monday to Friday 0800 to 1830 and Sat 0900 to 1300, it's UK government funded so it shouldn't cost you anything apart from the phone call and nothing online.
Oct 01, 2009 | Panasonic PV-V4522 VHS VCR
Problem with Banner Shredder Shark, Model # SH 92050P
Blow some canned air down into the feed slot to clean the sensors.
Sep 24, 2009 | Banner American Products QuikFinish ...
More Steam Less Coffee
I had same problem after 4 months. very slow brew time, 10 cups of water poured in made about 6 cups of coffee. I used a packaged coffee pot cleaner powder and this fixed the problem (for now).
Dec 26, 2007 | Mr. Coffee 072179228578 12 Cup Coffee...
Coffeemaker
The Bunn coffee machine has an internal tank used for holding approx three potfulls of water at just below brewing temperature. When you add water for a potful, the thermostat senses cold water and starts the brew heater. The water level inside the tank comes up and goes through the sprayhead. This "surge" of water, that you call drips is normal. The hot water stratifies to the top of the tank, just like an electric water tank in a house. The internal pot heater kicks in and boils the water already in the tank, raising the water level in the siphon pipe to the sprayhead until the reservoir under the add water opening is empty.
Sep 15, 2007 | Bunn NHB Coffee Maker
Keurig B60 Coffee Maker Logo
44 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Steve Allison
Steve Allison
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
