Question about Garmin Forerunner 305 GPS Receiver
Pulse meter on forerunner not functioning
Went to use fore runner and found pulse readings nom longer recording. replaced battery but still no readings
  • eidy Jun 15, 2008
    moistened inside no difference pulse meter not recording.
Moist inside unit.
Posted on Jun 15, 2008
My pen is appears to have no power and unable to use - I have tried to charged but pen does not show any signs of charging can you suggest how I can fix this?
How old is it? The OLEDs on mine went south after a few years. I find the pen, albeit a great idea, the execution is junk. No user replaceable battery?? Its really planned death.
Sep 14, 2014 | Smart Pulse Livescribe pen
2002 4 runner has a P0500 and the speedometer does not work, also abs light and brake light and traction light is on
Here is the definition of the code.
You replaced the sensor which is the easiest thing to do, now you will have to troubleshoot the circuit back to the computer. Note the reference to the combo meter in the circuit. You may want to research this online.
P0500 TOYOTA Description The vehicle speed sensor outputs a 4 pulse signal for every revolution of the rotor shaft, which is rotated by the transmission output shaft via the driven gear. After this signal is converted into a more precise rectangular waveform by the waveform shaping circuit inside the combination meter, it is then transmitted to the Engine Control Module (ECM). The ECM determines the vehicle speed based on the frequency of these pulse signals.
Read more: http://engine-codes.com/p0500_toyota.html#ixzz27h3FhFu6
Sep 27, 2012 | 2002 Toyota 4Runner
My 2002 pontiac aztek battery light came on yesterday. Today i went out and NOTHING. jumpstarted it ran for a few minutes then died. Will not start without being jumped. i figured out how to get past the...
Hello! I do not believe this is a security issue...The Battery Light is telling you that the charging system has a fault...One of three possibilities exist...# 1...The battery can no longer hold a charge...
# 2...The Alternator is defective...Or # 3...The cables that interconnect power and ground are corroded and resistive...Do you have a voltmeter and a wee bit of experience using one?...If not send a comment...Set the meter to rear +12 volts...Place the meter probes directly in the center of the battery post...Record the reading...Jump start the vehicle...Quickly remove the jump cables and while the engine is still running, take the same reading again...The second reading must be 1.8 to 2 volts higher than the first...This tests the alternator...If alternator is good...Have the battery tested...Clean cables (on both ends) if necessary...
When the battery, alternator and cables are correct, the battery light will go out...At that point in time the engine should start...If not, then we have other issues and I'll fix them if necessary...
Guru.......Saailer
Feb 08, 2011 | 2002 Pontiac Aztek
I have had my garmin forerunner 205 since end of May 2010. It recently started taking longer than normal to find satelites. On my last run it came up as saying battery low when I had only just charged and...
You need to contact Garmin and have them replace or repair the watch. If the watch is less than a year old, it will be under warranty. Older than a year it may be a repair or replace only situation, Garmin will have to determine that. It is not unusual for the forerunner series to have rechargeable batteries that die off.
Jan 04, 2011 | Garmin Forerunner 205 Gps Training Watch
My watch to my garmin forerunner 50 started bleeping last week and then it went blank (the watch), changed the battery twice but still not working. can you help?
I have read the instructions for your watch and I found nothing in there that was helpful.
I am having a guess here but perhaps the memory is full (did you see the "Lo mem" warning?
Try downloading the memory to your computer if you can with a blank screen!
As a last resort, go to theri web site and find the "contact us " phone number and ask the maker.
Mar 15, 2010 | Garmin Forerunner 50
Garmin Forerunner battery replacement
It's not always the battery, I assumed it was and opend mine up to check it out but the battery was OK.
Problem was the unit wouldn't start without pressing mode + reset followed by the power button.
I lifted the internal watch contact strips to put a better connection between the two halves but that made no difference.
I found that I couldn't delete all the history and the watch had recently turned itself off on a run after giving a low battery warning => the history was corrupted and caused the watch grief.
The only way I found to delete the history was to load a v 2.80 (or earlier) version of the watch s/w (current 2.90 doesn't delete history and there is no tool to do it!)
Fortunately I had a copy of v2.80 but the old version is not now on the Garmin site (that I saw).
Moral of the story, don't run your battery low for two reasons, Li-ion batteries lose capacity if you run them below ~30% and also if the watch "low battery" turns off while recording it can corrupt the history and really upset the watch.
At least I now know how to open the watch and have found plenty of possible small mobile phone batteries that will fit (Samsung have a few possibilities). The ABSOLUTE max size of a replacement battery is 36mm H x 43 mm wide x 5.8 mm deep.
If you go 43 mm wide you have to trim a couple of internal plastic ridges in the case.
Good luck and try starting after pressing mode + reset if it won't fire up then try and delete all the history.
Also DON'T run the battery low if you want it to last, Li-ion work opposite to NiCad and NiMH which should be fully discharged before recharge. You try and keep them above 50%.
Steve
Sep 20, 2008 | Garmin Forerunner 305 GPS Receiver
Pulse meter died on forerunner 305
You may need to re pair the unit with the heart rate monitor. Settings/ General/ Accessories/ Heat rate monitor. RESTART SCAN. OR follow this link (Hope it works) https://buy.garmin.com/shop/store/manual.jsp?product=010-00467-00&cID=142&pID=349 Go here and click on owners manual. Go to page 46. Adding accessories.
Jun 15, 2008 | Garmin Forerunner 305 GPS Receiver
Garmin Forerunner 305 GPS Receiver Logo
97 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
