Question about Bling Software 123 Copy DVD Gold 09
Unable to encode video and cannot open demuxer
How to reset unable to clean 50 error on brother dcp-j125? I cant open my printer brother dcp-j125 due to an error unable to clean 50.no paper jam occured
Clean 50 is either Dirty Encoder Stripe or broken Maintenance Unit. In first case clean thoroughly the vertical Encoder Stripe and it should work. In case 2 better exchange the machine
Nov 23, 2015 | Brother Office Equipment & Supplies
Tip
Standalone DVD player with DivX why does the VBR encoded Audio lag the Video
DivX or XVid encoded MP4 Video codec or AVI will almost always have either the Dolby Digital AC3 Codec or the MP3 encoded audio codec see the following links; Fraunhofer MP3 Decoder or LAME MP3 Encoder
This fixed audio lag can sometimes be caused by VBR audio encoded files and starts part way through the playback as opposed to CBR audio some standalone DVD players will exhibit sound lag in this case. It is a good idea to re-encode the VBR to CBR audio this usually solves the problem.
I suggest that you convert/encode all your DivX AVI files into CBR audio to avoid any such errors; all commercial DVD Video Audio is encoded in CBR (constant bitrate) which also reduces the audio filesize unless its encoded in LCPM which will give a much larger audio component.
Check the audio bitrate type open the AVI in GSpot the example below shows an AC3 audio already in CBR so can be left alone and should work fine.
MANUAL CONVERSION PROCESS
This audio MP3 conversion process it a bit of a long way around I know, but it does work!
  • Open video in VirtualDubMod or VirtualDubMP3 (if there is an index error this can sometimes fix it for you.
  • Ignore the error warning that the video contains VBR audio.
  • Extract audio as MP3 ("demux" in VirutaldubMod or save as WAV, then rename to MP3 in VirtualdubMP3).
  • Convert audio to WAV with CDex
  • Open original video in VirtualDub,choose "direct stream copy" for video and "WAV audio" with "Full audio processing" with CBR MP3 compression (and interleaving with appropriate delay if out of sync) for audio.
SEMI-AUTOMATED CONVERSION PROCESS
You could also use several other easier methods including AVIDemux which uses VirtualDubMod or scan in the DVD-Video using TMPEnc v4.0 Xpress and applying a time lead OR lag however this does not solve a progressive lag *** but can be used to re-author a fixed audio lag error in milliseconds you can use either Windows Media Player Classic or KVM Player in real-time to find this lag or lead error and then adjust accordingly
If you can't work AVIDemux then AVIrecomp will be your best solution this is a bit more user friendly
NOTE> always keep a Backup copy of the AVI before you make any drastic changes as you could make the file unplayable the above process will only work on FIXED AUDIO LAG AVI files.
Progressive Audio Lag (starts in synch and runs fast or slow throughout the AVI is almost impossible to remove with re-encoding the AVI using the above methods.
*** Feel free to comment if you know of a foolproof way other than performing a full re-encode from the MPG2 or DVD VOB file.
on Feb 08, 2010 | Philips DivX DVD Player
How can i split an MPEG 2 stream into separarte audio and video streams?
you have to get a demuxer. multiplexing is called muxing, and demuxing will separate the streams
Jan 15, 2013 | Televison & Video
I have a 123 copy DVD gold software and can not copy a DVD because the software showed a pop up information "can not open demuxer". how can i solved this problem?
If the "Cannot open demuxer" error appears it means the Avi encoders on your system are either missing or corrupt.
To uninstall Windows Media Encoder, apply the following steps. 1.Go to control panel 2.Click on add and remove programs( Programs and features for Vista and Windows 7) 3.Click on Windows Media Encoder 4.Click on remove button 5.Click on next button 6.Then continue according to the instruction provided by the Encoder's Uninstaller
Reinstall your codecs.
DIVX http://www.divxmovies.com/codec/
XVID http://www.xvid.org/Downloads.15.0.html
Windows Media Encoder WMV - www.123copydvd.com/apps/WMEncoder.exe
Jun 30, 2011 | Bling Software 123 Copy DVD Gold 09
I have windows vista and i am unable to open files created by printmaster even although i have the disc. The files come up as sig files . Is there a free program i can download to help with this problem...
BODY { FONT-FAMILY:Tahoma; FONT-SIZE:10pt } P { FONT-FAMILY:Tahoma; FONT-SIZE:10pt } DIV { FONT-FAMILY:Tahoma; FONT-SIZE:10pt } TD { FONT-FAMILY:Tahoma; FONT-SIZE:10pt } People who use Sony and Cannon camcorders may feel frustrated trying to upload their videos to youtube, as thesy are taken and saved as mts/m2ts. Well, in fact, all they have to do is to find an mts to flv converter. How to convert m2ts to flv?
Download and install mts to flv converter on your PC. It takes only a few steps to convert m2ts to flv on Windows.
Step 1: Connect your HD video camera/camcorders to your PC. Copy the videos you want to share to your PC's hard-drive before converting or editing them.
Step 2: Launch the m2ts/m2ts to flv converter. Click "Add files" to browse your computer hard disc and add the .mts or .m2ts files you want to convert. You can load all the source files before the m2ts to flv conversion as batch converting is supported by this m2ts flv converter.
Step 3: Now you select flv as the output format and specify a directory for the output files. This m2ts to flv converter supports comprehensive video formats including avi, mpeg, wmv, mp4, mov, xvid, 3gp and more.
Step 4 (optional): The mts to flv converting program can set the brightness, the contrast and the saturation of your videos, crop, trim videos and even merge multiple files into one single file before the conversion.
Step 5: Click the "Start "button to start the mts flv conversion and all you have to do is to wait until the m2ts to flv conversion is done.
Related article: How to convert m2ts to flv and How to convert mts to flv
Oct 03, 2010 | Broderbund Computers & Internet
Scan my pc and boot this all files
unable to encode the video,cannot open demuxer
Aug 10, 2010 | Symantec WinFax Pro for PC
Cant open demuxer
If the "Cannot open demuxer" error appears it means the Avi encoders on your system are either missing or corrupt. Please use the following links below to download and install Divx and Xvid encoders. A good way of telling if your Avi encoders are installed properly is if the AVi file being used can play in Windows Media Player correctly.
You would simply need to download the appropriate codec you are attempting to convert to, and also the Windows Media Encoder.
DIVX
www.divx.com
XVID
www.xvid.com
www.microsoft.com/windows/windowsmedia/forpros/encoder/default.mspx
Jan 30, 2010 | Bling Software 123 Copy DVD Gold 09
Hi.. I have a jvc 32 X cam corder that i want to down load my videos onto my computer and am not sure how..
Two things here. Is your cam corder a digital one? If so there should be a connector on it for either firewire or USB, and if not, you will need some kind of video capture device if your cam corder has outputs on it. If not, you will need a player (vhs-c or 8mm or whatever your format) that can send out to the computer. Once this connectivity is done, you need video capture software that will "encode" the video files that will be produced. If your cam corder is already data (hard drive onboard or SCD card recording, you will only have to "demux" the format you have into the format that you are seeking (ie.. MPG to AVI or so on).
I hope that helps you out.. let me know if you need more clarification. It also might help if you give the media you have (VHS-c etc.) and the available outputs that you see on your cam corder. Thanks!
mrstan
Aug 29, 2009 | Video Cameras
Sound lags picture
This can some times be caused by VBR audio encoded files as opposed to CBR audio some standalone DVD players will exhibit sound lag in this case. It is a good idea to re-encode the VBR to CBR audio this usually solved the problem.
Although this is usually with DivX (AVI) files that have been re-authored to DVD-Video I suggest that you convert all audio to CBR to avoid any such errors.
this conversion process it a bit of a long way around I know, but it does work!
1) Open video in VirtualDubMod or VirtualDubMP3 (if there is an index error this can sometimes fix it for you.
2) Ignore the error warning that the video contains vbr audio.
3) Extract audio as mp3 ("demux" in VdubMod or "save as wav", then rename to mp3 in VdubMP3).
4) Convert audio to wav with CDex
5) Open original video in VirtualDub, choose "direct stream copy" for video and "Wav audio" with "Full audio processing" with cbr mp3 compression (and interleaving with appropriate delay if out of sync) for audio.
You could also use several other methods including AVIDemux which uses VDub Mod or scan in the DVD-Video using TMPEnc v4.0 Xpress and applying a time lead OR lag however this doex not solve a progressive lag but can be used to reauthor a fixed error.
Feb 12, 2007 | Philips DivX DVD Player
Bling Software 123 Copy DVD Gold 09  Logo
369 people viewed this question
Top Bling Software Computers & Internet Experts
Edward Talavera
Edward Talavera
Wayne Tolonen
Are you a Bling Software Computer and Internet Expert? Answer questions, earn points and help others
