Question about LG 42LC2D 42 in. LCD HDTV
Had my Tv for a week and connected it to a Thomson sky receiver. Everything worked fine until today. When watching sky progammes the screen continuously flashes every second making viewing impossible. I've connected my sky receiver into another tv and it works perfectly so I assume the problem may be a compatability issue?
    Novelist:
  • 145 Answers
Make sure both deviced are set for 60 htz, it might be that there is a signal overly if one is set for 50 htz and one for 60 htz double check your screens refresh rate make sure its 60 htz as well. If it flashes once every second while staying on most of the second this could be it. check to also make sure all the cords are correctly positioned and try to keep the cords away from audio equipment stereos/ home audio, this can also cause signal issues.
Posted on Nov 06, 2010
Playback of Topup TV Sky / ESPN Recordings
I am just guessing but you may have an ant-copy signal embedded into program signal causing to when you are trying to look at a recording to another source. If that is the case then there is one way that would work. You need to connect inline with the video line out to the in of the other unit (yellow) and that would solve the problem. Go to xdimax.com and check out a dimax signal adaptor( can not recall what it goes by,description-wise) This is almost like trying to use a hdmi output and a audio/video connection at the same time.This also happened when doing the same with some video decks (vcr)
Sep 02, 2017 | Thomson Televison & Video
I have an LG TV with an LG HOME CINEMA SYSTEM problem is: watch dvd/blue ray - video fine sound fine (through speakers) watch tv / sky -- video fine sound None throughspeakers on...
There are two things that I can suggest.
1-Test your optical cables to make sure they a good on a known working source because they are very fragile and break very easily.
2-Try to eliminate the use of optical output from tv to receiver. There may be a problem from the HDMI to optical conversion at the tv. Instead, try running the audio directly from the source to the receiver, and let the tv deal with video input only.
Hope this helps,
Good Luck.
Jan 07, 2011 | LG Audio Players & Recorders
Got sky installed today only thing getting on screen is "no video signal"
Sounds like the "channel" you are trying to watch on is not the one it's plugged into, or a faulty lead.
check the connection from the sky box to the tv, and select the av or hdmi channel that it is plugged into on the tv.
check the lead by swapping it for a known good one, for example from a dvd or ps3, but unplug from the dvd/ps3 and plug into the sky box(make sure that all the units are powered off when swapping leads) and try on the channel you normally watch/use the dvd/ps3.
If you suspect the sky is at fault, press menu on the sky remote and then flick through all the av/hdmi channels until you find the menu, then try to reinstall/retune the sky box.
If that don't work phone sky......................
Dec 30, 2009 | Toshiba 32HLC56 32 in. HD-Ready LCD...
How do I retune my Thomson Digital TV 24WK25UG after digital switchover in Granada area
this tv is not a dtv tv you can only watch digital tv if you now have a freeview box this is conected via a scart lead . you select av on the tv remote . or you can watch sky or cable . these are connected the same way .
Dec 04, 2009 | Thomson 24WK25U 24" TV
Thomson DTI1000 DV3 STB
since switch over I cannot get any progammes everything is connected OK ,rechecked aerial connection with another digibox thats Ok all I get is a blue screen . Can anyone help ?
It is a Thomson DTI 1000 DV3 model
Nov 11, 2009 | Televison & Video
We receive satelite tv through dish and digibox. We have suddenly
Try unpluging from the mains for about 2 mins,if still a problem then the LNB on the dish may be at fault
Oct 27, 2009 | Televison & Video
1 front speaker and 1 surround speaker won't work on cable selection
theres probably a problem with the right channel cable or plug that connects the tv to the reciever, or the tv is set to mono audio.
May 17, 2008 | Yamaha HTR-6030 Receiver
Archos dvr station remote control
I HAVE A SKY+ BOX ALSO , AMSTRAD MAKE ON BACK, TRY SETTING IT TO DIGITAL RECEIVER INSTEAD OF SAT RECEIVER, THEN SELECT THE MAKE PACE, THEN CODE NO 8 ( B676 ) THIS DID TURN OFF MY SAT RECEIVER BUT THEN ACCIDENTALLY SCREWED UP THE NEXT STAGE AND I CAN NOW NO LONGER TURN THE SAT BOX OFF,
BUT YOU MAY HAVE MORE LUCK, IF YOU DO NOT SCREW THE NEXT STAGE UP, BEST OF LUCK
Nov 30, 2007 | DISH Network ViP622 DVR DTV Receiver /...
LG 42LC2D 42 in. LCD HDTV Logo
57 people viewed this question
