Question about Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television
Hi my tv is the ws-55315 and i turn the tv on the light comes on for a second(the power light) and the tv shuts off is that the bulb i dont know?and how do i fix it
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
WHEN the power light goes off on front of set, press and hold both the menu and input (device) buttons at the same time for at least 5 seconds and then release both buttons.
Power light will blink an error code: most common is 2 blinks, 2 blinks, a pause and it will repeat code several times.
This is self check and will narrow down what is wrong with your set.
Let me know what code you find and I will tell you what it means.
SD TECH
Posted on Nov 06, 2010
  • jarezleake Apr 15, 2011
    I have the same problem with my set. I pressed the input and menu buttons, I got two blinks and two blinks. How can I solve this problem?
Wont turn on, turn power on and tv turns off and you hear click.
DO THE SELF CHECK WHEN POWER LIGHT GOES OFF.
On front of set press and hold both the menu and input buttons for at least 5 seconds and release both, power light will blink a two digit error code like 2 blinks, 2 blinks, and pause and repeat several times.
Let me know error code and I will tell you what it means.
SD TECH
Dec 07, 2010 | Mitsubishi WS-55315 55" Rear Projection...
Set comes on then turns it self off
do the self check this model has:
when green light comes on (power) and then goes off:
On the front of the set press and hold both the menu and input (device) buttons at the same time for at least five seconds and then release both.
The power light will blink a two digit error code like: 2 blinks, 2 blinks, a pause and then repeat it several more times.
Let me know with a comment here and I will tell you what it means.
SD TECH
Nov 23, 2010 | Mitsubishi WS-55315 55" Rear Projection...
Ws-55315, screen turned to fuzz
If it was the lamp there should be nothing. press the menu button if the menu does not come up the issue is with the tv. If the menu does come up try a second source a dvd player or game system. If the issue is only with the original source than the original source needs to be replaced.
May 05, 2010 | Mitsubishi WS-55315 55" Rear Projection...
It turn on then it gose off how to fix
tv come on play good for a few second , screen goes blank the power shut of
Jun 16, 2009 | Mitsubishi WS-55315 55" Rear Projection...
WS 55315 Tv won't turn on-
Thanks for your help can you send photos so I can see what to look for
Dec 01, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Mitsubishi turns on for 3 seconds then shuts off..after power surge
try holding in the menu and input buttons together on the front panel for about 8 seconds to see if the self diagnosis feature will blink a two digt code then let me know what happens
Jun 05, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Mitsubishi Mod # WS-55315
On this model the timer led blinks when the tv is off if you have the timer set to turn it on. You can get the manual here.
Mar 13, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Turning on for 2 seconds then shutting off
thats the protection circuit. it detects that the low and or high voltage is not correct and shuts down.
you need a tech .
Sep 04, 2007 | Mitsubishi WS-55315 55" Rear Projection...
WS-55315 with only red bulb
It seems that you donot have the 200+ V line for the GREEN,BLUE. This line is the same as the read line, check connectors located on crt boards make sure they did not come apart. Also you can:This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. Shutdown at power with self diagnosis error 2-2. Check for open fuses F9A04 and F9A05 part # 283P144080 on the +24 and -24 volt lines. If the fuses are open the convergence output circuit would be suspect. 2. Shutdown at power with self diagnosis error 2-1. At power on check for 12-volts DC at connector KH pin 8, if missing check IC9C51 part # 270P990010 and L9C52 part # 441D009020 on the Signal PCB
Aug 24, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television Logo
127 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
