Question about Whirlpool Refrigerators
Whirlpool Imperial Series Refrigerator - water pools in both the refrigerator and freezer parts - believe it's a result of the defrost cycle but not sure why the water is pooling inside instead of being drained outside
  • 1462 Answers
SOURCE: water pooling on the bottom shelf of the freezerless refrigerator
take back panel off inside freezer.
you will see a drain tray at the bottom with a drain hole in the middle. this hole is blocked with ice
melt off with a hairdryer and follow up with hot water till water flows away freely.
check drain tray heater is ok as well
Posted on Oct 11, 2008
mgprice
  • 744 Answers
SOURCE: water pools under the veggie crisper
yoor problem is with the drain, when your refrig goes into self defrost the water melted from the defrost needs some where to go. There is a drain for this purpose....it is normally a tube that leads from the rear of freezer to pan by compressor. when this gets blocked the water has nowhere to go except into the freezer vent and down the bottom of the refridge compartment. you will need to clear the blockage in the drain tube...if you are still haveing a problem i can tell you how.
Posted on Jun 22, 2009
woodchuck789
  • 4070 Answers
SOURCE: water leaking from icemaker on outside
If this is your water dispenser leaking
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Posted on Jul 08, 2009
arikrom
  • 528 Answers
SOURCE: whirlpool refrigerator has water pooling under crisper
  1. take all things out from freezer
  2. open back wall of freezer
  3. clean the drain hole in the bottom middle
  4. put all back
  5. good job you fix it
Posted on Jan 01, 2010
iwillfixforu
  • 619 Answers
SOURCE: Water is dripping down the back of the
Defrost drain tube is clogged. Have to clear this by removing back wall inside freezer and removing the ice build up inside the defrost tray and tube. Very very hot water and hairdryer will help with this process. hope this helps.
Posted on Jan 29, 2010
Whirlpool Gold Model # GI5FVAXVQOO French door Refrigerator with ice through door is frosting up in the freezer.
your defrost drain has clogged, normal self defrost cycle should be removing water via a drain tube leading down behind unit and evaporating away. however if you were to look behind refrig in compressor compartment youll see a "drain tube" that has what appears to be a black "duckbill" grommet attached..it has more then likely failed be gumming up and preventing water to drain through.if you remove this and install part number "w10619951", should solve your problem... youll need to clear frozen drain from inside unit as well, directions i believe are in the part packet
Oct 28, 2013 | Whirlpool Gold GI5FVAXVQ 25 Bottom Mount...
I have whirlpool imperial series refrigerator model et1lfkxkq03, which has freezer on top. Water from freezer is leaking into refrigerator. I cleared out the freezer and can't find the clogged drain.
You will probably have to remove the back panel, which is the evaporator cover. The defrost water drain is always at the base of the coil. **** the drain out and pour some hot water down it
Jun 22, 2011 | Whirlpool Freezers
Moisture is pooling on my refrigerator shelves and I haven't been hearing the defrost cycle run,
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 16, 2011 | Kenmore Refrigerators
Older (serial # erased) GE freezer top frost free Water pools in bottom of frig. cannot find drain.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Drain is under the coils and may be froze shut...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Sep 11, 2010 | GE J Series 18.2 cu. ft. Top Freezer...
Water is leaking out of inside bottom vent of freezer and pooling and freezing on bottom under pull-out container unit.
heatman101
Aug 31, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
I have a whirlpool imperial refrigerator; freezer on top; with icemaker....water is leaking from the freezer section down onto top shelf in refrigerator, near back, any help??
Hello and Welcome to FixYa!
Actually the leaking water is from the evaporator coil unit.... Under normal conditions,Self-defrost refrigerators usually dispose the water generated during the defrost cycle through a tube or channel that directs the water a pan (Known as Drip pan), commonly below the refrigerator unit....
The channel or tube is clogged and the water is leaking to the refrigerator unit, so you need to clear that contamination....Once the blockage is removed, the generated water will move through that channel/tube directly to the drip pan and there will no water on the top shelf in the refrigerator compartment. This is all you need to do....
Best of Luck,
Please do Rate the solution, if you feel that this helps you,
Concerned.
Aug 10, 2010 | Whirlpool Refrigerators
Water is dripping down the back of the refrigerator inside and pool in the bottom of the refrigerator. Whirlpool/ freezer on top ET-1CHMXKQ02. Freezer is still working and icemaker is still making ice.
Jan 28, 2010 | Whirlpool 21.6 cu. ft. Top Freezer...
This is a side by side refrigerator/freezer with water freezing on the bottom of the freezer as well as water pooling under the freezer area & seeping out the side and front of the freezer on the...
defrost wiring problem, defroster stuck on or timer not working properly , eventually wires may short out. Had this problem on my whirlpool
Aug 02, 2009 | Refrigerators
I have a Whirlpool Imperial Series refrigerator that has water coming from the bottom- onto the floor. The evaporation pan is nowhere near full. It is not apparent where the water is coming from. Any...
Hi, Dounfd like the defrost drain in the freezer is plugged. Remove the rear panel inside the freezer and locate the drain hole under the evaporator coil.
Once all the ice has been removed, flush the drain with hot water. Some models require an after market drain heater kit. If you will get me a model #, Ican look this up for you.
Vic
Jul 02, 2009 | Refrigerators
Whirlpool Custom Series refrigerator leaks -Model ET18JKXSN05
It sounds like the line you found is for draining the water from the defrost cycle. It should drain the water from melting the ice into the pan at the bottom so it will evaporate. Sounds like its being clogged is the cause of the water in your fridge.
May 13, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Refrigerators Logo
1,335 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
