Question about Zanussi Washing Machines
I've got a much louder noise than normal coming from my Zanussi ZWD 1681 W washing machine when it spins! I've opened it up and it is coming from the drum area so would i be correct in thinking that it's the bearings? I'm aware that the machine has a front and a rear bearing. How do i get into remove them after the back is of the machine, is it by removing the drum pulley? if so how do i do that and if only one bearing has gone would i be as well changing them both?
  • 139 Answers
SOURCE: bearing noise
Hi there im the wash docotor. With your zanussis once you have removed the back half of the pannel and the top pannel. you will have to then detach the motor wire plug. then the heater wires and also the there is a sensoer on the side of the drum that also has a wiring connection. Also detactch the earth wires Then here come the tricky part. if you look on the top of the drum you have a rubber pipe connected to it comming from the washer draw detach that its easy. Then you have to dicconect the door seal from the front of the machine by the door (do not dissconect from the seal from the drum as you dont have to . Then disconnect the the drain hose. once this is all done you have to disconnect the legs, from the drum side. these are easily done as the pegs come out easily if you push in the pips from one side you can either knock them out with a hammer but it is best to pull em out with either some long bent nose pliers or gripping em in such a way with a monkey ranch Best way og getting the drum out is once you have done all that is to turn the machine onto its back and lifting the casing off leaving the drum on the floor.
Posted on Oct 10, 2006
  • 183 Answers
SOURCE: replace drum bearing
To complete this repair correctly and to prevent problem re occuring within months you must change the inner drum spider at the same time as the bearing kit, otherwise you are wasting your time, to complete the repair if you have not done one before will take you aprox 1 to 3 hours depending on space available and practicle ability, here goes, remove lid and outer case from machine to do this remove bolts on lower back and two side bolts (under small white covers) remove bolts along top edges both sides on top of macnine, remove cabinet, remove motor, remove hoses, remove heater and thermostat wires, noting location for refitting, remove suspension leg pins and lift outer drum assembly complete fron lower frame, split two halves of outer drum by removing bolts around centre seem, split drum in two, remove drum pully, refit pully bolt and drift inner drum out having put nut back on drum spider thread to avoid flaring shaft, using hammer knock shaft through bearings, then using a chisel or similer object knock out bearings and seal, reverse process refitting new bearins and spider, make sure to replace centre outer drum seal, as these are prone tro leaking I suggest you also seal with a layer of clear silicon, and problems contact me again, not really a job for a novice. Good Luck you will need it. Regards Advisor
Posted on Aug 30, 2007
watugot
  • 290 Answers
SOURCE: rear bearing noise when drum rotates
Check the warranty in your owners manual. Your parts should still be in warranty (basket and tub). You will have to pay labor, about $200. Turn it by hand and listen carefully to be sure it isn't something that has gotten between tub and basket.
Posted on Oct 06, 2007
Krazytech
  • 725 Answers
SOURCE: WAsh machine drum bearing removal
check out the tommy tool on youtube .it will show you how to do it even if you don't buy the tool...
http://www.youtube.com/watch?v=F3Wrq6Yxra8
let me know krazytech
Posted on Aug 13, 2008
ginko
  • 19396 Answers
SOURCE: replace washing machine bearings
To start, you can find the exploded view by entering the model number here.
Posted on Oct 19, 2008
Water will not drain. Wash programme runs normally to this point. There is a louder than normal noise when machine is attempting to drain
Basically, the drain pump is jambed due to an obstruction in the impellar. Dont retry untill pump is cleared or it will burn out.
Aug 05, 2010 | Zanussi IZ12 Front Load Washer
When switched on the door locks and the pump runs for a few seconds then stops and the door opens zwd 16270w
an earth fault on the motor or heater can cause this. try the heater first disconnecting it and seeing if the machine can get past the fill stage .
Jul 31, 2010 | Zanussi Washing Machines
My Zanussi ZWD 1470W won't fill up with water. I
Story could be lengthly so in brief, check to see if drain pump is not blocked and if door latch is functioning correctly.(use a multimeter if you can). If it all measures out as good, then your control is faulty. Does the water fill up to the correct level when you start the cycle? Does the motor hum when trying to run. If so check the capacitor.
May 20, 2010 | Zanussi ZWD1470W Front Load Washer / Dryer
Error e40 come up on my washing machine zwd 1472 s
E40 normally points to a fault at the door switch,sometimes when the door switch fault occurs it can also cause damage to the main P.C.B.(Programmer).As this machine is still in the major parts warranty it would be advisable to get in touch with Electrolux.
May 03, 2010 | Zanussi ZWD1470W Front Load Washer / Dryer
Machine is not washing, spinning or draining
has someone interfered with the inlet tap. The buzzing is normally a sign that the appliance is trying to take water but tap is off.
Mar 29, 2010 | Zanussi ZWF14070 Front Load Washer
Anussi ZWD 1271W stops at beginning of program
Did you fix this problem? We have the same with Zanussi ZWD 1472 W. It takes some water and stops after 2 minutes. We need to shut machine down and fill water manually. It works fine then.
Feb 02, 2010 | Zanussi Washing Machines
E20 code. Not draining
E20 is a general error code to get to the real problem try this..
Reading Error Codes 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold the START/PAUSE and CANCEL buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an “E” followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. let me know what code come up... hope it helps
Jun 06, 2009 | Zanussi ZWD1470W Front Load Washer / Dryer
I have problem E40 on Zanussi zwd 1680 w
E40 is door interlock error, it means that either the door interlock is stuck or faulty, or the wiring from door interlock to main control board are not connected.
Oct 03, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi washing machine wont spin
check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
Apr 23, 2008 | Zanussi ZWF1430W Front Load Washer
Washing Machines Logo
42 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
