Question about Garmin Forerunner 305 GPS Receiver
Pulse meter died on forerunner 305
I went to use the forerunner and was unable to get pulse readings. replaced battery but still no readings. not sure which way up battery goes nothing showing in manual being going for around 6 months before this problem.
  • ljking1 May 17, 2009
    after not using the pulse meter for 6 months I replaced the battery and it doesn't work. I tried another battery with the same results. batter goes in flat side up. I even tried cleaning the contacts with an eraser.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 84 Answers
You may need to re pair the unit with the heart rate monitor. Settings/ General/ Accessories/ Heat rate monitor. RESTART SCAN. OR follow this link (Hope it works) https://buy.garmin.com/shop/store/manual.jsp?product=010-00467-00&cID=142&pID=349 Go here and click on owners manual. Go to page 46. Adding accessories.
Posted on Jun 08, 2009
Can't find satillittes
Yes, resetting the Forerunner 305 would be just like resetting the Edge 305. If you are still unable to locate satellites with the Forerunner 305, please go to the following page on the Forerunner 305 Main Menu > Settings > General > About Forerunner and reply with your software version and GPS version.
HID KITS.
Jun 01, 2012 | GPS
My garmin forerunner 305 turns off automaticly after a couple of minutes, and the battery is fully charge.
Try SW reset. Hold Mode and lap/reset for 10 seconds, then release and long press start until device restarts.
Should clean up default.
If not try hard reset, but you'll loose all data in device.
hold mode and start for ten second, device needs to off before.
Then keeping these, pulse press lap/reset.
You'll get a confirmation screen
Oct 04, 2010 | Garmin Forerunner 305 GPS Receiver
Forerunner 305 keeps beeping, turning on and off every 5 seconds
I think I had the same problem. You do not write if your device were connected to the PC. My device was, and I finally got the suspicision, that it died because the battery was so low, that it crashed when the PC polled it as an usb unit.
So, I connected the unit directly to the charger unit that came with the unit, and now it works. So, try to connect directly to your charger, when your battery is totally drained.
Sep 16, 2009 | Garmin Forerunner 305 GPS Receiver
My garmin 305 dies when power is applied to charge or download
item returned to garmin europe after a phone call and diagnosis
Aug 01, 2009 | Garmin Forerunner 305 GPS Receiver
Forerunner 305 battery
it's been two weeks since i bought my IPOD ,but haven't played because of these battery problems.
Jul 27, 2008 | Garmin Forerunner 305 GPS Receiver
Forerunner 305 battery replacement
Automotive silicon/gasket maker.
Use a tooth pick to put a VERY small amount of silicon around the entire seam. Put the two half's together and wrap tightly with electrical tape. Test the unit immediately to see if it powers on and off. If it does not open it back up and raise the small prongs that make the connection from the bottom half to the top half.
If any silicon squishes out the sides wipe with water and a rag.
Let the unit sit over night. In the morning remove the tape.
Jul 14, 2008 | Garmin Forerunner 305 GPS Receiver
Garmin Forerunner 305 usb cable won't be read
The problem is probably not with the USB cable if the GPS wont even turn on. The older firmware of the Forerunner 205 and 305 have a problem with locking up. This causes the Forerunner to look completely dead. There is a reset procedure: push the mode and reset button at the same time and then let go and hit the power on button. If it powers on that is the problem. Go to the Garmin site and load the newest rev. of firmware into the Forerunner. Fixed mine and a few friends with the same problem.
I do however have a cable problem. Sometimes my PC will come up with unrecognized USB device and my 305 wont talk to the PC, it does charge. It is the cable or dock for sure, because I have tried a different cable/dock and the 305 has no problem. This is the reason I ended up here. I hope the lock fix works for those with the above problem.
Dec 16, 2007 | Garmin Forerunner 305 GPS Receiver
Garmin Forerunner 305 GPS Receiver Logo
497 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
