Question about Lancaster Colony Deluxe Coffee Urn 58 Cup
How much coffee do you use per cup in a Colony automatic 58 cup percolator?
SOURCE: Delivers only small amount of coffee per brewed cup
Same problem happened to me. There is a plastic boot inside the tank that is broken. This seals the top to the tank to the center rod. Keurig will not sell me the $5 part. They would would be glad to sell me a new brewer though!
Posted on Aug 17, 2006
  • 8 Answers
SOURCE: Gaggia espresso machine won't percolate
Does the steam outlet give water when coffee swith is engaged. If so when you get a flow going, shut the steam valve and water should eventually pout in the cup. If no water pours thru the steam pipe, it's pump failure or blocked wand. If no water at shower depending on last result same problems. Search web for solution i.e. google "jammed espresso machine"
Posted on Dec 30, 2007
SOURCE: How to make coffee with 101-cup percolator urn (Regalware)?
Simply fill with COLD water to the number of cups desired.
Place the stem and basket in the pot and put one 8 oz cup of coffee for every 20 cups of water into the basket...when doing 100 cups I add an extra 12 oz of coffee for a good coffee flavor.
Place the perforated lid on the coffee basket that is in the pot (if there is a lid--some do not have a lid). Put the cover for the coffee pot in place.
Plug in.
Turn on if there is a switch.
Give these large pots about 1 minute per cup, brewing time...that is a little over an hour usually to brew 100 cups. The coffee maker will percolate with the water coming up through the stem and over the coffee as the water heats. Usually there is an indicator light that comes on when it is finished.
If holding the coffee for awhile, it tastes best if you remove the stem and basket and it will maintain the heat without doing more "perking" and becoming stronger or bitter.
Be sure to wash it out and dry it well, leaving the lid loose or upside down for storage so that the pot doesn't become pitted. Blessings, Louise
Posted on Jan 15, 2009
  • 33 Answers
SOURCE: General Electric Electric Coffee Percolator
sure thing Fred
Try this
to order all of your part needs
http://www.abtecparts.com/Westbend_Percolators_51000.htm
Please don’t forget to rate me.
eric
Posted on Feb 16, 2009
  • 134 Answers
SOURCE: I need a replacement rubber gasket for Six cup Cafetera Isabella
HI
You need to contact the manufacturer here
http://www.valira.com/eng/index.html
Posted on Feb 19, 2009
How to brew coffee
USING YOUR PERCOLATOR
1.Wash the Percolator thoroughly before using for the first time.
(See "Cleaning Instructions" section in this manual.)
2.Remove Cover, Basket, Spreader and Pump Tube. Use cold, fresh
tap water to fill Percolator. Fill according to markings on inside
of Percolator for number of cups desired. Use cold tap water -
the automatic brewing cycle is timed to begin with a cold
water start.
NOTE: The bottom of the Pump Tube Spring marks the maximum
capacity of the Percolator.
3.Wet Coffee Basket to help keep small particles of coffee from sift-
ing through. Place Basket on Pump Tube. Add desired amount of
regular or percolator grind coffee to Basket.
4.Place Pump Tube with Basket into Percolator so bottom of tube is
set into Center Well. Place Spreader on top of Basket and snap
Cover onto Percolator. Attach cord to Percolator and plug into
standard household 120 volt AC wall outlet. Brewing begins
within seconds and continues at a cup-a-minute speed
5.When coffee brewing is complete, percolating will stop. The
Percolator automatically switches to "KEEP WARM" setting to
preserve fresh-tasting coffee at hot, ready-to-serve temperature.
For best flavor, remove Coffee Basket, Spreader and Pump Tube
when brewing is completed.
Aug 04, 2014 | Faberware FCP280 Coffee Maker
Vintage farberware percolator does not stop percolating
There is a thermostat in the bottom of the percolator that is broken. It would normally cut off the percolator heating element after the water reaches a certain temperature. It can be replaced but it takes a little skill. There is a video on eBay.
If you want to just unplug the percolator, time it for 1 minute per cup.
Jan 25, 2014 | Faberware Coffee Makers & Espresso...
Farberware millenium coffee percolator does not heat
There is a thermostat in the bottom of the percolator that is broken. It would normally cut in to perc the coffee and then cut off the percolator heating element after the water reaches a certain temperature. It can be replaced but it takes a little skill. There is a video on eBay.
If you want to bypass the thermostat and just unplug the percolator, time it for 1 minute per cup.
Mar 04, 2013 | Farberware Coffee Makers & Espresso...
WE HAVE OLDER LANDCASTER 90 CUP POT AND THE SPOUT LEAKS. CAN WE PUT NEW GUTS IN IT OR REPL;ACE THE HOLE THANG
Hi, am sure that all it needs is to be cleaned. Gently take it apart, clean the parts, use a soft brush if needed and put it back together and if it still leaks, it is advisable to replace it....
Jan 16, 2011 | Lancaster Colony Deluxe Coffee Urn 58 Cup
Looking for percolator tube for 90 cup urn
Hey, sorry I don't have a solution, but a question! Do you still have the manual?? I have the same maker and woudl like some advice on making 90 cups of coffee before I have caffeine deprived angry guests on my hands.
Jul 28, 2010 | Lancaster Colony Deluxe Coffee Urn 58 Cup
How many scoops per cup?
Hi. normal is 2 scoops of coffee for 3 cups of coffee, then adjust from there for your taste. Good luck.
May 23, 2010 | Faberware FCP280 Coffee Maker
West Bend 36 cup coffee maker amounts
It's a percolator. Use about 1 heaping teaspoon of coffee per cup. Each coffee pot is different. You will have to adjust the amount of coffee for what you like.
Dec 03, 2007 | West Bend (58036) 36-Cup Coffee Maker
Lancaster Colony Deluxe Coffee Urn 58 Cup Logo
Top Lancaster Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Lancaster Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
