Question about Seagate Momentus 5400.3 ST9120822A - 120GB - 5400rpm - Ultra ATA/100 (ATA-6) - IDE/EIDE -... 120 GB Hard Drive
My hdd was locked, i unknown password, help, please
Forgot password hdd is locked
Unlock and Recover Hard Drive Password with Hard Disk ...
www.geckoandfly.com > Tutorials > Password and Recovery
Nov 18, 2015 - Is there any software to recover hard drive disk password? ... HDD Unlock Wizard is a user-friendly application which allows you to easily remove HDD password. ... HDD Unlock Wizard incorporates proprietary unlocking algorithms which allow removing an unknown HDD password and making hard ...
Unlocking a locked hard disk (lost password) - Straight ...
Dec 02, 2015 | Lenovo IdeaPad S10-3 Netbook
Password retrievable
These WEB sites may unlock the hard drive password.
HARD DRIVE PASSWORD UNLOCKING - Purchase
http://www.hddunlock.com/purchase/ A-FF HDD Unlock Wizard (HDD Password unlocking - Free)
http://www.hddunlock.com/download/
Jan 07, 2013 | Seagate Momentus 54006 (ST9250315AS) 250...
I forgot my password for my buffalo hd-pntu3 what will i do i don't want to delete my data
Download the
HDD Unlock Wizard HDD Unlock Wizard v4.2 http://www.filebuzz.com/publisher/download.php?id=98078
HDD Unlock Wizard is a window based utility.
It works as a new life for your locked hard disks, as it is competent to unlock almost all hard disks of major brands available in market.
Its proprietary unlocking algorithms can remove any unknown HDD password and you do not required to give any hint of password as it is not working as a normal password cracker tool.
Removal of a HDD password is a slow process and total time required to remove HDD password is depending on the size of the hard disk and type of hard disk.
A small 2.5" notebook hard disk takes more time as compared to normal Desktop hard disk.
Presently it supports IDE and SATA hard disks.
hope this helps
also you might try
http://download.cnet.com/siw-portable/3000-2094_4-75449686.html
Software Inventory: Operating System, Installed Software and Hotfixes, Processes, Services, Users, Open Files, System Uptime, Installed Codecs, Software Licenses (Product Keys / Serial Numbers / CD Key), Passwords Recovery.
Oct 12, 2012 | Buffalo Jeans Buffalo Technology...
Hi, I have a locked Hitachi HDD and don't let me to format. Can you help me please?
You can't unlock your hdd at home. Go to a professional, or get the original password, only that way you can unlock it.
Dec 26, 2011 | Hitachi Computers & Internet
Dell Latitude D620 "Hard disk #DPOXKKP7P7M-595B, the system primary HDD, is protected by a password authentication system..." -service tag: DZMBTB1... Can u please help me with unlocking?
I think there is a new feature on later notebooks, called "drive-lock".
It uses a password to lock the hdd, even if the hdd is swapped to another PC.
You might be able to get round it, if you connect it to an old Laptop or Desktop, where the bios doesn't support "drive-lock".
Or you could try "Ultimate Boot CD" from http://www.ultimatebootcd.com/
This will allow you to make a boot CD.
You could then try the program called "ATA Password Tool 1.1", which is supposed to unlock any locked hdd.
And if that doesn't work you'll need to call up dell.
Sep 26, 2010 | Computers & Internet
Hi I can not unluck my maxtor external hard driver, which requires password. May you please help?
According to Lenovo and many other manufacturers’ website, if you forget your hard drive or hard disk password, there is no possible way to reset your password or recover data in the hard disk drive. Basically the hard drive is unusable. Scary right? However, this is often not true.
Most people are not aware that most hard disk drives have the ability to set a hardware password, just like the Bios password for motherboards, thus making the drive completely inaccessible unless a correct password is provided during the BIOS POST test. Usually these features can only be found in laptops, this is when you set a password on your notebook, the hard drive together with the motherboard becomes locked.
Most experts would say if you forget the original HDD or Bios password, there is no way of restoring it by generic system tools. Unlike the Bios password where there is a master key or with the removal of the bios battery, the password is erased from the flash memory thus the settings is restored to factory settings without the password, however, this does not applies to hard disk.
unlock_recover_remove_tool_hdd_hard_disk_drive_password_software.jpgHDD Unlock Wizard is a user-friendly application which allows you to easily remove HDD password. IDE and SATA hard disk drives are supported. Both User and Master password can be removed. Please note that while unlocking, Remember HDD Unlock Wizard will erase and re-certify the drive, meaning to say all data in the disk is lost and not recoverable. HDD Unlock Wizard incorporates proprietary unlocking algorithms which allow removing an unknown HDD password and making hard drive usable again.
Download Hdd Unlock Wizard from here
It may not be possible to recover the hard drive password or to unlock it; however, it is possible to remove the password together with the data, thus making your hard disk accessible and usable again.
Or Try Hiren's boot cd in this there is a operating system which boot from direct your cd/dvd rom. try it if it may open your locked external disk. And if your hard disk open in it just copy the data from the drive to any other drives and after copying your data format it. Then you see there is no password dialog box open in your normal windows log in.And for future if you use any software for password protection try to memorize the password in your mind or write it somewhere.
You can contact me or thanks me on my email id ejaz89@live.com
Aug 05, 2010 | Computers & Internet
My dell inspiron1525 laptop isn't working and its asking me for the hdd password that I have no idea what its is or what it means cause I didn't put one. What can I do to fix it and get the password with...
if the hdd was in the inspiron when it got locked and was not locked by another comp please send me ur lock code
should look something like ###HYGF2FR-595B and maye i can help
Jun 20, 2010 | Dell Inspiron 1525 Laptop
How do i get passed my hdd user password i forgot the password
A couple of days ago, I lost my windows vista admin password. I solved the problem with the help of Windows Password Seeker. Not just support XP/Vista/2000/NT, but also compatible with windows 7, I tested it on my computer installed with Windows 7 and remove the local user and admin accounts password successfully. It's worth trying. You can download it from: http://www.passwordseeker.com/howtouse.html
May 19, 2010 | Toshiba Satellite A205-S4617 Notebook
Forgotten HDD password on Dell Vostro 1510
If it truly is the HDD password, Dell will be of no help to you, as they have no control over the HDD Password; the password is stored in a hidden sector on the HDD itself.
The only people that could help you with that is the manufacturer of the HDD, and odds are they won't help you. It would involve sending the drive back to the manufacturer, and paying them a heft fee to unlock it. It would be returned to you, but would be blank, as they have no way of knowing that the data on it truly belongs to you.
Today happens to be your lucky day however, as I stumbled upon what seems to be a very useful piece of software. There are many restrictions with it's use, so make sure you can manage this. It would involve you connecting your laptop drive into a desktop system in order to perform the task of unlocking, only works with certain drives, and has been known to not work on some Dell HDDs, amongst many other things. Link is below..
There is a reason people put passwords on the HDD, and that is for total security... Good Luck my man, good luck!
Password Removal Software
Dec 29, 2009 | Dell Vostro 1510 Laptop
Hdd password
What is HDD Password? All hard disk drives have the possibility to set a hardware password, thus making the drive completely inaccessible unless a correct password is provided during the BIOS POST test. When you set a password on your notebook, the drive becomes locked as well. XBox gaming consoles and some desktop computers can also lock hard disk drives. This is usually called "HDD password" or "ATA password".
If you forget the original HDD password, there is no way of restoring it by generic system tools. HDD Unlock Wizard incorporates proprietary unlocking algorithms which allow to remove an unknown HDD password and make hard drive usable again.
I have a software enable to reset the password security on your harddriver but you need to pay my professional charge. If sound interested please email diazphi@gmail.com.
Please rate me solved if you like my solution.
Best regards,
Philip
Oct 30, 2007 | Toshiba Satellite Pro 6000 and 6100 14.1...
Seagate Momentus 5400.3 ST9120822A - 120GB - 5400rpm - Ultra ATA/100 (ATA-6) - IDE/EIDE -... 120 GB Hard Drive Logo
79 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
