Mitsubishi HD1080 Hi. When I turn my HD1080 on the green power light comes on and then goes out. Tv never comes on. I removed the lower grill and gently pushed on the powerboard with a rubber stick and tv came on for few secs and I heard fizzle comeing from that powerboard. How came I find a powerboard for it? Thanks For Any Help! Rick rpclearwater@verizon.net
  • 1 more comment
  • helprick Jun 15, 2008
    Its a Mitsubishi HD1080 55 inch rear projection. Thanks
    Oh Im sorry. Its a WS-55313. Thanks Rick
  • 4durango Apr 04, 2009
    my tv can be on for a few minutes then shuts off. you can try to turn it on but it will turn off immidiatly. if you wait about ten minutes and then turn it on it willstay on for awile. can you let me know what could be wrong thanks greg
  • 8,617 Answers
I will need to know your model number in orderto help you locate a PC board for it.
Posted on Jun 15, 2008
  • Sonny Berry
    Sonny Berry Jun 15, 2008
    I will still need the actual model number of your set as you could have anyone of the 100 different model numbers in the HD1080 series. The model number is on the rear tag.
  • Sonny Berry
    I am sending an illustration of your chassis to your email address if you can let me know which board it is youre looking for from the diagram I will be able to help you.
My Mitsubishi hd1080 tv will not come on when i turn the power button on the green timer light comes on but the tv goes back off
The TV reset may help you. If the timer was set by accident many of these TV's that have the sleep timer have this problem. Try the factory reset initialization.
Nov 19, 2014 | Televison & Video
Mitsubishi Medallion does this
hi there,
Check for bad solder on convergence module. May have bad stk's. Do not neglect looking for bad solder on dsignal and defl boards. Mitsubishi is very prone to bad solder.
`jack
May 26, 2008 | Mitsubishi WS-55411 55" Rear Projection...
2001 Mitsubishi 65 inch HD1080 rear projection. When I turn it on, green light comes on for 2 seconds then it turns itself off. No flashing green light like others I read about.
Ok, try this first. After attempting to turn on set after it shuts off push and hold the MENU and INPUT buttons at the same time on the front of the set for 10 seconds. This should acccuate the self diagnostics function in the micro and the power LED should start blinking a two sequence code. That code will narrow things down.
Jun 03, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Won't come on
The power board has failed and will need to be repaired or replaced. you can remove this board and, replace individual parts and save a lot of money. You will be inspecting for swollen capacitors and resistors. also, look for discolorations on the board itself.
Feb 19, 2009 | Mitsubishi WS-55807 TV
HELP
how many times does it blink it should blink a two digit code. let me know the sequence of blinks as it should be a self diagnosis code
May 20, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Tv mitsubishi ws55311
Remove front lower speaker grill,then remove access panel =
unplug white connector ( goes to front controls )......Does the set
work now with remote ?...= bad tactil switch on front panel......T.
Apr 23, 2008 | Mitsubishi WS-55513 55" Rear Projection...
HD1080 65inc.mitsubishi
Hello hope. Try pushing in the input and menu buttons on the set and hold them both in together for 8 seconds to see if the Led will blink a two digit code then let me know what that code says. I can get you a link where to get a new power supply, but that may not be your problem. Try this test an see what the led blinks if anything then let me know I will try to help you determine whats wrong. I am a specialist with mitsubishi projection units.
Apr 07, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi HD1080 60in TV
First do a self test diagnosis. you can search Mits tv or read my solutions.
Mar 10, 2008 | Mitsubishi VS-60609 60" Rear Projection...
Mitsubishi HD1080 TV will not turn on.
On my Mitsubishi WD65-613 it was 4 capacitors on the DM board. They are 1000mf 16v, replaced with 4 1000mf 25v. TV is working great.
Nov 02, 2007 | Mitsubishi WS-65615 65" TV
Televison & Video Logo
300 people viewed this question
Top Televison & Video Experts
