Question about Jandy AQUALINK RS TELELINK KIT
Jandy Aqua Link system turns on the spa without being programmed
    Top Expert:
  • Jandy Master
  • 4,292 Answers
Check spa side remote disconnect if it quits replace remote
Posted on Apr 25, 2016
  • 22 Answers
SOURCE: jandy aqua link main control box
Do you have a 4 button switch in the spa and is the light on the button that is slightly under water? If so , the button is bad as the water is completing the circuit and turning the light on and off.
Repalce the button or disconnect it at the outdoor panel.
Posted on Dec 21, 2008
  • 128 Answers
SOURCE: We have the Jandy AquaLink RS PDA, we have two
If you have a spa side remote unplug it at the outside control panel. If the problem stops it's the remote
Posted on Aug 30, 2009
  • 5 Answers
SOURCE: I have Jandy RS4 system with 4-button poolside
Pull the cover off the control panel. You will probably find a button which would be accessible from outside the panel with a paper clip or pencil but is unlabeled. On the board itself by the button, in small letters it should say "reset". Push the button and see what happens.
Posted on Oct 09, 2009
  • 8404 Answers
SOURCE: Jandy Aqualink RS4 randomly turns on blower, pump, heater
Re program your assorted timer functions and make sure you set AM and PM or use a 24 hour clock. I think your model allows for a 24 hour clock setting but I am not certain.
I hope this helps you
a
  • 10 Answers
SOURCE: I have a Jandy Laars LX Pool/Spa Heater...when I
If the unit is lighting then shutting off then repeating it isn't rectifying, means not sensing the flame. May have a bad flame sensor or ignition control. I'm guessing your AGS is indicated on the GUI also.
Posted on Mar 07, 2010
How do I wire two seperate Heaters to a jandy Aqua link rs 2/6?
need more info on why you have 2 heaters if for the same body of water hook them up parallel and the firemans switches go from each heater to 1 and 2 pins on the big plug if set for pool and spa then pool to 1 and 2 and spa heater to solar to turn on
May 17, 2016 | Jandy Pool & Spa
Jandy PDA PS4 Firmware 4.1 Date reads 10/10/14 "SAT"should be Friday.
go into system setup then find time and date reset to correct if every time the power goes out it is wrong you need to replace the battery backup either a 9 volt or a nicad on back of PCB board
Oct 10, 2014 | Jandy Aqua Link RS PDA-P4 - PDA for...
Why does my Jandy Aqualink alarm keep beeping?
if it has a aqua pure and it isnt working turn chlorine production to 0 and then get it fixed
May 24, 2014 | Jandy Aqualink - Rs32 One Touch Pool / Spa...
Cannot find reset button on aqua link rs system
top left of control panel there is a reset button make sure to write down all your auxillaries and programming because if you reset make sure to go into controller and clear memory also
Aug 13, 2013 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jandy aqua link , message 6521 rev hh. How do I resolve?
check 4 pin connectors see if shorted or see if wires cut
Sep 15, 2012 | Jandy Aqualink RS6 Pool Only/Spa Only...
Jandy PDA-PS4 lost link to salt system?? There is no more
go to system setup find aqua pure up setting from 0 to something and it will apear
May 27, 2012 | Jandy Aqualink Pda Ps4 Wireless Handheld...
I have a Aqua link RS4, now 13 years old. The pool will switch to the spa mode by itself, no human intervention. Any thoughts.
its most lke a problem called ghosting which mean your spa side remote will turn system to spa mode or turn other thing on such as the blower or heater will come on without manualy turning it on to fix this problem open up outside control panel and unplug the four connection wire hooked on a red bar plug tape the ends after unplugging so nothing will get shorted also turn of breaker as well so guarnting no shortage
Jan 28, 2011 | Jandy AQUALINK RS TELELINK KIT
Jandy AQUALINK RS TELELINK KIT  Logo
42 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
