Question about Amana Heating & Cooling
Amana pgd42c0902e gas package unit works with no problems until temp outside drops into the 40"s shows no fault codes on control board.can not catch have set for hours....THANKS,JEFF
5 Suggested Answers
  • 85 Answers
SOURCE: ac/heating unit not working properly.
Check your filters, make sure they are not dirty. Make sure your outdoor sensor is working properly. If it is then check the setting on the defrost timer. If you don't know how, you'll have to call an expert to come fix it. Diagnostic fees generally are around 65 to 125 depending on time and contractor.
Posted on Dec 06, 2008
  • 137 Answers
SOURCE: outside temp stuck on -40
when its at -40 usually its because the ambient temp sensor is not sending the proper signal to the controller.. it may just be disconnected.. the sensor it behind the grille.. it has a 2 wire connector to it ... itf its connected it may havea broken wire from body damage in an accident... its rare that the sensor fails..
Posted on Feb 04, 2009
shastalaker7
  • 1515 Answers
SOURCE: Armstrong Heat pump Package Unit, Model#1B36DA-9B,
Hi, the outdoor unit will start to freeze when it is cold outside, but also it should go into a defrost mode to melt this ice either by the defrost board or defrost thermostat. You will know as steam will rise like smoke and some folks think it is on fire. If it never goes into defrost, get back to us and we can go through some things to check. Merry Christmas,
Shastalaker7
Posted on Dec 24, 2009
bep86
  • 142 Answers
SOURCE: My 1992 accord does not blow.heat when outside
If you have heat when its above 40 degrees most likely your problem is a bad thermostat, when it gets VERY cold out the engine cannot reach proper operating temperature to maintain heat quality because the thermostat is more then likely stuck in the open or partially **** in the open position....
Posted on Dec 07, 2010
Heater will not activate until outside temp. is above 40 degrees
If you have a heat pump the compressor is locked out below that temp. If you have a dual fuel - hp/gas, the gas burners should come on as would the electric heaters if you have electric heat as backup.
Jan 19, 2016 | Heating & Cooling
Freezer is cold but food isn't frozen
Deforst freezer and ref. wipe dry. Reset controls to starting point.
Check temp. 0 in fez. 38-40 in ref. keep advancing settings until you reach temp. Also, vaccum behind unit
May 02, 2014 | Amana 22.6 cu. ft. Side-By-Side...
Amana Packaged Gas Unit Not Blowing Cold Air
There may be a capacitor on the outside of the compressor that needs to be replaced. You would have to take it apart to see.
Jun 04, 2013 | Amana Heating & Cooling
1.Our gaz range (with electronic range control) Amana ACS3350AS oven bake works normally at 350 F for 40 minutes, then stops. While the broil can still work at this point, it's likely the Oven - High...
Works normally for 40 minutes? Then after she cool down will work again? Let me look un momento mon ami. Aha Your temp sensor might be faulty,
Another thang it could be is a weak ignitor,
An oven limit would shut down and NEVER come back to life. It ain't gonna be no limit er fuse.
Basic American oven fault codes and more HERE
Feb 11, 2011 | Amana ACS3350 Gas Kitchen Range
Ovens temps are generally controlled by a probe with two wires called the oven probe(1100 ohms at room temperature for a good one) This probe connects to the main erc control board, which as temperature rises, it changes resistance reading, which is read by the board.......These usually show a fault code on the display when one fails........
The oven ignitor is glowing which ignites the flame. Usually this has to read between 3 to 3.5 amps to be good. (can be 2 or 2.5 and glow and the gas valve will not open) If the ignitor is glowing after 40 minutes, it is most likely the ignitor is bad. (the broil has a separate one, the bake has a separate one) If you do not have a amp clamp to test, you will need to replace part and see what happens, if it fixes problem.......good luck (it could be a sticking gas valve or relay but the ignitor is the most common failure, fragile part also, do not drop it)
Its 15 degrees outside and my amana unit is off. every so often it kicks on by itself and runs for about 10 seconds then shuts off again. while it is running the control panel flashes FP, what is it trying...
I was wondering the same thing about our unit until I found the specs online and read that it has freeze protection. When the temp goes below 40 degrees, the fan comes on to prevent damage to the unit.
Dec 23, 2009 | Amana PTH123B25AJ Heat Pump Air...
AMANA PTH153B35AE PTAC Temp drop??
PTAC temp drop should be 20 to 25 degrees across the coil. They never put a service tap on these units. I sell Amana PTACs. You may be alittle low on gas. Check your air TD and that will tell you. The compressor may be overheating due to lack of cool gas to cool the comp. May need a service tech but get a free estimate first. Rus
Jul 04, 2009 | GE Zoneline AZ55H07D Air Conditioner
Minimaxpower on but fails to start no error code just flashes off
hi, it seems like a component malfunction, Try a hard reset Just unplug the power cord for 30 minutes or more, then try again.
May 07, 2009 | Pentair Minimax NT Heater
Ac/heating unit not working properly. If the temp outside drops to around 40 degrees the unit will shut off and not come back on until temp outside rises to above 60
Dec 06, 2008 | Heating & Cooling
F2 on Amana ARGS7650SS
well the f2 code on an amana is an over overheat fault code. the best thing to do is replace the oven temperature sensor.
it looks like this
http://www.partselect.com/xq/aspx/Inventory.1508183/qx/PartDetail.htm?SourceCode=5&ModelNum=ARGS7650SS
they cost around 40 dollars but that should eliminate your problem
Jun 20, 2008 | Amana ARGS7650SS Gas Kitchen Range
Heating & Cooling Logo
202 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
