Question about GE Profile 25.1 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - Stainless-Steel
Ge profile fridge side by side makes only 8 ice cubes per day
    President:
  • 1,218 Answers
Good day,
Assuming the temperature in the freezer is normal. 10 degrees or less. then it should be one of the 3 items here.
1. Partially plugged filter.
2. Water valve in the back bottom of the machine failing to open properly.
3. Partially blocked supply line from the house or it's connection fittings which ar more common than the line itself.
As well, if the water fill valve has a small leak on the off cycle, the fill tube running from the outside back of the machine that supplies water to the ice maker cavity may have ice starting to cause a blockage.
Posted on Nov 06, 2010
GE Profile REfrigerator: Model PFSS6PKWASS Problem with loud clicking coming from icemaker every 2-3 seconds. Will do this for 30-60 minutes constatntly, then will stop clicking for the same period of...
i have same fridge with same prob makes 6 cubes of ice in a day with a lot of noise like you discribed also i have water collecting under crisper drawer of fridge i have to clean out water once a month or so still trying to figure out how to take ice maker out to fix
Jan 25, 2011 | GE Profile 26.6 cu. ft. Side-by-Side...
Our ice maker is making 5-10 cubes per day. Ice
OK, Have a look (if you can) and see if one of the water jets might be broken, or if there might be a defect in the tray. I can't help any further i'm afraid.
Apr 14, 2010 | GE Profile 25.1 Cu. Ft. Side-by-Side...
Our GE Profile side by side refrigerator is making hollow ice cubes and the water dispenser comes on by itself sporadically for about 3 seconds a few times a day. Over night it filled a whole glass of...
Hello. Hollow cubes is caused when there is not enough water going into the ice cube molds. That said, since you have too much water going into the water dispenser I would suspect that the valve needs to be cleaned or possibly replaced. Joe
Mar 27, 2010 | GE Profile¿ Arctica® Energy...
PSS23MSTC GE PROFILE WATER WORKS, ICE CRUSHED ICE INDICATOR LIGHT DIMS NO ICE IDEAS?
clean built up ice in the door where ice comes out.....make sure the metal bar is down. its located inside the tray where the stored ice is.
Nov 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
Aug 04, 2009 | GE Profile Arctica 25.4 Cubic Feet...
My icemaker, a ge profile is only making crushed ice, no cubes,
There is a selector for crushed or cube and is usually at the dispensor.or above it. good luck
May 26, 2009 | GE Profile PSW26P Stainless Steel Side by...
New GE profile Fridge Ice maker is very inefficiant for two people we have 3 drinks each and no ice
yea you ned to figure that the ice makler probalby makes 8 ice cubes every 2.5---3 hours. so if your filling a glass with ice, more then 8 cubes, the machines gonna take 3 hours to replace that!!!all machines regardlees of manufacture take a long time to produce ice
Apr 09, 2008 | Refrigerators
Ice maker not working
check your owners manual for a water filter, make sure trip arm isn't stuck closed and not letting water in to freeze.
Dec 08, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Stainless Steel side by side fridge GS425JSRF - 2 ys old
Make sure there is no obstructions from the time the ice leaves the chute until it drops into the glass. make sure the motor that moves ice and out to the area for the cup is stuck or seized up let us know thanks
Aug 25, 2007 | GE Profile PSW26P Stainless Steel Side by...
GE Profile 25.1 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - Stainless-Steel Logo
102 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
