Question about Intertherm Heating & Cooling
Is there a reset button on an intertherm furnance model g5ra0963-16. if so where is it located. thanks
3 Suggested Answers
  • 96 Answers
SOURCE: Where can I find a
Have you looked on the back side of the silver cover that is covering up the relays and sequencers in the lower left of the furnace
Posted on Dec 06, 2008
  • 30 Answers
SOURCE: need help bad!!!!
try to google it at best but chances are you will need to contact intertherm directly and order one. what is wrong with your unit?
Posted on Jan 05, 2009
Our intertherm furnance is clicking twice before the burner lights. Why?
If your unit has a spark igniter you'll hear clicking noises until the flame is lit. If it hasn't done this in the past, then its quite possible the igniter is starting to oxidize and needs to be cleaned. The best way to do this is use a light abrasive cloth to remove the oxidation, or otherwise known as soot. Sometimes, the igniter needs to be removed and as always remove power to the system before attempting any repairs.
Jan 22, 2017 | Intertherm Heating & Cooling
Intertherm furnis doesnt light just replaced the glow rod
WHY! Most of the time, all you have to do is reset the high-limit switch located next to the fan motor. Jst remove the front cover, and locate the fan motor and look for a switch and push down the littlie button in the middle to reset it.Now,Why did it tripped, thats the problem! It,s trying to tell you ,I,m starving for fresh air, check my filters, they,re stopping up! T Y V M !
Dec 14, 2009 | Intertherm Heating & Cooling
Intertherm furnace pilot won't light
if there are two wires to gas valve check voltage between these two wires while the furnace is going through a start up if you never get a call or voltage to valve your control board is bad, if you are getting voltage ,your valve is bad
Sep 29, 2009 | Intertherm P3RA-048K Air Conditioner
I need to find the wiring diagram for a intertherm furnance e2eh-012ha
Here is the manufature link. They will email you the manual directly.
http://www.intertherm.net/
Aug 18, 2009 | Heating & Cooling
I have a intertherm model feh-017h electric
It's the heat kit in the unit that is causing the problem. You need to do a continuity test on it to eleminate that they have shorted. This is the only thing in an electric furnace that will blow a fuse on it. Intertherm is a Nordyne product for manufactured homes. Of coarse they still sell them! I am a Nordyne dealer. Also a sequencer can not cause a fuse to blow. The service guy just wants to make money from you by installing a new unit. You can either re-wire the heat kit or you can purchase a new one and have it installed. If you are referring to the heat kit for 159.00, then that's a fair price for it if you are a non licensed person.
Mar 17, 2009 | Heating & Cooling
Intertherm e3eb020h electric furnance won't start just hums
it was the thermstat i replaced the thermstat
thank you
Dec 03, 2008 | Heating & Cooling
Indoor fan motor continue to run even if the thermostat is in auto position with the cool and heat switch in the off position. The furnance don't have a fan on and off switch in the furnance like most....
Try this, disconnect the fanwire (green) on the furnace, if it shuts off then the hot wire from the thermostat is touching the green wire or bad thermostat. Thank-you-very-much!
Aug 26, 2008 | Intertherm Heating & Cooling
Reset Button
There is no reset button on most of these units. If nothing is running at all when a call from cooling from the thermostat is made your problem could be a tripped or breaker in the off position. When you turn the thermostat to cool have someone listen for a click at the unit. If no click is heard it may be in the low voltage circuit that your problem is. If a click is heard which is the main contactor pulling in to run then your problem may be in the high voltage power supply. If you have a fused disconnect check the fuses. They should be of the time delay type (slow blow) and sized according to the ampacity on the unit name plate. Also check the main breaker in the house power panel.
May 22, 2008 | Intertherm P3RA-030K Air Conditioner
Heating & Cooling Logo
21 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
