I need a power supply replacement for a Dual CS455-1 turntable. I need to know amperage and polarity or where i can order an original. Thanks!
IB4G2008
  • 3587 Answers
SOURCE: Dual Voltage (5v / 12v) Sirius Hardwired Car Power Supply
Click here first for installation guide
Posted on Feb 11, 2008
SOURCE: Power For WD 5000H1U Drive
http://support.moonpoint.com/hardware/power/adapters/
kevin
Posted on Jan 28, 2009
  • 298 Answers
SOURCE: Need to know polarity of power supply for JBL
Look where the plug goes in
There will be a C shape with a dot in the middle. Follow the line attached to the dot and you will see a + or - which is the polarity. Next you need to know Voltage. Look in the same area, or on the label for this info. If there is NO info by the power plug, it might be AC, which has no polarity - just plug it in. The label may have this information and will say something like 12VDC or 12VAC that is the key. DC Matters (+ and -) AC does not.
Posted on Mar 26, 2009
SOURCE: Want to know polarity of Zip 100 DC power supply.
I just connected a new power supply to my zip 250MB, with the center pin as positive - and it worked out well :-)
Posted on Apr 21, 2009
  • 20 Answers
SOURCE: What voltage and amperage the western digital
Mine has a 12V 4A power supply. This is not generally available as a generic replacement, due to the high current required. Good luck!
Posted on Mar 01, 2010
What power supply do I need for a JVC AL-E300BK turntable?
That label on the lower right of your photo shows the polarity connections. It looks like the (+) is on the inner connector and the (-) is on the outer or shell. You need a 12 volt power supply of at least 1 amp rating. You can buy a power supply from radio shack that will have different plugs so you can choose the one that fits. Just make sure the polarity is set correctly. If your not sure bring the turntable into radio shack and ask him for a power supply for it.
Dec 20, 2014 | JVC Audio Players & Recorders
What is the output voltage, amperage, watts and polarity for Schwinn 203 recumbent bike? I have a pile of transformers and don't know which one my mother-in-law used. Thanks for all replies.
If the recumbent digital computer gives you an option of power supply or batteries then you can deduce voltage of the power supply by counting the number of batteries needed times 1.5 (1.5 volts = voltage of AA or AAA battery).
You can deduce typical current by multiplying the number of batteries by: AA = .05 amps or AAA = .01 amps.
Your next issue will be to deduce the polarity. Look at the Schwinn to look for a symbol that will show you polarity. Typically the center of the plug is: + positive and the outer shell is - negative. There are instances where those two are reversed.
If this is all too confusing then Google the recumbent model number to find replacement power supplies ($35 to $45 US).
Nov 28, 2014 | Schwinn Cycling
I need a charger for Remington HC5550, where I can find one or to repait mine? Thanks
As long as you know the ratings of the powers supply (if you still have the old one) they should be marked on it. You can use any power supply that will fit as long as the voltage is the same and the amperage is the same or higher. If you get one with the wrong end on it, just swap the ends, paying attention to the polarity.
Aug 14, 2014 | Health & Beauty
Misplaced my power supply for my 1950x pencil sharpener and can`t find the output or polarity labeled on the thing?
I have the same sharpener. Input is 120v AC 60Hz 16W which is what comes out of the wall in USA.
Output is 12V 800mA and the polarity is positive in the inside of the plug. I'll try to attach a photo to this post.
misplaced-power-supply-1950x-pencil#solution-section-kjptrdwcwv032w1lziamb525-3-0.jpg
Mar 02, 2014 | Boston Acoustics Mighty Mite Electric...
Need to replace power cord - Technics 1200 MK2
As long as the only thing damaged is the power cord, this should be easy. You said that you needed to know how to tell which side is positive and which is negative? The power cord carries alternating current not direct current. So in this case, polarity really isn't important. The same applies to the two yellow wires supplying the main motor board. They are A/C too. As long as the replacement cord you use is of equal or higher power handeling, and you make sure your connections are solid, it will work fine regardless of polarity. Just be sure the only problem is the cord. Check this link to be sure. Good luck, EW.
This link is a must have for anybody diagnosing a problem with a SL1200/1210. Take a look:
http://www.deckdoctor.com.au/TECHNIC%20SL1200%20PCB.pdf
Apr 28, 2013 | Technics SL-1200MK2 Turntable
I have a JVC AL E31BK turntable that I want to connect up to my system. I need a power adaptor for it. It says it requires 11-13volts but I don't know the amperage required. I don't want to use the wrong...
Normally these low power turntables connect to a unit audio system that supplies them with power. If you find out that you should be able to track down the specifications of it.
Jan 08, 2011 | Audio Players & Recorders
Adaptor is not working
Hi I am Vortash .. most likely if you go along to your local Radioshack , Maplins or any other Electronics outlet and take your old Adaptor with you they will be able to supply you with an equivalent based on the Voltage and amperage and polarity information on the original adaptor specs label .. Regards Vortash
Mar 30, 2010 | Televison & Video
I need to know if there is still some were to purchase and Ac Adapter for a Balance LCD Monitor CM2019?????????
All you need to know is:
- The output voltage (usually 12V)
- The rated output current (usually above 5A)
- The plug polarity (usually plus on the inside)
Then just purchase any replacement AC adapter that has the same voltage, same plug polarity and rated current preferrably more (at least 120%) of the original.
That's it.
You can buy them online, for example at http://www.12vadapters.com/
Dec 24, 2009 | Balance CM2019 19" LCD Monitor
What is the voltage, current, and polarity of the power supply for the SC-D23?
You should use the original Samsung supply since it is a switching power supply capable of supplying the needed current to operate the onboard charging circuit. Many customers have tried to go with generic supplies and it opens the inline chemical fuse due to the unit drawing heavy current during battery charging. Hope this helps. Joe Weibel Custom Electronics Memphis, TN 38133 (customelectronics.org)
Feb 12, 2007 | Samsung SC-D23 Mini DV Digital Camcorder
 Grubhead
Grubhead
