Question about Kenmore 62802 Electric Dryer
Dryer Kenmore Elite front cover removal
Can you help
  • 5,911 Answers
Okay...if the illustration is correct that you posted this questions under, you will need to remove the top panel in order to get to the mounting screws for the front panel. The top panel comes off in a couple different way depending on the model.
1. On some models all you do is grasp the top panel along the back corners and pull towards you and lift up.
2. On other models, you insert a putty knife along the front seam (about 2 inches in from each side) where the top meets the front panel and push in to release the retaining clip.
2. Still, on other models, the operator console must be lifted to access the three mounting screws that hold the top in place. If the console has removable end caps, there is a screw under each side that you loosen to raise it. If the console does not have removable end caps, you will need to slide a putty knife under each front corner and push in while lifting up. This releases a retaining clip and the console will raise up. You can carefully lay the console over the back panel in its resting position. Use care not to damage the small plastic hinges.
CAUTION: Make sure the dryer is UNPLUGGED before servicing. The 220VAC terminals are located in close proximity to the console.
Once you figure out how the top panel comes off. There are is a mounting screw on each side of the front panel inside the dryer cabinet holding it to the side panels. Remove these screws and disconnect the door switch and drum light connectors (you may want to write down where these connectors go). The entire panel should lift straight up, then off.
NOTE: When putting the front panel back on, make sure you insert the bottom of the panel on to the small black cleats, first. The cleats insert into a couple of slots on the bottom of the front panel. Once in place, use your knee to hold the panel in place while inserting the mounting screws. Don't forget to reconnect the door switch and drum light connectors.
I hope you find this information helpful. Let me know if you require further assistance.
NOTE: The manufacturer usually places a wiring diagram inside the operator console. Use this as a reference if needed.
Posted on Jun 15, 2008
How do I remove the front oanel of the Kenmore Elite dryer model #796.8107, 796.9107?
Hello, You can look for aditional information in following web page . Please try it, it could be helpful for You. Sincerely 1_27_2014_4_37_18_am.png
Jan 02, 2014 | Dryers
Kenmore elite he3 gas dryer, how to fix blower assembly?
take it it's a front load, well remove the top panel, this will allow you to get to the screws to remove front panel. remove bellows pad (rubber gasket around door) remove with a screw driver carefully there will be a metalic ring, remove it fold bellows pad back.Now you can remove front panel and access the blower motor
Sep 19, 2013 | Kenmore Elite HE4 Electric Dryer
Clean Dryer Lint Vent in Kenmore elite HE4
If you wish to clean the interior cabinet of the dryer follow these steps:
1. UNPLUG the dryer. Dangerous voltages are still present even with the dryer turned off.
2. Open the dryer door and remove the lint screen. IMPORTANT: You must remove the lint screen first in order to remove the blower fan housing.
3. Remove the lower toe panel directly below the dryer door by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off. NOTE: For better access, you can prop the front feet of the dryer up (a 2x4 works well).
4. Loosen the screws on the blower fan housing directly below the drum and remove. There's usually a small clip holding the cover in at the bottom that you may need to pull out to release. NOTE: You may also have to disconnect the auto dry sensor plug (yellow wires with white plug - use a small screwdriver to release the locking tabs) and/or ground wire to accommodate removal of the cover.
You should now have access to the dryer interior and the blower fan squirrel cage motor. Take the time to clean out the blower fan housing cover as well. A long bristle brush made for dryers works well at removing any lint inside the dryer in the hard to reach places, followed by vacuuming.
NOTE: After cleaning, you may experience a slight burning odor. This is normal as lint gets stirred up in the cleaning process and can settle on the heating components. The odor should dissipate after a short period of use.
If you have any questions, please let me know. I hope this helps you.
Sep 29, 2009 | Kenmore Elite HE4 Electric Dryer
Either the thermal fuse or the ignitor on my kenmore elite gas dr
Remove the lower front cover - it has spring-loaded keepers that can be gently pryed and the panel should either hinge down or pop off. The thermal fuse and ignitor are behind this panel.
Mar 28, 2009 | Kenmore Elite Oasis 7808 Gas Dryer
i have a kenmore elite washer the red lite is lit on controlles locked how do i solve this
Mar 22, 2009 | Kenmore Elite 45986 Front Load Washer
Dryer won't heat
check thermostats on fan duct housing. the white one is a thermal fuse, not the problem if unit runs. for frontloader matching models thermostats are up front. remove lower cover and use ohm meter. wiring diagram avail there as well. then check element.
Nov 30, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he4 dryer wont run
Hi! crystal2hd
My he3 dryer does not have a door lock. The door switch turns off the light and allows the dryer to start. Make sure this switch is not damaged. Unplug the dryer before removing the front cover.
Aug 27, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite he3 dryer
Some coins or other objects may have fallen down in to the blower housing. Unplug the dryer. The Front lower cover has 2 screws holding the outer panel on. There are several screws in the blower housing.
Aug 12, 2008 | Kenmore Elite HE4 Electric Dryer
Front cover of my kenmore dryer
Assuming the two top inside screws have been removed, grasp each side of the front panel, slightly tilt away from cabinet and lift up. (may have to rock back and forth a little)
Jun 15, 2008 | Kenmore 62602 Electric Dryer
Kenmore elite dryer
can you spin the drum by hand? if not,pull front panel off by removing three screws on bottom, remove lint screen, then remove three screws holding inlet housing ( the big brown thing in front) check to make sure not clogged with sock, panty hose ,bra underwire ,etc.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 62802 Electric Dryer Logo
1,136 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
