Question about JVC Televison & Video
Im trying to hook my standard antenna up to my jvc av 56p585. i dont have manual. and i cant get any channels. what do i need to put my tv on to get my basic local channels
  • Anonymous Mar 21, 2014
    no remote
  • JVC Master
  • 5,467 Answers
This JVC TV has an NTSC (analog) tuner. So it can only receive some of the few remaining low power tv stations that are still using analog transmitters. Depending on your location, you may not have any of these stations within the range of the antenna.
You need an digital-to-analog tuner to get additional channels. Use tvfool.com or antennaweb.org to check for stations in your area and the appropriate direction to point that antenna. (You may need an amplifier since digital stations are either sufficient signal for the tuner to use or you get "no signal".)
Please note that the d-t-a tuners that were available with the government coupon cards only handles standard definition signals (480i). The HD tuner digital to analog converters are available at some online sites but cost more.
I hope this helps.
(you can use a tuner in your computer (USB or PCI card), but you will need a converter unless your video card can put out a signal other than RGB. The HDMI port on the TV will not interface directly with a computer.)
Posted on Nov 06, 2010
How to hook up antenna to jvc tv
you have to put an antenna adapter
Mar 30, 2013 | JVC AV-27D302 27" TV
Video channel "v" In right hand corner
All depend of the design of the TV and REm CONTROL. See you owner manual or download from www. retrevo.com
God bless you
Oct 18, 2012 | JVC AV-27820 27" TV
Channels 1 through 47 will come in and out but most of the time they dont come in at all. There will be fuzz for a second and then the screen turns blue. The upper channels work fine and dont cut out.
You need to check your antenna connections, and your Signal Amplifier, this sounds like that is your problem, IF you have visually and electrically proved your Antenna, cable, plugs, joints, and Amplifier are all OK, then you may have a fault in your tuner.
http://www.retrevo.com/support/JVC-AV-20D303-TVs-manual/id/279ci776/t/2/
http://www.jvc.user-manuals.com/list-of-manuals.php?page_id=702
http://elektrotanya.com/jvc_av-21bt8ens_chassis-11ak30.pdf/download.html
Bottom link is for your service manual, the next is for your user manual. Use these manuals to troubleshoot and hopefully repair.
May 19, 2010 | JVC AV-20D303 20" TV
I have cable hook up through a normal cable and I can only get two channels how do you program the channels in on a jvc av 20fd24
You should be able to go into the menu settings and select channel, then Antenna, then the type of source your have, Air, or cable...select one then press enter, or ok...should do everything for you.
Oct 19, 2009 | JVC AV-32D305 32" TV
JVC AV-20FD24 will not pick up the signal from the antenna. I Moved tv from my daughters apt to my home and now it will pick up only 67 , 69, 27, 57, & 25. I am currenty using an antenna on top of...
On the JVC remote there should be a setup button. Sometimes they call this Main. Regardless, once in setup you'll need to change the input from cable to antenna. This should solve your problem.
Oct 12, 2009 | JVC AV-32D305 32" TV
JVC and the right converter box and antenna
If the tv got audio video inputs put the converter box on it,because any converter box got to work with all tv´s
Jun 30, 2009 | JVC AV-27230 27" TV
I have a jvc tv model av27530. Disconnected cable box b/c going
You probably have to find your original remote to the set and go through setup in your menu. On most sets, there will be a menu item which will allow you to switch from Cable mode to Air mode. If you have no Cable connected, then you must set tuner in Air mode.
If you are using an external device to run on channel three, then try this:
Make sure device (rather it's a vcr or game console), is hooked up to your Antenna Input connector. Also, some of these devices will have a small hidden switch on back that says 3 and 4. Move the switch to 3 position. Turn on device. Go into TV menu and do a Channel scan. This should auto program any device hooked up to the TV antenna input jack to channel three.
Keep in mind that you may not receive anything by Feburary of this year without an HD converter box to tune in channels with and outdoor antenna.
Jan 09, 2009 | JVC AV-27530 27" TV
Picture shows snow and fuzz on channels JVC AV-32980
Sounds like U have an antenna or feeder problem. Get it checked out/ check it out. If in a strong signal area, try a simple indoor antenna for comparison. If in a marginal reception area, it could be your antenna is inadequate.
Mar 27, 2008 | JVC AV-32980 32" TV
Televison & Video Logo
158 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
