Question about Whirlpool Washing Machines
Washer does not seem to change cycles. Fills and agitates fine, but does not seem to go further than the first cycle.Suspect timer issue.
    President:
  • 1,218 Answers
Good day,
If it fills and agitates and gets thru the first cycle, but won't pump out and spin, then it would be a bad lid switch. Check the following clip for more info.
http://www.youtube.com/watch?v=fC8SY3cU1Yc
Posted on Nov 06, 2010
Haier XQJ50-31 drum quit agitating or spinning
If the timer stopped advancing on one of my machines (laundromat owner) i'd assume it's the timer motor. Kind of like when a top loader has no final spin but otherwise runs okay i always suspect the timer mechanism. For me it's a simple check; exchange timers with a neighboring machine. You probably don't have that option. Unfortunately, I don't know the Haier Brand of machines so i could be wrong.
Dec 23, 2012 | Haier XQJ50-31 Top Load Washer
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    During normal cycle agitation is a constant stop/start
    Yes, the timer mechanism should be replaced asap. the timer has a motor that is responsible for the rotation of the device. This motor is damaged, in return, not allowing the normal cycle to initiate and transfer sequential information to the motor properly.
    Replacing the timer will correct this issue.
    Aug 31, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
    Won't finish the final spin
    Post further comments for more information ....
    Good Luck!!
    Thanks
    Aug 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Water doesnt pump out to start rinse cycle
    Seems the timer is sticking at the drain cycle. Manually move the timer and see if this helps. If this works then the timer is bad.
    Jul 05, 2009 | Washing Machines
    My washing machine is not changing cycles. It fills, drains and refills. It sat unused for 1 year. 12 months ago it was working fine.
    Hi there. I can help you.
    • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. If this is the case, turn off the water and remove the hoses. Check both hoses to be sure the filter screens are not clogged with crud and that the hoses aren't kinked.
    Jun 18, 2009 | GE WSXH208A Front Load Washer
    Washer won't wash
    Hi!
    Please do rate this solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    May 30, 2009 | GE Washing Machines
    Stops in the middle of wash cycle
    Hi!
    If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
    Thanks
    Rylee
    May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Soon as i set cycle and swich on door light flashes open
    hi,
    The cycle doesn't advance
    Thanks for your question.
    Jan 03, 2009 | Ariston Technologies AW129NA 16 Lbs Front...
    Machine fills with water & then clicks but goes no further. It will drain but no other function seems to work
    That is probably a problem with the timer.
    The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • Oct 11, 2008 | Bosch Washing Machines
    Washing Machines Logo
    35 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
