Question about Panasonic PT-52LCX66 Projection Television
Need to change bulb - Panasonic PT-52LCX66 Projection Television
    Sergeant:
  • 252 Answers
Ok this very basic to all DLP or projection screen so don't get hung up on the name brand. This Video will help you out a bunch.
Posted on Nov 08, 2010
Headlight bulb chevy traverse life
As I also had the dealer tell me it would be $120 - $150 to change I looked into it further. If you will remove the screws from the protective cover under the fender (just a few you do not need to remove the full fender cover). You can access the bulb. You will need to turn the housing and remove the bulb. Be sure to not touch the bulb as oil from your fingers will make certain you will be changing the bulb in a short time. Also I would use the standard bulb as the brighter bulbs run hotter and burned out very fast (2-3 months). If you turn the wheel your access to the bulb is easier. It is tight but by changing the bulb yourself you are saving a lot of money.
Sep 12, 2013 | 2010 Chevrolet Traverse
Changing interior light bulb on GE jes1289sk
I have had this trouble before but with a different model. There may be a plastic screen inside the microwave that will just pop off exposing the bulb. Now all you will need to do is to find out what type of bulb you will need to change the other bulb. I hope this made things easier on you.
Jul 25, 2013 | Microwave Ovens
New signals not flashing
Depending on the year of your bike, If you changed your signals from a bulb type to a LED type you will need a Load equalizer. If its a bulb to another bulb, Check your voltage at the housing. A change in amps or watts for the bulb will usually only change the brightness, unless you have changed the bulb to an outrageous wattage or amps.
Jan 12, 2013 | Harley Davidson Motorcycles
My car 2003 altima I need change light bulb. need know how to remove head light to change the bulb.
You don't have to remove the headlight to change the bulb. The bulb can be removed from the back of the headlight, usually by turning the bezel ring that holds the bulb onto the headlight housing. Just make sure you do not touch the glass part of the bulb while replacing it or it will burn out again fast.
Jan 27, 2011 | 2003 Nissan Altima
Replace rear turn signal bulb on 1996 cadilac
Hello; To change bulbs remove the cover in the trunk (pull it away) Remove the nut's/wing nuts and the assembly will come out. If you ever have to change any of bulbs that are on the deck lid you will need to remove the covering on the inside of the deck lid, remove the assembly and change the bulb.
Sep 17, 2010 | 1996 Cadillac Seville CA Value
How do i change headlight on a 2003 Murano
To change the headlight bulbs, you will need to remove the wheel liner cover to gain access to the back of the headlamp assemblies. Then you can pull off the screw cap / cover that seals the bulb into the headlamp assembly for the bulb you want to change. Once the cap is off, you will need to disconnect the harness from the back of the bulb. With the harness off, you will then need to either twist a black lock ring to release the bulb, or you will need to push on a metal lever to release the bulb (this varies on models and high and low beams).
Install in the reverse order....
Nov 16, 2009 | 2003 Nissan Murano
How do I change headlight bulb . Left side low beam headlight bulb is blowed . I have the new bulb and just need to know where the lever or turn object is to remove from the back side so I can change the...
Reach beind the headlight and just unscrew the cap that holds it in. However don't touch the new bulb with your bare fingers or you will drastically shorten the life of the bulb.
Oct 16, 2009 | 2003 Chevrolet TrailBlazer
Changing head lamp 04 grand am
you need gloves hands cant touch bulbs .oils from hand causes bulb to blow.to change bulb you raise hood remove head light housing has to be removed before you remove bulb.
Mar 07, 2009 | 2004 Pontiac Grand Am
CHANGING HEAD LIGHT BULBS IN 2002 CHEVY S-10
Right behind the light there should be 2 clips pull up on those and the headlight will come out to change the bulb
Dec 13, 2008 | 2002 Chevrolet S-10
Changed passenger side headlight bulb, now unable to adjust or align head lights
Changing the bulb should not have affected the housing adjustments.
The bulb is just inserted into the headlight housing. The adjustments on the headlight housing is what adjusts the alignment of the headlights.
Did you maybe not get the bulb not seated correctly in the socket? Or didn't get the socket not seated correctly into the housing?
Aug 12, 2008 | Ford Focus Cars & Trucks
Panasonic PT-52LCX66 Projection Television Logo
69 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
