Question about Admiral AW22 Top Load Washer
Admiral AW20N35V Washer started making a loud grinding noise during the agitation cycle.I've looked for obvious breaks/wear but nothing to note. I then pulled the washer into the garage, filled the tub and tried the agitation cycle again; no more noise to note. Knowing that issues don't go away for good, I'm trying to get the gear box out; good or bad idea? Looks like I may need some special tools also? Thanks in advance for your help. Orlando T
  • 2 more comments
  • UnHombre Jun 15, 2008
    Forgot to mention, are there disassembly instructions available and what's the most probable cause?
    None, but I'm some what mechanically inclined. I also figure, the system is breaking down, a repair tech is going to charge almost what it'd cost to replace, so why not?
    P.S. $10 for you to tell me not to try?
    The standard comment that's been previously posted is not the same disassembly for my model. My transmission uses bolts not tabs.
    Yes, please send disassembly instructions for my model, not generic instructions for general models. Also, would like to get a parts break down indicating which the likely failed part. In addition, a listing of what other parts/gaskets that should be replaced when performing this level of maintenance.
    Master:
  • 638 Answers
Its a good idea if u already hve som tecnical knowledge .otherwise dont try
Posted on Jun 15, 2008
  • 4 more comments
  • hemant somaiya
    hemant somaiya Jun 15, 2008
    if u r sure u want to do it urself . let me know so that i can guide you with some helpful instructions.
  • hemant somaiya
    If you begin dissassembly from the tub down, you wil come to the transmission with the spindle sticking out of it. If you undo the bendable tabs all around the transmission it comes apart in two halves. Careful, its full of oil. The spindle has a plastic gear bolted to the bottom of it. It meshes with other gears in the tranny. It has sheered teath and is making the noise
  • hemant somaiya
    i hve send u details wat causing a noise problem.do u want to know somthing else regarding this.feel free for further assistance .pls rate this solution as FIXYA if it helps u understand n solve ur queries.
  • hemant somaiya
    DO U WANT ME TO SEND U DISSASSEMBLY INSTRUCTIONS I WILL PLS LET ME KNOW AS SOON AS POSSIBLE
  • hemant somaiya
    after a final research regarding ur problemi hve found the instructions step by step it will help u but if u mke a mistake somewere it will get messed up so i will give u a direct link to the site with all the details of repairing ur machine with cost of parts n procedure to fit them:
    http://www.repairclinic.com/0047_11.asp
    for any more help feel free n dont forget to rate the solution
  • hemant somaiya
    Show your Appreciation by rating this solution. thanks in advance
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
I have a Admiral Capacity Plus washer LNC6267B71. Washer makes loud grinding noise when agitating & spin cycles. Machine does fill, drain, agitate & spin. Only noise is concern.
Hello. Your symptom describes damaged bearings and/or a damaged transmission. This is a MAJOR, INVOLVED repair requiring special tools to prevent serious injury during dis-assembly and re-assembly. I strongly suggest acquiring outside service to repair this machine if cost effective. There are many parts that have to be removed and then replaced--if you've never done this--don't attempt it. There is a brake spring with 200lbs of torque on it that has to have a special tool mounted to relieve the tension during removal and then re-compress it during replacement for example. Sorry to be so dramatic but I don't want you to get hurt needlessly. I hope I helped you!
Nov 05, 2015 | Admiral Washing Machines
Washer makes grinding noise when it agitates
check back of unit as the concrete on the back may of been dislodged check not over loaded also the belt maybe loose or streached
Jan 02, 2014 | Crosley CAWC529JQ Top Load Washer
Whirlpool Model #: WTW4800XQ making a loud grinding noise during or at end of spin cycle. Help!
I have a similar model (WTW4850XQ1) that was making a very loud grinding/screeching noise during the agitation and sometimes the spin cycle. I unplugged and turned it on its front to get underneath and exposed the motor/transmission unit. Took the cover off the belt drive assembly and my drive gear was loose. Simple tightening down of the nut was an easy fix for me. But some times those plastic gears between the drive pulley assembly and transmission crack or the teeth wear down (think it's called the CAM). That is a fairly cheap and easy fix as well ($35). Repair Clinic website has free videos on how to diagnose and fix issues and parts as well. Worth a look.
Jan 08, 2013 | Whirlpool WTW4800XQ Washer
Admiral washer model AW20N2V making a clicking sound...
call manufacturer. heard there was a recall... for dangers of fire.
Oct 02, 2012 | Admiral Washer Control Panel Frame 35-5733...
I have a Maytag Performa Washer, model number PAVT244AWW, that does not agitate. Everything else is working. It makes a loud noise during the wash and rinse cycles when the agitator is supposed to be...
My Maytag Performa makes a grinding sound when it agitates. When it starts to dump the water it makes a loud grinding on metal sound... really loud. What is the problem and how much to fix?
Sep 05, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Grinding noise while agitating.
possible foreign substance under agitator
Feb 26, 2009 | Admiral AAV7000A
Load squeal when it in the agitation cycle.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
for detailed help with diagrams and step by step instructions click the link http://www.applianceaid.com/washerspinnoise.html
Dec 29, 2008 | Admiral AW22 Top Load Washer
My Capacity Plus Admiral Washer will spin and agitate, but it makes a loud grinding noise.
Well, Sounds to me like the Bearings are going out, but it could make that noise a good while, before it goes completely out.. Replacement would possably be more cost effective, Kinda hard to beleive !!!!!!
Oct 26, 2008 | Washing Machines
Loud noise while agitating in wash cycle
If you begin dissassembly from the tub down, you wil come to the transmission with the spindle sticking out of it. If you undo the bendable tabs all around the transmission it comes apart in two halves. Careful, its full of oil. The spindle has a plastic gear bolted to the bottom of it. It meshes with other gears in the tranny. It has sheered teath and is making the noise.
Sep 24, 2006 | Admiral AAV7000A
Admiral AW22 Top Load Washer Logo
205 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
