Question about Jandy POOL PUMP IMPELLER ASSY PLUS HP STEALTH R0445304
I can't get the impeller off. It doesn't have a screw and I can lock the shaft and try to turn it counter clockwise, but it will not budge.
  • 366 Answers
There is most likely corrosion in the threads between the impeller and the motor shaft. You will need an impeller wrench to get enough torque to spin it loose., you may have to replace the impeller if it is excessively corroded as it may be cracked as well.
Posted on Nov 08, 2010
How to remove impeller on Pentair ultra-flow pump
Remember to remove the impeller locking screw (left hand thread) before attempting to unscrew impeller.
May 05, 2013 | Pool & Spa
I have a proline 1.5hp pump need to replace the shaft seal. I can't seem to get the plastic impeller off. We use a screwdriver to hold the shaft screw and try to turn the impeller counter clockwise...
Keep trying - It is stuck and will likely break but you have to remove it to change the seal. It is not uncommon to need to replace the impeller when the seal fails since the water gets behind the impeller shaft and rusts the metal causing the impeller to bind. If you still cannot get it free pull the motor thru-bolts and lock the rotor once removed from the motor in a vice. Use a large pair of channel locks to break the impeller free...replace it if necessary.
John
May 15, 2011 | Waterway 1.5hp Hi Flo Above Ground Pool...
How do you take off the motor from the pump assembly
Turn the circuit breaker off to the pump. Undo the band that holds the motor and flex plate to the pump. Unscrew the 5 screws on the diffuser ( front of pump ) That will expose the impeller. Remove the rear cover of the motor, (2 -1/4" screw heads) Pull off the rear cover. The impeller might have a screw in the center of it. If it does, the screw is left handed thread. Turn the screw clockwise to remove. Use a 7/16" open end wrench to hold the shaft at the rear of the motor. Put the wrench behind the plate with the two springs on the shaft. You might have to turn the shaft a little to get the wrench on. Remove to screw and remove the impeller, (counter clockwise). Unscrew the 4 motor flange bolts and pull the flex plate from the motor.
Apr 10, 2011 | AO Smith SQ1202 Pool Pump Motor
How to remove impeller seal
Remove v-clamp from wet end.
Remove diffuser from wet-end using a flat blade screwdriver.
Remove impeller screw by turning clock-wise(this is a reverse threaded screw (some impellers dont have an impeller screw))
Remove back end of motor using a 1/4" hex driver.
Secure rear end of motor shaft by slipping a 7/16" open face wrench into rear electrical compartment
While securing the shaft, turn the impeller counter clockwise until its off.
Remove seal halfs and replace with identical seal.
Reverse to finish the install
Mar 23, 2011 | Sta Rite Tune Up Kit Dyn Glas Dyna Max...
I am trying to replace the motor on a pool pump. How do you remove the front end or impeller to install a new motor?
it may have a left hand thread screw in the front of the impeller turn this screw clockwise to loosen, to loosen the impeler just use a 7/16 or a 9/16 wrench to hold the back of the motor shaft look close you will see a slot in the shaft for the 7/16 wrench just under the centrifugal switch , this will hold the rotor still so you can turn the impeller counter clockwise to remove it
Oct 10, 2010 | A.O. Smith SQ1102 Pool Pump Motor
How to seperate pump from motor
Disconnect all power. Remove the six bolts holding the seal plate to the wet end. Remove the two small allen screws to remove the diffuser. Remove the dust cap from the end of the motor and secure the shaft from moving. If installed, remove the Phillips head screw in the center of the impeller by turning clockwise (left hand threads). You can now remove the impeller by turning counter clockwise, note that you may need an impeller wrench to remove it and a specific tool to hold the shaft while you remove the impeller. Once the impeller is off you can remove the four bolts that hold the motor to the seal plate. This process just needs to be reversed to re-install but you will need a new shaft seal (PS-1000).
Jun 30, 2010 | Pentair 1 hp WhisperFlo InGround Pool Pump...
How do you remove the impeller from the motor shaft?
Thank you for posting your question here on Fixya.com.
Lock the shaft using a wrench at the end where the electric leads connect. Then spin the impeller off counter-clockwise.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Jun 13, 2010 | Flotec 1 - 1/2 Sprinkler Pump Composite...
We are having issues getting the impeller apart on the jacuzzi magnum force pool pump and need some instructions on how to proceed.
I believe the jacuzzi pump impeller has a locking screw directly in the middle of the impeller. You'll have to turn it clockwise to remove it. Then you'll need to remove the cover from the back of the motor using a 1/4" nut driver. Depending on the motor, you should be able to use a 7/16" open end wrench to hold the motor shaft from turning as you turn the impeller counter-clockwise to remove it. Some motors are different, some have a keyed shaft or require a special tool to hold the shaft while the impeller is removed. Hope this helps.
Nov 22, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Remove impeller
Based on the limited info. For most jacuzzi pumps, you will need to remove the lock ring and pull the pump apart to expose the impeller/diffuser. Next, remove the diffuser to expose the impeller. Depending on what type of motor you have, either remove the cover plate or cover cap to expose the shaft at the rear of the motor. There are three types of shafts, one is slotted so you will need a large screwdriver to hold it in place. One is larger and can be held with a wrench or special shaft tool. One is more internal and has a switch at the end so it has to be held with a 7/16 wrench under the switch midway between the switch and the housing. You may have to remove the capacitor to gain access with the wrench.
There may be a lock screw holding the impeller to the shaft, if so, remove it by turning it clockwise (left hand threads). Then you can remove the impeller by turning it counter-clockwise. They can get stuck on the threads and you may need an impeller wrench or something suitable to give you some mechanical advantage to remove it.
Oct 20, 2009 | Jacuzzi Pool & Spa
How does the impeller come off of the motor shaft
It unscrews. If it has a lock screw in the center that is left handed so it unscrews in a clockwise direction. Then the impeller unscrews in a counter clockwise direction. Usually needing a good sharp rap to get it started. I usually use a screwdriver held sideways in the impeller and I hit it straight down with a cresent wrench.This will usually start it spimming. if that dosen't work you will have hold the back of the motor shaft and break it free by turning it with water pump pliers or the like.
May 30, 2009 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
Jandy POOL PUMP IMPELLER ASSY PLUS HP STEALTH R0445304 Logo
187 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
