Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Water dripping inside fridge
Inside the refigerator, there is water accumulating towards the back of the shelves. it looks like it is coming from the vents in the back of the fridge. it also ends up accumulating under the crispers. Water was dripping onto the top, lower and bottom of interior or unit. Located a line on back of unit. Not sure if it was for the ice maker which I don't have connected or if it was the drain line. I used high pressure air gas duster from Staples to try to unlodge any ice particles in this line. Also used hair dryer to try to unfreeze anything in the line. Now I only have dripping on one side not both. I must have done something right. But not sure. I've discovered water accumulating under the crispers, some of the water has frozen. I noticed water dripping from the bottom of the temperature control unit, so I thought perhaps I had blocked the fan in the freezer. I moved everything away from the fan so air could circulate, but I've still had to mop standing water out of the bottom of the fridge about once a week. I bought the fridge 7 years ago and I think it was new then, but I'm not 100% sure - I bought if from a scratch and dent retailer. It may have been slightly used or reconditioned. I've been very happy with my Kenmore, and it doesn't make any odd noises - just the drip. I know little about appliances, so any suggestions are welcome.
  • 10 more comments
  • Anonymous Jun 15, 2008
    same issue. It seems that the freezer is not defrosting properly and then the water goes t
  • Anonymous Jun 27, 2008
    I have the same issue. The water gets everywhere, and I know my landlord will try to fix it himself, even though he has no idea what he is doing. It's a magic chef fridge.
  • tori59 Jul 08, 2008
    Ditto
  • LostInOhio Jul 11, 2008
    I clean out the freezer. It has a solid sheet of ice under the removable floor. This fixes it for a month or two but then it just re-freezes and it starts again.
  • Anonymous Jul 30, 2008
    Water is leaking from somewhere (freezer perhaps) down to the fridge part on the shelves and underneath the crispers, where the water is then puddled up and freezing.  What's wrong?
  • Anonymous Aug 02, 2008
    Same problem in Whirlpool placed med bowl under vent in rear, on top shelf, that solved the mopping up under the crisper problem. Any body know how to stop the leak?
  • whiddonlk Aug 04, 2008
    Same here and with my Dad's too. I will never buy Kenmmore again. How do I fix this mess?
  • Anonymous Aug 13, 2008
    water accumulating on the bottom of the fridge, underneath the crisper. Items close to the bottom is wet also. If not kept cleaned up it would flow out the door.
  • gimmy Aug 31, 2008
    There's water dripping down to the crispers and floor of the fridge. I have to mop it up every other day.
  • jcd54 Sep 07, 2008
    Water is accumulating in freezer compartment and dripping down into fridge through the vent holes - the fan is working OK and we did not have an issue until we had the fridge moved downstairs. Fridge is only 3 years old Kenmore 18.5 cubic foot with upper freezer.
  • Anonymous Dec 25, 2008
    I have water accumulating under the crisper
  • holyrav Mar 29, 2009
    Our problem was the same as described, water under crispers.  We did what was suggested, but when my husband pulled off the black tube that the water is suppose to drain from, and blew in it, a clog blew out and it no longer dripped.  Fixed with no cost.  Try this first as I think crumb got in through the back of the freezer and made their way to the draining tube.
OK, i see a lot of this, and on a fridge that is nearing 10 years old, its pretty normal. Now, we all know that water is leaking into the fridge section from up top because the drain is plugged that is under the evaporator.. now to fix the WHY it happened. most of the time this will happen because the fridge did not go into a DEFROST cycle for a while.. reason being one of two things... either the defrost timer has quit working, or the bimetal thermostat sensor that is clipped on the evaporator has failed. the bi-metal thermostat is usually located in the freezer behind the rear wall and looks like a round "clip on" with 2 wires coming off of it. one pic of one is here.
http://www.partselect.com/PartDetail.aspx?Inventory=371255&SourceCode=5&ModelNum=et18pk
instructions on how to test this is shown on the link.
(just replaced mine the other day, NO MORE WATER LEAKS! =) )
hope this helps!
Chris
Posted on Sep 07, 2008
Are you guys keeping items in the freezer? i've heard this can be caused by the unit working harder because it's empty or near empty...if you're single or don't keep a lot of food in the fridge/freezer try keeping a jug of water in both.
hope that helps.
Posted on Aug 08, 2008
Http://www.applianceaid.com/frig_leaking.html
Posted on Aug 20, 2008
Water leaking
the bottom tray/salad compartment will always get a fair amount of condensation because they are glossy plastic(bathroom paint is matt)the only "cure" is kitchen towel under the tray and remove once a week.as for the drain it is normally at the back and does collect a fair amount of "moss"in the tube,pour some clorine bleach down to clear any out.the design of the shelves directs the side/back condensation down the drain.
Apr 06, 2010 | Sub-Zero Bottom Freezer Refrigerator
Water accumulation underneath the bottom vetable
Two solutions
1 If a frost free fridge/freezer - ice build up in internal cooler - defrost totally until no more water
2 if ordinary fridge/freezer look inside at the back, you should see a very shallow 'V' shaped plastic channel running to a small drain hole which leads to the rear outside of the unit. This channel collects the water drips from the cooler
Clear this hole with a pipe cleaner or cocktail stick or similar
Sep 27, 2009 | Samsung Refrigerators
Water leaking inside fridge.
If you remove the back panel of your freezer you will notice what looks like a drain - melted water will go through a drain hole that extends to your refrigerator inside a cup that slowly drains the water through a tube through the back of your refrigerator and down the drip pan. Your cup may appear fine, but maybe there is some obstruction somewhere causing the water not to drain fast enough - so what happens is that the cup will eventually overflow - try to see if you can remove this and pass a long wire down the drain tube at the back to dislodge anything blocking or partially blocking it - see if you can also clean your drain cup, eventually small derbris accumulate. At the back of your freezer panel look for any partial or complete obstruction of the drain hole and its surroundings, which might be iced up.
I myself have had this problem for months, my refrigerator would have water at the bottom accumulate and eventually under the crispers a river of water :)
Cleaning the cup and the drain tube at the back of the fridge and the drain and surroundings at the back of the freezer panel should fix this problem. Sounds like your drain at the freezer level is plugged up and water is backing up and leaking from elsewhere !
Sep 25, 2009 | Frigidaire PLHT219TC Top Freezer...
Water accumulates inside the refrigerator, Kenmore, Mod. 71194100
You get to it from the freezer. Remove the back wall in the freezer and you will see it there. Unclog it with some wire or check to see if it has ice over it.
Sep 13, 2009 | Kenmore 71112 / 71114
Water accumulating in bottom of kenmore
It's likely the condensate drain is plugged. You can access it from the back of the refrigerator. You can disconnect from the inside of the fridge and blow it out to ensure it is not blocked, then reconnect.
Aug 15, 2009 | Refrigerators
Fridge ice accumulation inside and water dripping outside
Hi, Are you getting ice build up in the freezer side as well? There is a air shuttle between the fresh food side and the freezer side. thwater might be getting in the freshfood side from there. Look at the bottom rear panel in the freezer for ice build up. Ig=f there is ice, you will need to get to the drain from inside the freezer and check for blockage.
Please let me know if I can help you further.
Vic
May 10, 2009 | Refrigerators
Water accumulation under crisper bins
Check that the hole at the back of the fridge is not blocked with gunge.  There should be a drip tray at the rear with 2 slopes towards the hole where the condensation drains to.  Some cabinets come with a little rod to clear the blockage.  The rod may live in the hole alowing water to drain around it.  Have a peek!
Feb 22, 2009 | Frigidaire FRT18S6AW Top Freezer...
Leaking Whirlpool refrigerator
My Whirlpool fridge had water droplets falling onto all three shelves and pooling unter the crisper drawers. I solved the problem by clearing the ice-clogged drain in the freezer.
In Whirlpool model ET21UM, the condensation drain hole is located directly behind the freezer. To access the drain hole, remove all your frozen items and place them in a large picnic cooler. Notice that the floor of the freezer is basically a large plastic tray fastened by two small bolts. Unscrew the bolts with a wrench or ratchet and remove the plastic tray. At this point you will probably see that water has seeped under the tray and created a mini ice rink on the bottom of your freezer. You can tap the ice lightly with the handle of a screwdriver to break it up. Once it's broken, toss the ice into your sink, or put it in a plastic bag and store into your cooler to keep everything cold.
Once the ice has been removed from the freezer floor, you should be able to see a metal drip trough in the back under a false wall hiding the condenser coils. It's a little tougher to remove the ice from the drip trough with the screwdriver method, so you might want to use a hair dryer. After a few minutes with the hair dryer, you should be able to remove most of the ice by hand. You can remove any water with a sponge or turkey baster. The only ice left will be a plug of ice in the drain hole in the middle of the drip trough. Heat up a cup of water in the microwave and carefully pour it into the drip trough. If the drip trough is hard to access, you might need to use a funnel. The hot water should melt most of the ice in the drain hole. If it pools in the drip trough and doesn't drain, use a sponge or turkey baster to remove the water and add hot water again. A small length of wire or a pipe cleaner might help clear any other obstruction in the drain hole. When the drain is clear you should hear water flowing through it. Dry off the floor of the freezer and return the plastic floor tray to it's spot and fasten with the two bolts. Remove any water that has pooled in your refigerator and you're done.
Dec 27, 2007 | Refrigerators
here is the link to the manual if you need it; http://www.whirlpool.com/assets/pdfs/product/ZUSECARE/2314472.pdf especially this time of year there can be a massive increase in humidity which often is the cause - the only real cure is to dehumidify the room and try and limit how often you open the fridge. even if the water seems like too much for this to be the cause, you would be surprised how much condensation humid air can produce - I assume everything else seems to be working as normal? ask again if you don't find what you need. check this link too; http://whirlpool.custhelp.com/cgi-bin/whirlpool.cfg/php/enduser/std_alp.php?p_page=1&p_cv=1.113&p_pv=1.137&p_prods=137&p_cats=113&p_search_text=&p_new_search=1 Hope this helps :)
Mar 15, 2007 | Whirlpool ET1FTKXK Top Freezer...
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
8,714 people viewed this question
Top Kenmore Refrigerators Experts
John Tripp
John Tripp
minguy15
Level 1 Expert
mike cooper
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
