Question about Tomtom ONE 3rd Edition GPS
I have a Tomtom Version 6.501(7460/060904). I recently changed the baterry charger but now it is not charging. I tried charging on AC power. It shows the green light is on and I can see in the screen that it is charging. Yet, it remains uncharged at the end with no bar or line. I can even not switch it on again as the power does not come at all as the battery is uncharged. I have reset it but with no success. Please,can you help. Many Thanks
    Top Expert:
  • Tomtom Master
  • 37,910 Answers
The battery may have become defective
Posted on Jun 27, 2017
SOURCE: TomTom 500 won't power EITHER!!!!
Guys make sure you know where the reset button is . Ie for tomtom 500 it is at the back and you have to unclip from the adapter.
Posted on Jul 08, 2007
SOURCE: GPS Won't Turn On
My 510 was doing the exact same thing.
I called customer support and they helped me get it working again.
866-486-6866 is the number but here is what they had me do.
I had to push down the reset button for 15 seconds (the reset is in a small cut out near where you plug in the charger on the bottom.you will need to use a pin and you will feel the pin push in the button if you have it in the right spot.)
Then release the reset and hold down the power button for 10-15 seconds. the screen should come right back on.
If you need more help I suggest calling the 866# they are very helpful.
Posted on Mar 13, 2008
SOURCE: Tomtom not switching on
I had this problem. had it plugged in charging and then pressed the the reset and the power button at the same time for about 30-50 seconds and then after that pressed the power button and so far so good
Posted on Aug 14, 2008
  • 20 Answers
SOURCE: Tomtom go 730 will not power up.Brand new,used a coupla weeks.
you need to do a hard restart. find tiny hole on under side by bracket mount and press it with a tiny paper clip once. you have to look very very close to see it. you can also try to hold down on power button for 5 to 6 sec.
Posted on Dec 28, 2008
E61N
  • 515 Answers
SOURCE: Recharging TomTom GO 730
It will show battery status when you tap screen where GPS signal bar is shown..
Posted on Apr 17, 2009
Is there a way to charge my 930 T on a wall socket AC adapter
The trouble with cheap chargers ' Mobile Fun Blog
www.mobilefun.com/blog/the-trouble-with-cheap-chargers/
Jul 10, 2012 - The abbreviation for amp is A. There are also milliamps which have the abbreviation mA. ... The other way around isn't as much of a problem. If you try tocharge an iPhone (1.1A) using an iPad charger (2.1A), ... micro USB cables can't tell the difference between a wall socket (AC power) and a USB port.
How USB charging works, or how to avoid blowing up your ...
www.extremetech.com > Computing
ExtremeTechAug 26, 2015 - If you take a smartphone which came with a 900mA wall charger, and plug it ... It turns out there's a method to all this madness - but first we have to ... A regular USB 1.0 or 2.0 socket has four pins, and a USB cable has four wires. ..... Last week I couldn't find my phone charger (wall plug), so I tried using ...
What wall plug chargers can be used to charge PS3 ...
gaming.stackexchange.com/.../what-wall-plug-chargers-can-be-used-to-c...
Jun 19, 2012 - I want to charge my PS3 controllers (SIXAXIS) without having the PS3... I have noticed there are (expensive) third party PS3 controller charger ... Why can'tthe normal wall plug chargers, that are able to charge way ... The PS3 controller won't charge when connected to any usb outlet (where only ...
Amazon.com: AC Adapter Wall Charger w/6'FT Power Cable ...
www.amazon.com/Adapter-ChargerCity-Manufacture...
Amazon.com, Inc.
Rating: 5 - ‎5 reviews
ChargerCity GPS AC Wall GPS USB Power Adapter Cable Accessories for ... XXL 550 540 535 530 GO 920 930 720 730 740 630 640 TOM TOM LIVE Traffic GPS ... I don't really have any need for the Micro SD Memory Card Writer so can't ... I now cancharge my TOMTOM from a wall socket instead of leaving it in my car.
Charging your Lumia 930 ' MyUCS
Jan 03, 2016 | Computers & Internet
Acer laptop 4730z wont power up
Hello. There is a hardware failure with the laptop not your acer 4730 AC charger. AC chargers have some range of protections of their own. If the power requirements of the laptop are bigger then what the charger can handle, the charger will turn off. Also other parameters can bring the charger offline. In your case, you have a problem with a small chip, the battery charge controller unit, witch regulates the amount of current required to propperly charge the battery. When this thing fails, the charging requirements for the battery are reported rong and the AC charger is forced to give more power then necesary. This results in disconnection of the AC charger ( an internal fail safe of the AC charger) and the laptop to swich back to battery power. When the laptop is turned off, it can charge the battery because the power requirements are low, having all processor, main board, hard disk etc turned off. Therefore the AC charger can handle the load. However you will need to have it checked by a service center as it is a hardware fault. Both AC charger and laptop needs that check. The charge controll circuit needs to be replaced probably. It will be a somewhat expensive repair. Don't buy any other battery untill you have the laptop checked.
Dec 23, 2012 | Computers & Internet
R380 only charging
YOU HAVE TO CHANGE THE CHARGER
it is the problem with the charger
Feb 15, 2012 | Ericsson R380s Cellular Phone
My nokia 5130 charging slot does no more 'hold' the charger. I could not charge the battery. Is there any thing I can do? I recently have a previous nokia 5130 phone with the same problem...
here in the philippines, we have a "universal charger" where in you can take out the battery and put it on the universal charger and plug it to the outlet. it's best for your problem. however, if the said exchange that you have said here is part of a warranty then you still had the same problem with the same particular phone, i think you better go to the store where you purchased that phone and talk to them regarding the same old problem. and ask them if they can exchange a different unit for you because tell them that you are not satisfied with the performance of that unreliable and not so durable gadget and its accessories. make a deal with them. convince them. don't let them manipulate you to just accept something that is really not acceptable.
May 19, 2011 | Nokia 5130 Cellular Phone
How can I charge my Tomtom GPS 550 at home using a USB to my PC ? Or can it be charged only in the Car using the Car Charger ? How long should it take to fully charge using USB & also on Car Charger ?...
i dont believe it can chagre via usb as usb only provides up to 5v of power you can buy from walmart a cheap ac to car adapter (makes your ac outlet a cig lighter adapter) and power it that way.
Mar 27, 2011 | Tomtom XXL 550 Car GPS Receiver
I recently purchased the tomtom 340S XL. Can it
Using cable data /charger port you can do charging both at system or in car under car charger option. those specifications placed in manual and normally lasts for 3 hours
Dec 16, 2009 | Tomtom XL 340S Car GPS Receiver
TomTom will not charge with car charger
Mine does the same, the light comes on on the charger, but not on the TomTom unit itself. There is clearly a loose connection in the cable somewhere as you can twist the flex and make it work, although this is not very reliable.
I just use a USB charger from an old phone instead.
Mar 30, 2009 | Tomtom ONE 3rd Edition GPS
Tomtom300 gps mains charging +
1= My battery is flat, but when i put it on charge in the house it doesnt charge and no green light comes on, on my sat nav why would this be?
Could be your house charger is bad or the power connector on the back of the Tomtom is bad.
2= But when i put it in car charge it works perfect 'Y'?
You are using the "power shoe" to charge the battery. For a test unplug the power cord from the power shoe and hook it to the back of the Tomtom. If this work then the house charger is bad. If this doesn't work then the Tomtom rear power connector is bad
3= If ever i have to change battery how is this done?
You will have to remove the faceplate and disassemble the Tomtom in order to get to the battery. Or you can find a shop that repairs small electronic. Find the battery on Ebay.
Jan 12, 2008 | Tomtom GO 300 GPS Receiver
TomTom 910 charger question
Yes, you can.
I presume the charger has an USB connector.
5v and 2A are the correct figures for a Go910.
Aug 24, 2007 | Tomtom GO 910 GPS Receiver
Tomtom ONE 3rd Edition GPS Logo
110 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
