Question about Maytag Washing Machines
Washer not spining after wash and rinse cycle Nod # NAV800AWW
  • 413 Answers
Look under the machine and check belt for wear. Replace if any signs of cracks or rubber dust.
Posted on Jun 15, 2008
Roper washer new will not fill with warm water on rinse cycle it fills and spins
if its only a new machine make sure transport bolts have been removed
Apr 09, 2014 | Roper Washing Machines
Washer is full of water but will not spin
if your washer has old dial selector ,does it continues and finishes "cycle" without spining or does the selector stops moving also you could have a bad timer ,newer ones will have some sort of electronic module
Feb 23, 2012 | Kenmore Washing Machines
The cold water keeps running in the rinse cycle. it nrver fills up it drains out as it flows in
you kind of lost me with that one, but the washer should spray in cold water when in the rince cycle , spining , draining, and spray of cold water. Thats a normal rince.
Dec 12, 2009 | Whirlpool LSQ9600L Top Load Washer
Maytag neptune stops in mid cycle
It sounds like your drain pump is going. Neptunes are suppose to neqarly dry the clothes with how fast it spins. A poor drain pump/motor, could cause this to be less effective. There could also be something in the drain lines. I would check that before you pay money on a pump though.
Feb 28, 2009 | Maytag MAH20PD Front Load Washer
P801front load washer
put on prewash cycle. note which tray water enters and that is the prewash tray.
put on wash cycle which has no prewash. note which tray water enters and that is main wash tray. remaining tray is rinse
Sep 06, 2008 | Samsung WF337AA Front Load Washer
Washer not spining out
WITH MACHINE SET ON SPIN CYCLE, DEPRESS LID SWITCH. DOES IT PUMP OUT? DOES IT SEEM TO BE LOCKED UP AND DO NOTHING? CAN YOU ASSIST IT BY HAND AND IT TURNS? IF YOU CAN MAKE IT TURN WITH HELP,YOUR BELT IS PROBLY WARN. IF MOTOR RUNS AND YOU CAN'T SEEM TO GET IT TO TURN WITH HELP YOUR SUPORT BEARING FOR INTER TUB IS LIKELY STUCK AND BAD.MAJOR SERGERY REQUIRED.COST APPROX. 150.TO 200.00 TO FIX. THANK YOU HOPE I HELPED. FXIT
Jan 12, 2008 | Admiral AW22 Top Load Washer
Washing machine not spining
You may have a problem with the rotor position sensor. This sensor is situated on the motor windings and should really be replaced by a qualified tech.
Nov 04, 2007 | Fisher and Paykel IWL12 Top Load Washer
Wash cycle not working...
Kerbri, it sounds like your pressure switch could be the culprit. Under the top console the switch will be on the left side. There will be a clear tube that runs from the tub to the switch. Take another piece of tubing about the same size in diameter, disconnect the tube to the pressure switch and connect the tube. Blow into the pressure switch and see if the washer starts agitating. If so, replace the pressure switch.. Another thing to check would be the harness to the motor, make sure it is on tight. Good luck
Jun 26, 2006 | Kenmore 23022 Top Load Washer
Washing Machines Logo
20 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
