Question about Magic Chef Dryers
The drum on my dryer stopped turning it was heating and it just stopped turning, I just want to get instuctions on how to take it apart.
    Genius:
  • 1,142 Answers
If your dryer doesn't tumble, check these:
Belt
Motor
Door switch
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Posted on Jun 15, 2008
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Samsung apartment size dryer-there is heat but drum does not turn
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on May 27, 2010
I have a quiet pak 2 Kenmore. When I depress the start button the drum works but there is no heat. I stops workin when I take my finger off the start button. Model 110.73932102
I looked up the model number. You have a 90 series dryer made by whirlpool. You need to take it apart and clean it up, cheack all limits and safetys for continuity. I beleive you have a bad motor If the drum turns and the belt is not broken when you release you button it stops that is either the start switch or the motor.
Feb 05, 2014 | Kenmore Dryers
I have a Whirlpool dryer model LEN2000JQ0. The heating element glows red and gets really hot. You can feel the heat and smell the heat I go to turn on the dryer it makes a buzzing sound and the drum will...
I would change the control thermostat. It is mounted next to the skinny white fuse on the filter housing under the dust cover on the back side.
I worked on a dryer like this that had a heat problem and wrote about it HERE
Dec 31, 2012 | Dryers
The drum turns, the air blows but its not warm air.
sounds like a bad t-stat or heating element if you call me i can give you step by step instuctions on how to fix it you probably need a part that costs about $10.00
call
210 313 7844
steve
Nov 16, 2010 | Dryers
How do i take apart the my dryer
Sounds like a drum roller bearing. When they go bad they form a flat spot and that against the drum will give a loud thump. Turn the drum by hand and you should feel the flat spot. You may have to remove the back panel to get a good look see and a repair access. Good luck.
Jul 11, 2010 | Maytag Neptune MDG5500AW Gas Dryer
heatman101
May 26, 2010 | Samsung DV306LEW Electric Dryer
Dryer heats but drum does not turn when the start button is pushe
You need to check the drum belt. With dryer empty, reach in and give it a spin. If the belt is good, it will stop in 1/2 turn or less when released. If the belt broke, it will spin almost a full turn.
Oct 25, 2009 | Kenmore 62602 Electric Dryer
No heat coming in drum
Probably a bad heating element (which he will have to take it apart to see).
Sorry!
May 19, 2009 | Dryers
The heating compenent works, but drum won't spin
Have you checked the belt? That's generally the problem when a dryer stops spinning.
May 19, 2009 | Whirlpool LEQ9858L Electric Dryer
Motor not strong enough
The problem dosen't sound like the motor. Check to see if the drive belt is loose and slipping. This is the usual cause of the problem you describe. If not, the bearings for the drum may be going bad. The heating elements should turn off shortly if the drum stops so there is little danger of overheating.
Ray
Dec 15, 2008 | GE DBSR453EBWW Electric Dryer
Dryer drum wont turn
These units use two circuits to operate. It is entirely possible that the circuit breaker for one is open. The breakers are linked units...generally 30-40 amperes. Turn both off and then on.
Dec 20, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
247 people viewed this question
Top Magic Chef Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a Magic Chef Dryer Expert? Answer questions, earn points and help others
