Question about Home
The tub drain is installed but it is leaking around the flang not the stopper itself? i am assuming it is leaking outside the drain ? which appears to be in the room beneath it.. 2nd floor tub.... Do it need to completely take it off?
  • 28 Answers
If it is leaking from around the flange then you will need access to the under side of the tub drain to 1) tighten the drain connection or 2) replace the tub drain connection or 3) remove the drain, clean it and replace it again properly with the rubber washer and plumbers putty.
Posted on Nov 08, 2010
How do u fit door seal on a zanussi fjdr 1666w
Removal of the Seal.
Remove plastic clamp holding seal to cabinet and peel off the cabinet. Push downwards on the seal close to the tub and the seal will come off - its just held by a spring around the outside.
To fit the new Seal.
Lubricate the slot which fits over the tub with washing-up fluid.
Starting at the top, press the seal, so the flange of the tub enters the slot on the seal.
Work your way round the using thumbs to force the slot on the tub flange.
When the slot is on the flange all way round, fit the spring which holds it on.
The spring goes into a slot on the outside of the seal.
This is difficult, you may need another pair of hands.
Fit the outside of the seal to the cabinet and fit the plastic clamping ring.
Test for leaks.
Use Rinse to test for leaks, since the water level is higher.
Sep 10, 2017 | Zanussi Washing Machines
How do I take the drain plug off so I can clean it out?
If the drain is one like this
https://www.plumbingsupply.com/images/foot-actuated-tub-closure.jpg
You can remove it by unscrewing the cap anticlockwise. You may need vise-grips. Pad the jaws with masking tape.
If it is one like this
http://www.mustknowhow.com/wp-content/uploads/2010/04/drain.jpg
You must remove the center screw and strainer. In extreme cases you may need to remove and replace the drain flange with a special wrench
http://images.meredith.com/diy/images/2009/02/p_SCP_167_08.jpg
In some locations there is no center screw to the strainer, which is all one piece with the flange. These cannot usually be removed without access to the big nut on the underside of the tub
More info here
http://www.familyhandyman.com/plumbing/drain-repair/unclog-a-bathtub-drain-without-chemicals/view-all
May 08, 2015 | Home
Water is draining from hot tub after its filled & dont know why
Hi Mary,sounds like your drain stopper may not be closing tight.Try removing the stopper by turning it counter clockwise,then jam a small rag in the drain as tight as you can to stop the water and fill the tub.If it still leaks then the drain plug where the stopper goes may have to be re-sealed or one of the jets may have a leak.If the tub is over a ceiling do not keep re-filling the tub you will cause major water damage to the rooms below.
Jan 05, 2014 | Leisure Time Filter Clean 1 Quart - 12...
Leaking jacuzzi jet
The workings of a bath jet...From the inside of the Bath there is a wall fitting that threads from the inside of the tub into the jet body located on the outside wall of the tub.
If the jet is leaking at this point behind the tub then you should take the wall fitting out of the tub and put a small bead of 100% RTV silicone around the flange of the wall fitting and reinstall it.
If however, the leak is from the PVC piping going into the jet then you will need to replace the jet.
Rod
US Parts Center
888-521-6183
Jan 14, 2013 | Kohler Home
Hansgrohe 88509000 sink drain does not close completely, water slowly drains out
This could be caused by the installation. If the installer did not use plumber's putty between the the flange and basin it will not seal with the basin. Another possible cause is if the basin is not perfectly formed it will cause the flange to oval or not seat evenly. If this is the case it may leak between the flange and the basin or the stopper may not seat all the way down and it may leak between the stopper and flange.
Oct 16, 2012 | Hansgrohe 31060821 Metris S Single-Hole...
When installing do you silicone each piece for example the faucet , the soap dispenser ,the sprayer , and the tap
Hi seawitch678,
If you have a granite or stone countertop/sink, use silicone as plumber's putty will stain the stone. Plumber's putty is petroleum based so it will not adhere to stone. Normally you should use what the manufacturer recommends and where they recommend. When installing a faucet, put either around the base of any piece that goes through the countertop.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jul 15, 2011 | Price Pfister Marielle Kitchen Faucet with...
The sink drain leaks
Sounds like plumbers putty un drain flange to sink may need to be replaced or strainer may need to be tighten up a little to see if that stops the leak.
May 05, 2010 | Plumbing
Removing bath drain
There are two types of tub drain stoppers for the delta brand - lift & turn and toe tap.
Lift and Turn:
The lift & turn stopper for the bathtub unscrews counterclockwise while in the full up position.
Toe Tap:
The toe tap stopper does also but if the cap may unscrew from it before the entire stopper comes out. In that case, there is a nut that is now exposed and can be accessed to unscrew the assembly.
If either of these is "spinning" without unscrewing, the threads are stripped and you would need to exert upward pressure while unscrewing in hopes of uncoupling this from the bath waste. If that doesn't work you would have to unscrew the bath waste flange from the drain pipe.
This will require access under the tub. I hope this answer the question for you. Thank you for using FIXYA. Jeff
Apr 09, 2010 | Delta Home
My 2000 kohler tub drain leaks. The drain itself
Need clarification....the drain leaks to the ceiling below, or it doesn't hold water? If it doesn't hold water, no need to replace the ring. Those can be adjusted. Simply pull up on on the lever and screw it in clockwise. This will lower the stop and hold the water. If it actually leaks below, unscrew said stopper, grab a pair of needle nose pliers and place them in the drain (to grab the strainer) and use another pair to loosen. Once off, clean around drain and clean strainer, apply plumbers putty to the strainer, apply pipe "dope" (thread sealant) to the threads and tighten back in. Good luck!
Nov 25, 2009 | Kohler 1107-R-0 ProFlex Bath Tub with...
I have a new push push drain from mac faucets, and it leaks. I have reversed the rubber gasket that goes under the sink (held on by the brass threaded ring assume that I don't use plumbers putty under the...
The order of installation starting from the top side is the flanged drain then a bead of plumber's putty, and don't skimp on the putty. On the bottom side, first the rubber gasket then the metal washer, finally the locking ring. You must use the plumber's putty between the sink\tub surface and the flange. My mom thought the same thing. She return her drain twice before she asked me why it was leaking:)
Hope this helps.
Sep 11, 2009 | Opella 2-3/8" Push-Push Drain Assembly...
Home Logo
88 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
