Master
- Posted on Nov 06, 2010
Re: Hello,
I want to remove the pedistles on my...
Hi, follow the instruction below on how to remove the Pedestal on your Kenmore Washer..
Instruction:
- Unplug the washer power cord from the wall outlet. When removing the pedestal from a washer, turn off the water supply to the hoses.
- Disconnect the water supply hoses with a pair of pliers if you are working on the washer. Move the washer or dryer away from the wall enough so that you can tip the unit on its back.
- Open the drawer to the pedestal and remove the contents from the drawer. Grasp the clips on the drawer slides on each side of the drawer and squeeze them toward the drawer. Pull the drawer completely out of the pedestal. Push the pedestal slides back into the pedestal.
- Place cardboard or a sheet on the floor behind the unit. Ask a friend to help you tilt the unit on its back on top of the cardboard or sheet. Remove the four screws securing the pedestal to the bottom of the washer with a Phillips-head screwdriver. Pull the pedestal away from the washer.
- Insert the sheet metal screws back into the bottom of the washer where they secured the pedestal. Screw the feet for the unit into the four threaded holes on the bottom corner of the unit.
- Tilt the unit back into the upright position. Level the unit according to the unit's user manual and reconnect the unit.
yes
